- 数量:1000
- 有效期:2027/4/24 0:00:00
EXC58171727 MEMORY BOARD ABB
EXC58172120 POWER SUPPLY ABB
EXC58172936 TERMINAL BLOCK BOARD ABB
EXC58174301 POWER SUPPLY ABB
EXC61522981 ABB
EXC63938742 ABB
EXC64059254 ABB
F1SE ABB
G1MP110G00 30MM PB,FLUSH,GREEN ABB
G1MP110R00 30MM PB,FLUSH,RED ABB
GHR4110001R1 ABB
GHR4120000V0 ABB
GHR4120001R1 ABB
GHR4140000V0 ABB
GHR4220000V0 ABB
GHR5120000V0 ABB
GJD8280310R106 ABB
GJL2001510R8061 COIL 220V 50HZ/ 240V 60HZ ABB
GJR5113100B2 ABB
GJR5113100R11 ABB
GJR5121200R12 ABB
GJR5231200R1 ABB
GJR5231200R1C ABB
GN280S31FC ABB
GNT2005805E0005 ASD 6351 Exchange ABB
GNT2009526E0032 GCB 6222 C Exchange ABB
GNT2009526E0034 GCB 6422 C Exchange ABB
GTU453 12 IN RACK ABB
GU112M4A1GS2235923C ABB
HK102 MS116 AUX SW 2NC SIDE MT ABB
HK111 MS116 AUX SW 1NO-INC SID ABB
HNFE403401R3 ABB
HNM00048 ABB
HRV13SC COIN COUNTER ABB
IB116G ENCL MS116 IP65 BLK HDL ABB
IC660BBA021 ABB
IC660BBA026 ABB
IC660BBD021 ABB
IC660BBD022 ABB
IC660BBD023 ABB
IC660BBR100 ABB
IC660BBS103 ABB
IC660EBA021 ABB
IC660TBA021 ABB
IEMMU01 ABB
IEMMU21 ABB
IEPAF01 ABB
IEPAF02 ABB
IEPAS01 ABB
IEPAS02 ABB
IEPEP03 ABB
IH540EN ABB
IMASI03 ABB
IMASO01 ABB
IMASO11 ABB
IMBLK01 ABB
IMCIS02 ABB
IMDS12 ABB
IMDSI02 Input Module ABB
IMDSI12 ABB
IMDSI13 ABB
IMDSI22 ABB
IMDSM04 ABB
IMDSM05 ABB
IMDSO01 ABB
IMDSO04 ABB
IMDSO14 ABB
IMFBS01 ABB
IMFEC11 ABB
IMMFP01 ABB
IMMFP02 ABB
IMMFP03 ABB
IMMPI01 ABB
IMRIO02 ABB
INICT03A ABB
INNIS01 ABB
INNPM01 ABB
INNPM11 ABB
K1600 Circuit Breaker ABB
K1600S Circuit Breaker ABB
K1DMB DIN-RAIL MT BRKT S1 ABB
K2000 Circuit Breaker ABB
K225 Circuit Breaker ABB
K225S Circuit Breaker ABB
K3000 Circuit Breaker ABB
K3TA LUG KIT S3 2-14AWG 3 LUGS ABB
K4000 Circuit Breaker ABB
K402 CONTROL RELAY 4NO, 240/60 ABB
K4LC LUG COVER S4 3P ISO ABB
K4NCT250 ABB
K4RA RING TERM ADAPTER KIT S4 3 ABB
K4TB LUG KIT S3/S4 1/0-14AWG 3 LUGS ABB
K4TC LUG KIT S3-S4 4/0-2AWG 3 LUGS ABB
K4TD LUG KIT S4 300MCM-4AWG 3 LUGS ABB
K4TDC LUG KIT S4 300MCM-4 CONTROL ABB
K4TE LUG KIT S4 350MCM-6AWG 3 LUGS ABB
K4TE2 LUG KIT S4 350MCM-6AWG 2 LUGS ABB
K5C036 S3/S5 FLANGE CABLE 36 IN ABB
K5C048 S3/S5 FLANGE CABLE 48 IN ABB
K5FCH4 S3/S5 FLANGE CBL HDL 4,4X ABB
K5LCH LUG COVER, HIGH RCS S5 3P ISO ABB
K5M8 ELECT OPER S5 24VDC ABB
K5NCT400 ABB
K5RH ROTARY HANDLE S3/S5 ISO ABB
K5S4 SHUNT TRIP 120VAC/125VDC S ABB
K5U8 UV TRIP 24VDC S3/S5 ABB
K5VDM VARIABLE DEPTH MECH S3/S5 ABB
K600 Circuit Breaker ABB
K600S Circuit Breaker ABB
K622F CONTROL RELAY,2NO2NC,24/40-60 ABB
K632 ABB
K633 ABB
K6402 CONTROL RELAY,4NO,240/40-450 ABB
K643 ABB
K644 ABB
K652 ABB
K653 ABB
K662 ABB
K663 ABB
K673 ABB
K6CSU CONNECTOR ST/UV S3/S6 ISO ABB
K6NCT600 ABB
K6NCT800 ABB
K6VDM VARIABLE DEPTH MECH S6 ABB
K7NCT1000 ABB
K7NCT1200 ABB
K800 Circuit Breaker ABB
K800S Circuit Breaker ABB
K932 ABB
K933 ABB
K942 ABB
K943 ABB
K952 ABB
K953 ABB
K962 ABB
K963 ABB
K972 ABB
K973 ABB
KA Circuit Breaker ABB
KA18030 30MM ADAPTER RING ABB
KA22021 LED BULB,RED,24V AC/DC ABB
KA22132 LED BULB-110-130VAC, GRN ABB
KA701001 STACKLIGHT,CONTACT BOX,SIDE EX ABB
KAF Circuit Breaker ABB
KB Circuit Breaker ABB
KB302 NLA ,240/60,220/50 ABB
KB30G COIL 42 VAC ABB
KBC30G04 KBC30G-04 ABB
KBC30G05 KBC30G-05 ABB
KBC30Y NLA,MUST REPLACE CONTR/RELAY ABB
KBE Circuit Breaker ABB
KC Circuit Breaker ABB
KC22E05 RELAY,2-2,220VDC ABB
KC40Q NLA,REPLACED BY KC40E-27 ABB
KCG Circuit Breaker ABB
KD Circuit Breaker ABB
KDON1600 Circuit Breaker ABB
KDON225 Circuit Breaker ABB
KDON600 Circuit Breaker ABB
KDON800 Circuit Breaker ABB
KDON800S Circuit Breaker ABB
KE Circuit Breaker ABB
KF225 Circuit Breaker ABB
KF600 Circuit Breaker ABB
KFP225 Circuit Breaker ABB
KFP600 Circuit Breaker ABB
KH145F COIL,24/60 ABB
KH145N COIL,24/50 ABB
KH2101 COIL,120/60 ABB
KH210F COIL,24/60 ABB
KH210N COIL,24/50 ABB
KL40BCK403 ABB
KL50BCK503 ABB
KL63BCK633 ABB
KL70305R STACKLIGHT,RED,LED,24V AC/DC ABB
KL75BCK753 ABB
KSDB320N SOLID STATE TIMER ABB
KSP1600 Circuit Breaker ABB
KSP2000 Circuit Breaker ABB
KSP3000 Circuit Breaker ABB
KSP4000 KSP4000 Circuit Breaker ABB
KSP600 Circuit Breaker ABB
KT1LTC3 LOW TERM COVER T1 3P 2 ABB
KT31003C LUG KIT T3 1/0-14AWG WITH ABB
KT32253 LUG KIT T3 300MCM-4AWG ABB
KT3HTC3 HIGH TERM COVER T3 3P 2PCS ABB
KT3RH ROTARY HDL T1-T3 DIRECT M ABB
KT3VD20PN4 T1 OPERATOR MECHANISM KIT ABB
KT42503 LUG KIT T4 350MCM-6AWG ABB
KT5LTC4 LUG COVER ABB
L14321001000 L143200 10PTS/3.81 ABB
L23211501000 L 232 100 15PTS/5. ABB
L25510711000 L 255 100 7PTS/5.0 ABB
LG Circuit Breaker ABB
LK16 Circuit Breaker ABB
LK1600 Circuit Breaker ABB
LK42 Circuit Breaker ABB
LK8 Circuit Breaker ABB
LKD16 Circuit Breaker ABB
LKD8 Circuit Breaker ABB
LKE8 Circuit Breaker ABB
LR370AE ABB
LT160EC NLA USE LT210-EC ABB
LT185AL TERM SHROUD,A145-185,COMPR ABB
LX Circuit Breaker ABB
M2SS510B 3POS, LONG, A-C, BLK, BP ABB
M2SSK1101 2 FIX POS,KEY REM B-C,CODE 71 ABB
M2SSK3101 2POS B ABB
M3SS110R 3POS,KNOB,A-B-C,RED,BP ABB
M3SS510B 3POS,LONG,A>B ABB
M3SSK260111 3POS KEY SS REM B 1NO-1NC ABB
MB16 Circuit Breaker ABB
MB8 Circuit Breaker ABB
MBT160MMK1610043D ABB
MC19PR0026 ABB
MC19PR02040790 ABB
MCB01 CONTACT BLOCK,1-NC ABB
MCB01B CONTACT BLOCK,1-NC BSMNT ABB
MCB10 CONTACT BLOCK, 1-NO ABB
MCBH00 3 CONTACT BLOCK HOLDER ABB
MCBH101 1 NO CONT BLK+LAMPBLK W/HLDR ABB
MCBH11 1NO 1NC CONTACT BLOCK W/HLDR ABB
MCBH201 2 NO CONT BLK+LAMPBLK W/HLDR ABB
MCC9006IO8 ABB
ML1100RF1 P. LIGHT, F.V. 120V, RED ABB
MMDA997501P20 ABB
MP111G MOM,FLUSH,GRN,BP,ILL ABB
MP111R MOM,FLUSH,RED,BP,ILL ABB
MP131R MOM,FLUSH,RED,MTL,ILL ABB
MP160G10 GREEN PUSH BUTTON ABB
MP160R01 RED PUSH BUTTON ABB
MP1KSP10K SPEED POT. 2W 10K BLACK RING ABB
MP311L MOM,EXTD,BLU,BP,ILLBUTTON ABB
MP331G MOM,EXTD,GRN,MTL,ILL ABB
MPD1511B FL/EXT,ST/ST,GRN/RED,BLK ABB
MPMT411R TWIST,60MM,RED,ILL ABB
MPOT01 POTENTIOMETER ABB
MS1160.16 3P MMP 0.1-0.16A RAN ABB
MS1160.25 3P MMP O.16-0.25A RA ABB
MS1161.0 3P MMP 0.63-1.0A RANG ABB
MS11610 3P MMP 6.3-10.0A RANGE ABB
MS1162.5 3P MMP 1.6-2.5A RANGE ABB
MS3250.16 3PH MANUAL STR. 0.10-0.16A ABB
MS3250.25 3PH MANUAL STR. 0.16 ABB
MS3250.63 3PH MANUAL STR. 0.40 ABB
MS3251.0 3PH MANUAL STR. 0.63- ABB
MS32512.5 3PH MANUAL STR. 9.0-12.5A ABB
MS32516 3PH MANUAL STR. 12.5-1 ABB
MS3252.5 3PH MANUAL STR.1.6-2. ABB
MS32525 3PH MANUAL STR. 20-25A ABB
MS3252BB USE UP REPLACE W/PS3-2-0 ABB
MS3254.0 3PH MANUAL STR. 2.5-4.0A ABB
MS3256.3 3PH MANUAL STR. 4.0-6.3A ABB
MS325B7 CLOSE COUPLER MS325+B6,B7 ABB
MS325BB1 CONNECTION.TERM.BLOCK,BUSBAR ABB
MS325EP3 ENCLOSURE ABB
MS325HK02 AUXILIARY CONTACT HK ABB
MS325HK11 AUX CONT HK-11,1N/0,1N/S ABB
MS325SA SHAFT ADAPTOR KIT,5X5,MS325 ABB
MS325SM1 CONNECTION TERM.BLOCK,WIRE ABB
MS325TC COVER.TRANSP.IDENTIFIC.MARKER ABB
MS325VB7 CLOSE COUPLER MS325+VB7M REV. ABB
MTR90L246 ABB
MUL1R1 NEMA 1 ENCLOSURE KIT ABB
MUL1R3 NEMA 1 ENCLOSURE KIT ABB
N22E84 RELAY,2-2,110/50,110-120/60 ABB
N31E81 RELAY,3-1,24/50/60 ABB
N31E84 RELAY,3-1,110/50,110-120/60 ABB
N40E80 RELAY,4-0,220/50,240/60 ABB
N40E84 RELAY,4-0,110/50,110-120/60 ABB
N44E84 RELAY,4-4,110/50,110-12 ABB
N53E80 RELAY,5-3,220/50,240/60 ABB
N53E84 RELAY,5-3,110/50,110-12 ABB
N62E84 RELAY,6-2,110/50,110-120/60 ABB
N71E84 RELAY,7-1,110/50,110-12 ABB
N80E84 RELAY,8-0,110/50,110-120/60 ABB
NDCO03KIT ABB
NF32E3PYJA 3P SW 30A IP65 SZ-0 RED HDL ABB
NL22E81 CONTROL RELAY,24VDC,2NO-2NC ABB
NL31E81 CONTROL RELAY,24VDC,3N ABB
NL40E81 CONTROL RELAY,24VDC,4N ABB
OA1G01 1-NC AUX SW OT16-125 ABB
OEA28 AUX HOLDER OT/OS200-400 ABB
OESA00160 ABB
OESA0032 ABB
OESA0063 ABB
OESA400D3 ABB
OESACF30CC6S ABB
OESACF30J6S ABB
OESAF100JT6A ABB
OESAF30J6F NLA USE OESA-CF30J ABB
OESAF60T6A ABB
OESAZX223 NLA COVER OESA-F60 3P ABB
OETL1000K3 ABB
OETL1600K3 ABB
OETL2500K3 ABB
OETLNF100S ABB
OETLNF100T NLA SW T 100A ABB
OETLNF200AF 3P SW 200A NF FLA ABB
OETLNF30S ABB
OETLNF30T NLA SW T 40A/UL ABB
OETLNF60 DISCONNECT SWITCH ABB
OETLNF60S ABB
OETLNF60T NLA GGLE SW 80A ABB
OETLZA75 PSTL SHAFT 12/10MM BK ABB
OETLZS37 NLA HDL SHAFT 5 X 150 ABB
OETLZS50 NLA - USE OXZS50 ABB
OETLZS55 SHAFT, 7.09 (180MM) 5MM SQ ABB
OETLZX100 PISTOL HANDLE, I/O, RED/YELLOW ABB
OETLZX102 HANDLE, BLK, ON-OFF ABB
OETLZX105150 NLA USE OHB2AJ1 & OX180 ABB
OETLZX47 HANDLE ABB
OETLZX58 SHAFT SUPPORT NF 30-100A ABB
OHB2AJ OT SELECTOR HDL BLK 3R,1 ABB
OHB2AJ1 SELECTOR HDL,BLACK NON-DEF ABB
OHB2PJ SEL HDL BLK SNAP-ON DOOR MTD ABB
OHB2RJ SEL HDL BLK DOOR MTD SCR ABB
OHB65J5 PSTL HDL 5X65MM BLACK 3 ABB
OHB80L6 PSTL HDL 6X80MM BLACK 4,4X ABB
OHBZX47 NLA OL HDL,ON/OFF,UL TYPE 12 ABB
OHBZX99 NLA CARRIER USE ONLY ABB
OHY2AJ1 SELECTOR HDL,RED/YEL NON-DEF ABB
OHY65J5 PSTL HDL 5X65MM RED/YEL 3R,12 ABB
OHY65J6 PSTL HDL 6X65MM RED/YEL ABB
OHYZX48 OHYZX48 ABB
OPMP01 REMOTE PANEL ABB
OS30ACC12 3P SW 30A CC FUSE 600V UL98 ABB
OT100E3 3P SW 100A NF 600V UL98 ABB
OT16E3 3P SW 16A NF 600V ABB
OT16ET3 16A NF SW 3-P 600V DOOR ABB
OT200U03 3P SW 200A NF UL98 600 ABB
OT200U03FC SW200A NF FLNG CBL OPER ABB
OT25E3 3P SW 25A NF 600V ABB
OT32E3 3P SW 40A NF 600V ABB
OT32ET3 40A NF SW 3-P 600V DOOR MOUNT ABB
OT45B2A1180 OT45,HDL,SHAFT KIT ABB
OT45E3 3P SW 60A NF 600V ABB
OT45E6 6P SW 60A NF UL508 ABB
OT60E3 3P SW 60A NF 600V UL98 ABB
OT63E3 3P SW 80A NF 600V ABB
OTPS32ED 40A 1-P EXTRA POLE DOO ABB
OTPS32EP 40A 1-P EXTRA POLE 600V ABB
OVR3N40320P TVSS 4P 40KA 320V ABB
OXP10X225 PSTL SHAFT 8.9" 10 X 225 ABB
OXP5X500 PSTL SHAFT 19.7" 5X500 ABB
OXP6X210 PSTL SHAFT 8.3" 6X210 ABB
OXS5X130 SEL SHAFT 5.1" 5X130 ABB
OXS5X180 SEL SHAFT 7.1" 5X180 ABB
OXS5X330 SEL SHAFT 13.0" 5X330 ABB
OXZS67 NLA, REPLACED BY OXP5X170 ABB
PFBK101 ABB
PFBK102 ABB
PFBK103 ABB
PG2134NPT ADAPTER,PLASTIC,PG21-3/4NPT ABB
PHAREPRFO10000 ABB
PHBAIN1200S100 ABB
PHBAOT1500S100 ABB
PHBBLK10000100 ABB
PHBBLK10010000 ABB
PHBDIO4000R100 ABB
PHBRMU1000N100 ABB
PHBRMU10010000 ABB
PM810 ABB
PP10012HS ABB
PP104812 ABB
PP15012HS ABB
PP18017HS ABB
PP18017HS(ABB)6A ABB
PP18017HS6AFESP5 ABB
PP18017HS6AGESP6 ABB
PP18017HS6AHD2P ABB
PP20012HS ABB
PP20012HS(ABB)5A ABB
PP25485 ABB
PP30012HS ABB
PP355 ABB
PP7512HS ABB
PR500280 ABB
PS16016 MCB BUS 1PH 60P 80A SUPP ABB
PS2616BP MCB BUS 2PH 6P 80A BCPD ABB
PS341 MS325 BUSBAR 63A 4DEV 1 AUX SW ABB
PSBEND3 END CAP 3PH ABB
PSBEND4 END CAP 4 WIRE ABB
PSC8 TWO HOLD-DOWN CLIPS FOR 8 PIN ABB
PSENDSP MCB BUS 2-3PH END CAP (1 PAIR) ABB
PSR660070 PSR SFTSR,OPEN,600V/240VAC CTL ABB
PST10560070 ABB
PST14260070 ABB
PST17560070 ABB
PST21060070 ABB
PST25060070 ABB
PST30060070 ABB
PST3060070 ABB
PST3760070 ABB
PST4460070 ABB
PST5060070 ABB
PST7260070 ABB
PST8560070 ABB
PSTB105060070 ABB
PSTB37060070 ABB
PSTB47060070 ABB
PSTB57060070 ABB
PSTB72060070 ABB
PSTB84060070 ABB
PU512V1 ABB
PU512V2 ABB
PU515A ABB
R32822 ABB
RA51 INTERFACE RELAY,A9-A110 ABB
RAIO01 ABB
RC51133 A9-A40,SS,RC,50-133V ABB
RC51250 A9-A40,SS,RC,110-250V ABB
RC5150 A9-A40,SS,RC,24-50V PA ABB
RC52133 A45-A110,SS,RC,50-133 ABB
RC52250 A45-A110,SS,RC,110-25 ABB
RC5250 A45-A110,SS,RC,24-50V ABB
RCEH25048 TWO HOLD-DOWN CLIPS FOR 8 PIN ABB
RFS100115 FE14.2 FUSE TERMINAL ABB
RFS100119 FE14.2.M FUSE TERM W/ ABB
RK214002AD ABB
RK214002AH ABB
RK214002AN ABB
RK214002AS ABB
RK214003AD ABB
RK214003AH ABB
RK214003AN ABB
RK214003AS ABB
RK214004AD ABB
RK214004AH ABB
RK214004AN ABB
RK214004AS ABB
RK214005AD ABB
RK214005AN ABB
RK214009AH ABB
RK426234BK ABB
RLY100 ABB
RT532 SURGE SUPPRESSOR,12-32VD ABB
RV5440 A9-A110,SS,VARISTOR,250 ABB
RV550 A9-A110,SS,VARISTOR,24-5 ABB
RVBC6250 SURGE SUP.,110-250V AC/DC ABB
S201B20 MCB 1P B 20A 480Y/277 SUPP ABB
S201C0.5 MCB 1P C 0.5A 480Y/27 ABB
S201C10NA MCB 1P+N C 10A 480Y/ ABB
S201C16NA MCB 1P+N C 16A 480Y/ ABB
S201C4 MCB 1P C 4A 480Y/277 SUPP ABB
S201C6NA MCB 1P+N C 6A 480Y/27 ABB
S201K0.5 MCB 1P K 0.5A 480Y/27 ABB
S201K1 MCB 1P K 1A 480Y/277 SUPP ABB
S201K1.6 MCB 1P K 1.6A 480Y/27 ABB
S201K10 MCB 1P K 10A 480Y/277 SUPP ABB
S201K13 MCB 1P K 13A 480Y/277 ABB
S201K15 MCB 1P K 15A 480Y/277 ABB
S201K16 MCB 1P K 16A 480Y/277 SUPP ABB
S201K2 MCB 1P K 2A 480Y/277 SUPP ABB
S201K20 MCB 1P K 20A 480Y/277 ABB
S201K25 MCB 1P K 25A 480Y/277 ABB
S201K3 MCB 1P K 3A 480Y/277 SU ABB
S201K30 MCB 1P K 30A 480Y/277 ABB
S201K32 MCB 1P K 32A 480Y/277 ABB
S201K4 MCB 1P K 4A 480Y/277 SUPP ABB
S201K40 MCB 1P K 40A 480Y/277 ABB
- 电话:020-87268766
- 传真:020-87269099
- email:gzlaijie@163.com
上一篇:广州莱捷电器专业销售ABB
ABB广州莱捷专业代理
