当前页面: 首页 >供求信息 >广州莱捷电器专业销售ABB
广州莱捷电器专业销售ABB
供稿:gzlaijie 2013/1/24 10:19:19
人气:62
  • 有效期:2027/4/24 0:00:00
ACS800U100257 ABB
ACS800U100302 ABB
ACS800U100305 ABB
ACS800U100305+D150 ABB
ACS800U100307 ABB
ACS800U100402 ABB
ACS800U100405 ABB
ACS800U100405+D150 ABB
ACS800U100407 ABB
ACS800U100502 ABB
ACS800U100505 ABB
ACS800U100507 ABB
ACS800U100602 ABB
ACS800U100605 ABB
ACS800U100607 ABB
ACS800U100702 ABB
ACS800U100705 ABB
ACS800U100707 ABB
ACS800U101005 ABB
ACS800U101007 ABB
ACS800U101205 ABB
ACS800U101207 ABB
ACS800U101405 ABB
ACSHCPEXT CONTROL PANEL ABB
ACSPanB ABB
AE110300004 AC contactor ABB
AE110301104 AC contactor ABB
AE3030 ABB
AE30301183 AE30-30-11-83 ABB
AE50300004 AC contactor ABB
AE50301104 AC contactor ABB
AE50301188 AE50,3P CONTR,220 ABB
AE63300004 AC contactor ABB
AE63301104 AC contactor ABB
AE7530 ABB
AE75300004 AC contactor ABB
AE75300085 AE75 3P CONTR,75V ABB
AE75301104 AC contactor ABB
AE95300004 AC contactor ABB
AE95301104 AC contactor ABB
AE9S81F AE9 3PH STR,24VDC,OPEN ABB
AE9S81K AE9 3PH STR,24VDC,OPEN ABB
AF40030 ABB
AI830 ABB
AI890 ABB
AIN220 ABB
AL12300181 AL12,3P CONTR, 24 ABB
AL12301081 AL12,3P CONTR, 24 ABB
AL16301081 AL16,3P CONTR, 24VDC,1 NO AUX ABB
AL26301081 AL26,3P CONTR, 24 ABB
AL30300181 AL30,3P CONTR, 24 ABB
AL40300183 AL40,3P CONTR, 48 ABB
AL9300183 AL9,3P CONTR, 48VD ABB
AL9301081 AL9,3P CONTR, 24VDC,1 NO AUX ABB
AO820 ABB
AOT150 ABB
ASC15003U06A72 ABB
ASC35003U06A72 ABB
B12400081 CONTACTOR ABB
B12C2 NLA,REPLACED BY A12-30-10-80 ABB
B16C2 CONTACTOR ABB
B16C201 NLA,REPLACED BY A16-30-01-84 ABB
B25C301 NLA,REPLACED BY A26-30-01-42 ABB
B30C1 NLA USE A30-30-10-84 ABB
B30CF NLA USE A30-30-10-81 ABB
B30CG NLA USE A30-30-10-83 ABB
B6CSP1 3P CONTR,SOLDER PIN,120/60 ABB
B75C2 NLA,REPLACED BY A75-30-11-80 ABB
B7SC1.7 MINI CONTR 24V/1.7W,1NO AUX ABB
BBCXT374E ABB
BC16300104 AC contactor ABB
BC16301004 AC contactor ABB
BC16C4PW Contactor ABB
BC16CP NLA,REPLACED BY BC16-30-10-01 ABB
BC25301004 AC contactor ABB
BC25301005 CONTACTOR ABB
BC30300004 AC contactor ABB
BC30302204 AC contactor ABB
BC30302227 REPLACED BY AL-30-30-22-87 ABB
BC6CSPU 3P MINI CONTR,1NC,12VDC,SP ABB
BC6CY 3P CONTR.24VDC,1NO ABB
BC6CY01 3P CONTR.24VDC,1-NC ABB
BC7CQ MINI CONTR.W/125VDC COIL ABB
BC7CU01 MINI CONTR.W/12VDC COI ABB
BC9300104 AC contactor ABB
BC9301004 AC contactor ABB
BC9301027 REPLACED BY AL9-30-10-87 ABB
BC9400027 REPLACED BY AL9-40-00-87 ABB
BER16V REV BUS MI A/AL9-A/AL16 ABB
BHD15C1 AC Contactors ABB
BHD15C2P1 AC Contactors ABB
BHD15C3P1 AC Contactors ABB
BHD30C2P1 AC Contactors ABB
BHD30C3P1 AC Contactors ABB
BHD60C1 AC Contactors ABB
BHD60C2P1 AC Contactors ABB
BHD60C3P1 AC Contactors ABB
BRC100 ABB
C2SS110B20 CP 2POS SS MAIN BLK, 2NO ABB
C2SS210B20 CP 2POS SS MAIN BLK ABB
CA501 A AUX BLK,1NC ABB
CA504E A AUX BLK,4P CONTR,4NC ABB
CA504M A AUX BLK,3P CONTR,4NC ABB
CA522E A AUX BLK,4P CONTR,2NO-2NC ABB
CA522M A AUX BLK,3P CONTR,2NO-2NC ABB
CA531E A AUX BLK,4P CONTR,3NO-1NC ABB
CA531M A AUX BLK,3P CONTR,3NO- ABB
CA540E A AUX BLK,4P CONTR,4NO ABB
CA540N A AUX BLK,RELAY,4NO ABB
CA701 AUX BLK,1NC ABB
CA704K NLA REPLACE W/CA5-04N ABB
CA710 AUX BLK,1NO ABB
CA722E NLA AUX.CONTACT,B50-75 NLA ABB
CA722M NLA REPLACE BY CA5-22M ABB
CA740E USE UP REPLACE BY CA5-40E ABB
CA740K NLA REPLACE WITH CA5-40N ABB
CA7DNC15 DB BLOCK, 15A 300V DB ABB
CAF602K TOP MTD.AUX.2NC,K6 & KC6 ABB
CAF611K TOP MTD.AUX.1NO-1NC K6 & KC6 ABB
CAF620K TOP MTD.AUX.2NO,K6-KC6 ABB
CAL1811 A95-AF1650 AUX,1NO & 1NC ABB
CAL1811B A95-AF1650 EXTRA AUX, ABB
CAL711 NLA AUX.CONTACT,B50-75 NLA ABB
CBFBEC BUTTON,CLEAR,EXTENDED ABB
CBFBEG BUTTON,GREEN,EXTENDED ABB
CBFBER BUTTON,RED,EXTENDED ABB
CBFBR BUTTON,RED,FLUSH ABB
CBFLC LAMP CAP,CLEAR,(ASSY) ABB
CBFLF1L CBF-LF1L ABB
CBFLF1W PILOT LIGHT,120V.WHITE ABB
CBFLFL8R P/L,LED RED 24V ABB
CBFLG LAMP CAP,GREEN,(ASSY) ABB
CBFLL LAMP CAP,BLUE,(ASSY) ABB
CBFLR LAMP CAP,RED,(ASSY) ABB
CBFLW LAMP CAP,WHITE,(ASSY) ABB
CBFLY LAMP CAP,YELLOW,(ASSY) ABB
CBFPER PB,EXTD.RED ABB
CBFPIF8G10 PB,ILL.FV,24V,GREEN,1-NO ABB
CBFPPIF8W10 CBF-PPIF8W10 ABB
CBFPR01 PB,FLUSH,RED ABB
CBGKPG 30MM PB,FLUSH,GREEN ABB
CBGKPPIF8W10 30MM ILL PB,MAINT,FV,24V,WHT ABB
CBGPMT40R 30MM 40MM TWIST REL, ABB
CBK2AMKIL ILL.2-POS.SW.MAIN.A-C,BLUE ABB
CBK2AMKIY ILL.2-POS.SW.MAIN.A-C,YELLOW ABB
CBK2AMLE 2-POS.SW.GREY LEVR,MAIN,A-C ABB
CBK2AMLIC ILL.2-POS.SW.MAIN.LVR,A-C,CLR ABB
CBK2BMK20 2-POS.SW.MAIN.B-C,2N ABB
CBK2BMKIG ILL.2-POS.SW.MAIN.B-C,GREEN ABB
CBK2P1 2PB FLSH/GRN/STT,EXTD/RED/STP ABB
CBK3MLIG ILL.3-POS.SW.MAIN.LEVER,GREEN ABB
CBKBM3RA BUTTON,MSHRM.RED,30MM,W/ARROW ABB
CBKBZ8 BUZZER,CONTINUOUS,24V A ABB
CBKBZR BUZZER WITH 24VDC BUZZER BULB ABB
CBKCB01 CONTACT BLOCK, 1-NC ABB
CBKCB10 CA CONTACT BLOCK,1-NO ABB
CBKEST6IR E-STOP OPER,60MM,TWIST REL,ILL ABB
CBKKBEIG BUTTON,ILL.GREEN,EXTE ABB
CBKKBEIW BUTTON,ILL.WHITE,EXTE ABB
CBKKBIR BUTTON,ILL.RED,FLUSH ABB
CBKKLF8R P.LIGHT,F.V.24V,RED ABB
CBKKLFPT1G P-T-T LIGHT, F.V.120V,GREEN ABB
CBKKPB PB,MOM.FLUSH,BLACK ABB
CBKKPER PB,MOM.EXT'D,RED ABB
CBKKPR PB,MOM.FLUSH,RED ABB
CBKKPR11 PB,MOM,FLUSH,RED,1NO/1NC ABB
CBKLBDR NLA, REPLACED BY CBK-LBD8R ABB
CBKLBDY NLA REPLACE WITH CBK-LBD8Y ABB
CBKLL CBK-LL ABB
CBKLMF LAMP MODULE,240V MAX. ABB
CBKLT1Y CBK-LT1Y ABB
CBKLT2Y CBK-LT2Y ABB
CBKNPE26 N/P,ENGRAVED HAND-OFF ABB
CBKNPE28 BLANK N/P,ALUMINUM,1-2 LINE ABB
CBKNPE28BA BLANK N/P,BRUSHED A ABB
CBKPMT40R02 40MM MUSHRM,TWIST-REL.RED,2-NC ABB
CBKPMT40RABBGCBKPMT40RABBG ABB
CBKPR NLA FLUSH,RED ABB
CCL1801 AUX BLOCK W/VARISTOR,A ABB
CI520V1 ABB
CI522A ABB
CI540 ABB
CI570 ABB
CI810V1 ABB
CS512 ABB
CXBY68140 DOOR MT HANDLE LOCKING CLIP ABB
CXBY68306 RED HANDLE,1.4",OT45-OT125 ABB
D0205104 ABB
DA3501 ABB
DB2525A SEPARATE MOUNTING KIT-TA25DU ABB
DB2532A SEPARATE MOUNTING KIT-TA25DU32 ABB
DCF1077359E0001 DCF504-0050 Exchange ABB
DCS40200259 ABB
DHM5100256002 ABB
DI801 ABB
DI820 ABB
DI890 ABB
DIO400 ABB
DK3301 ABB
DO801 ABB
DO802 ABB
DO890 ABB
DPH10051D5150011 ABB
DSAO110 ABB
DSAO120 ABB
DSBC173 ABB
DSCA114 ABB
DSDO110 ABB
DSDX110 ABB
DSMB124 ABB
DSMB125 ABB
DSMB127 ABB
DSMC110 ABB
DSPC153 ABB
DSPC157 ABB
DSQC ABB
DSQC103 ABB
DSQC104B ABB
DSQC129 ABB
DSQC236B ABB
DSQC236D ABB
DSQC253 ABB
DSQC324 ABB
DSSR115 ABB
E22511C PUB SW 1NO/1NC RED LEN ABB
E22511E PB SW 1NO/1NC YELLOW LWNS ABB
ED0100 NAAST STELLING ABB
ED0183 IN KOFFER ABB
ED1103 ABB
ED1111 ABB
ED1121 ABB
ED1210 ABB
ED1310 ABB
ED1311 ABB
ED1319 ABB
ED1401 ABB
ED1411 ABB
ED1430 ABB
ED1611 ABB
ED1613 ABB
ED1629 ABB
ED1633 ABB
ED1638 ABB
ED1709 ABB
ED1715 ABB
ED1780 ABB
ED1781 ABB
ED1790 ABB
ED1803 ABB
ED1804 ABB
ED1806 ABB
ED1810 ABB
ED1817 ABB
ED1822 ABB
ED1832 ABB
ED1833 ABB
ED1867 ABB
EG1601CK ABB
EG3151CK ABB
EG6302CK ABB
EG900CK ABB
EH110ARCCHUTE TRANSFORMER TOP ABB
EH210C1 AC Contactors ABB
EH260 ABB
EH260C1 AC Contactors ABB
EH300C1 AC Contactors ABB
EH450C1 AC Contactors ABB
EH550C1 ABB
EH700C1 AC Contactors ABB
EH800C1 AC Contactors ABB
EHCK1003 ABB
EHCK1453 ABB
EHCK1503 ABB
EHCK1603 ABB
EHCK1703 ABB
EHCK1753 ABB
EHCK2103 ABB
EHCK2503 ABB
EHCK2603 ABB
EHCK2703 ABB
EHCK2803 ABB
EHCK3003 ABB
EHCK3703 ABB
EHCK4503 ABB
EHCK503 ABB
EHCK5503 ABB
EHCK603 ABB
EHCK7003 ABB
EHCK753 ABB
EHCK8003 ABB
EHCK803 ABB
EHCK903 ABB
EHDB110C1L AC Contactors ABB
EHDB110C2P1L AC Contactors ABB
EHDB130C2P1L AC Contactors ABB
EHDB220C1L AC Contactors ABB
EHDB220C2P1L AC Contactors ABB
EHDB280C2P1L AC Contactors ABB
EHDB280CL1 AC Contactors ABB
EHDB360C1L AC Contactors ABB
EHDB360C2P1L AC Contactors ABB
EHDB520C1L AC Contactors ABB
EHDB520C2P1L AC Contactors ABB
EHDB650C2P1L AC Contactors ABB
EHDB650CL1 AC Contactors ABB
EHDB75C1L AC Contactors ABB
EHDB75C2P1L AC Contactors ABB
EHDB800C2P1L AC Contactors ABB
EHDB800CL1 AC Contactors ABB
EHDB960C1L AC Contactors ABB
EHDB960C2P1L AC Contactors ABB
EHTK080 NLA ABB
EHTK170 TERMINAL KIT,#6-250MCM ABB
ES1836 ABB
ET100 ABB
ET145 ABB
ET150 ABB
ET210 ABB
ET250 ABB
ET300 ABB
ET370 ABB
ET450 ABB
ET550 ABB
ET700 ABB
ET80 ABB
ET800 ABB
ET90 ABB
EXC344274 POT 04 MSR-syst. Keyboard ABB
EXC344277 POT 25 keyboard ABB
EXC344508 Power supply ABB
EXC368208 PBC 02 bus control unit ABB
EXC368302 Power supply ABB
EXC368305 Power supply ABB
EXC368306 Power supply ABB
EXC368307 Power supply ABB
EXC368308 Power supply ABB
EXC3BDH000002R1 PM 802F processor module basic unit CSA ABB
EXC3BDH000011R1 SA 801F Netzteil 115/230 V AC ABB
EXC3BDH000015R1 EI 801F Ethernet Modul 10Base2 ABB
EXC3BDH000017R1 Ethernet Interface Module Twisted pair ABB
EXC52614775 EE-MEMORY BOARD ABB
EXC53316981 X AMPLIFIER ABB
EXC53317626 DIESELAUTOMATIC CONTR.BOARD ABB
EXC53360131 INTERFACE CARD ABB
EXC53410448 REF. VALUE SOURCE ABB
EXC53410570 3 POINT CONTROL ABB
EXC53410618 VOLTAGE CONTROL ABB
EXC53410634 COMPARATOR ABB
EXC53410774 REGUL.AMPLIFIER ABB
EXC53410804 CURRENT REGULATION AMPLIFIER ABB
EXC53411754 SUM ABB
EXC53585264 PULSE INHIBITION CARD ABB
EXC56536043 POWER SUPPLY ABB
EXC56538054 BATTERY AND BUS TERMINAT. CARD ABB
EXC57086785 DI-BOARD WITH MEMORY ABB
EXC57086939 ANALOG ISOLATION BOARD ABB
EXC57088427 MEMORY BOARD ABB
EXC57088435 MEMORY BOARD ABB
EXC57088508 MEMORY BOARD ABB
EXC57088575 COMMUNICATION CONTROL ABB
EXC57088613 MEMORY BOARD ABB
EXC57088672 VIDEO CONTROLLER ABB
EXC57122374 AMPLIFIER BOARD ABB
EXC57124351 SERIAL I/O CARD ABB
EXC57127881 CHANNEL CARD ABB
EXC57128976 CONTROL BOARD ABB
EXC57129000 SAWTOOTH GEN.BOARD ABB
EXC57129051 PROTECTION CARD ABB
EXC57137541 MEMORY BOARD ABB
EXC57146443 MATCHING BOARD ABB
EXC57158131 SHARED MEMORY INTER ABB
EXC57167432 POWER SUPPLY ABB
EXC57177209 TRANSDUCER CARD ABB
EXC57198346 BUS TERMINATOR CARD ABB
EXC57253444 POVER SUPPLY ABB
EXC57254122 DEVICE CONTROLLER ABB
EXC57254807 DIGITAL OUTPUT BOARD ABB
EXC57273682 ARITHMETIC CIRCUIT ABB
EXC57275677 COMMUNICATION CONTROL ABB
EXC57275707 IO TRANSMITTER/RECEIVER BOARD ABB
EXC57275758 DIGITAL OUTPUT BOARD ABB
EXC57275782 DIGITAL INPUT CARD ABB
EXC57275812 ANALOG INTERFACE BOARD ABB
EXC57275871 UNIVERSAL COUNTER BOARD ABB
EXC57287080 TERMINAL BOARD ABB
EXC57288248 CONTROL BOARD ABB
EXC57288493 D-CONNECTOR BOARD ABB
EXC57288965 TERMINAL BOARD ABB
EXC57289058 TERMINAL BLOCK BOARD ABB
EXC57289091 THERMOCOUPLE BOARD ABB
EXC57357061 RELAY BOARD ABB
EXC57409746 PULSE AMPLIFIER UNIT ABB
EXC57418150 DC BRIDGE POS. UNIT ABB
EXC57521465 PHASE AND FREQUE ABB
EXC57538821 LINE FILTER UNIT ABB
EXC57557109 FILTERING BOARD ABB
EXC57574712 RWM-MEMORY CARD ABB
EXC57574895 PT100-TRANDUCER CARD ABB
EXC57584262 PULSE AMPLIFIER ABB
EXC57587385 OUTPUT STAGE ABB
EXC57591927 THYRISTOR BRIDGE ABB
EXC57592231 THYRISTOR BRIDGE ABB
EXC57599821 INTERRUPT DIGITAL INPUT C ABB
EXC57769963 DISPLAY UNIT ABB
EXC57770571 DISPLAY UNIT ABB
EXC57770732 RELAY BOARD ABB
EXC57771593 PULSE FREQUENCY DIVIDER BOARD ABB
EXC57771810 CARD FRAME ABB
EXC57772280 SHARED MEMORY INTERF ABB
EXC57779039 VIDEO CONTROLLER BOARD ABB
EXC57782633 DR 16 ABB
EXC58031844 MEMORY BOARD ABB
EXC58032751 POWER SUPPLY ABB
EXC58032808 POWER SUPPLY ABB
EXC58038032 EARTH FAULT SUPERVISION BOARD ABB
EXC58038750 RELAY UNIT ABB
EXC58113972 TERMINAL BLOCK BOARD ABB
EXC58114791 CONTROL BOARD ABB
EXC58171662 CENTRAL PROCESSOR BOARD ABB
EXC58171671 CENTRAL PROCESSOR BOARD ABB
  • 电话:020-87268766
  • 传真:020-87269099
  • email:gzlaijie@163.com
