- 数量:10
- 有效期:2027/4/24 0:00:00
郑州高恩供应Q系列PLC
QX10 100-120VAC/7-8mA, 16pt 1,680.00
QX28 240VAC, 8pt 1,120.00
QX40 240VAC/4mA, POSITIVE COMMON INPUT, 16pt 1,600.00
QX40-S1 24VDC, POSITIVE COMMON INPUT, 16pt (HIGH SPEED) 1,680.00
QX41 24VDC, POSITIVE COMMON INPUT, 32pt 2,780.00
QX41-S1 24VDC, POSITIVE COMMON HIGH-SPEED INPUT, 32pt 2,780.00
QX42 24VDC, POSITIVE COMMON INPUT, 64pt 4,460.00
QX42-S1 24VDC, POSITIVE COMMON HIGH-SPEED INPUT, 64pt 4,460.00
QX48Y57 24VDC POSITIVE COMMON INPUT, 8pt, OUTPUT: 7pt 1,680.00a
QX70 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 16pt 2,250.00
QX71 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 32pt 3,030.00
QX72 5-12VDC INPUT, POSITIVE AND NEGATIVE COMMON INPUT, 64pt 4,720.00
QX80 24VDC/4mA. NEGATIVE COMMON INPUT, 16pt, TERMINAL BLOCK 2,020.00
QX81 24VDC/4mA. NEGATIVE COMMON INPUT, 16pt, CONNECTOR 3,450.00
QY10 240VAC/24VAC, 16pt, WITHOUT FUSE 2,190.00
QY18A 240VAC/24VAC, 2A, 8 INDEPENDENT OUTPUT 2,030.00
QY22 240VAC/0.6A, 16pt, WITHOUT FUSE 2,700.00
QY40P 12/24VDC, 16pt, WITH SHORT-CIRCUIT PROTECTION 1,600.00
QY41P 12/24VDC, 32pt, WITH SHORT-CIRCUIT PROTECTION 2,780.00
QY42P 12/24VDC, 64pt, WITH SHORT-CIRCUIT PROTECTION 4,460.00
QY50 12/24VDC, 16pt, WITH FUSE 1,680.00
QY68A 5-24VDC, 8pt, WITHOUT FUSE 2,360.00
QY70 5/12VDC, 16pt, WITHOUT FUSE 2,150.00
QY71 5/12VDC, 32pt, WITHOUT FUSE 2,780.00
QY80 12/24VDC, 16pt, WITHOUT FUSE 2,190.00
QY81P 12/24VDC, 32pt, WITH SHORT-CIRCUIT PROTECTION 3,790.00
Q2MEM-BAT REPLACEMENT BATTERY, FOR Q2MEM-1MBS 220.00
Q312B POWER SUPPLY + CPU + 12 SLOTS FOR Q SERIES I/O, CE/UL/cUL 2,370.00
Q33B POWER SUPPLY + CPU + 3 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,250.00
Q35B POWER SUPPLY + CPU + 5 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,310.00
Q38B POWER SUPPLY + CPU + 8 SLOTS FOR Q SERIES I/O, CE/UL/cUL 1,870.00
Q3ACPU 2048PT., 92K STEP, 0.15μS/STEP 36,270.00
Q4ACPU 4096PT., 124K STEP, 0.075 μS/STEP 41,560.00
Q4ARCPU 4096PT., 124K STEP, 0.075 μS/STEP, HOTSTANDBY 46,220.00
Q52B 2 I/O SLOTS, FOR Q SERIES MODULE (NO NEED POWER SUPPLY) 1,120.00
Q55B 5 I/O SLOTS, FOR Q SERIES MODULE (NO NEED POWER SUPPLY) 1,310.00
Q612B POWER SUPPLY + 12 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 2,500.00
Q61P-A1 100-120VAC INPUT/5VDC 6A OUTPUT, CE/UL/cUL 1,710.00
Q61P-A2 200-240VAC INPUT/5VDC 6A OUTPUT, CE/UL/cUL 1,710.00
Q62AD-DGH 2 CHANNELS, A/D CONVERSION, SIGNAL CONDITIONING FUNCTION 4,210.00
Q62DA 2 CHANNELS, D/A CONVERSION: VOLTAGE/CURRENT OUTPUT 4,210.00
Q62DA-FG 2 CHANNELS, D/A CONVERSION: V/I OUTPUT WITH MONITOR 5,620.00
Q62P 100-240VAC INPUT/5VDC 3A, 24VDC/0.6A OUTPUT 1,970.00
Q63B POWER SUPPLY + 3 I/O SLOTS, FOR Q SERIES MODULE, CE/UL/cUL 1,380.00
Q63P 24VDC INPUT/5VDC 6A OUTPUT 3,000.00
Q64AD 4 CHANNELS, A/D CONVERSION: VOLTAGE/CURRENT INPUT 4,210.00
- 电话:0371-63897587
- 传真:0371-63897587
- email:weiyanbo1@126.com
Q系列PLC
