- 数量:10
- 有效期:2027/4/24 0:00:00
郑州高恩供应三菱A系列可编程控制器(PLC)
128KWROM 128K 内存用于 AD51H, AD57G 1,600.00
16KHROM 16K 步 EP-ROM 内存用于 AD57(S1/S2), AD58 2,030.00
16KQROM EP-ROM MEMORY+B213 2,030.00
16KRAM 16K STEP RAM 2,180.00
16KROM 16K STEP EP-ROM 2,030.00
256KWROM 256K 内存用于 AD51H, AD57G 2,010.00
4KEROM EP-ROM MEMORY 1,350.00
4KRAM 4K STEP MEMORY (A1N, A3NMCA-0) 1,080.00
4KROM 4K STEP EP-ROM (A1N, A3NMCA-0) 810.00
64KWROM 56K BYTE MEMORY FOR AD51H, AD57G 1,210.00
8KROM 8K STEP EP-ROM 1,350.00
A0J2HCPU 8K STEPS, 480 I/O, 1.25uS/STEP 5,100.00
A11VC VOICE OUTPUT MODULE 14,160.00
A1NCPU 6KSTEPS, 256 I/O 11,330.00
A1NCPUP21 A1NCPU WITH MELSECNET II OPTICAL DATA LINK 22,250.00
A1NCPUR21 A1NCPU WITH MELSECNET II COAXIAL DATA LINK 22,250.00
A1S32B BASE UNIT: CPU, 2 I/O & POWER SUPPLY SLOTS 1,000.00
A1S33B BASE UNIT: CPU, 3 I/O & POWER SUPPLY SLOTS 1,080.00
A1S35B BASE UNIT: CPU, 5 I/O & POWER SUPPLY SLOTS 1,100.00
A1S38B BASE UNIT: CPU, 8 I/O & POWER SUPPLY SLOTS 1,660.00
A1S38HB QnAS BASE UNIT, 8 I/O, HIGH SPEED ACCESS TIME 2,510.00
A1S42X 64 PT. DYNAMIC INPUT 3,050.00
A1S52B-S1 EXTENSION UNIT : 2 I/O SLOTS 950.00
A1S55B-S1 EXTENSION UNIT : 5 I/O SLOTS 1,060.00
A1S58B-S1 EXTENSION UNIT : 8 I/O SLOTS 1,560.00
A1S61PN INPUT : AC 100 - 240VAC OUTPUT : DC 5V 8A 1,560.00
A1S62DA D/A CONVERTER : 2 CH., 4-20mA,-10V-+10V 4,990.00
A1S62PN INPUT : AC 100 - 220VAC OUTPUT : DC 5V 5A, DC 24V 0.8A 1,790.00
A1S62RD3N TEMPERATURE SENSOR : PT-100, 3 WIRES 5,940.00
A1S62RD4N TEMPERATURE SENSOR : PT-100, 4 WIRES 5,940.00
A1S63ADA A/D, D/A CONVERTER : 2 INPUT/1 OUTPUT, 4-20mA,-10V-+10V 4,690.00
A1S63P INPUT : DC 24V OUTPUT : DC 5V 8A 2,710.00
A1S64AD A/D CONVERTER : 4 CH., 4-20mA,-10V-+10V 4,240.00
A1S64TCRTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00
A1S64TCRT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00
A1S64TCTTBW-S1 3-WIRE PT-100 I/P, TRANSISTOR O/P, 4 CHANNELS 10,430.00
A1S64TCTT-S1 THERMOCOUPLE R,K,J,T,I/P,TRANSISTOR O/P, 4 CHANNEL 8,020.00
A1S65B-S1 EXTENSION UNIT : 5 I/O, POWER SUPPLY SLOTS 1,170.00
A1S66ADA A/D, D/A CONVERTER : 4 INPUT/2 OUTPUT, 4-20mA,-10V-+10V 8,160.00
A1S68AD A/D CONVERTER : 8 CH., 0-20mA,-10V-+10V 6,480.00
A1S68B-S1 EXTENSION UNIT : 8 I/O, POWER SUPPLY SLOTS 1,720.00
A1S68DAI D/A CONVERTER UNIT : 8 CH., 4-20mA 8,430.00
A1S68DAV D/A CONVERTER UNIT : 8 CH., -10V-+10V 8,430.00
A1S68TD THERMOCOUPLE INPUT : 8 CH., B, R, S, E, J, K TYPE 12,110.00
A1SC01B 55 mm EXTENSION CABLE 360.00
A1SC03B 300 mm EXTENSION CABLE 420.00
A1SC05NB 450 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 660.00
A1SC07B 0.7M BUS CONNECTION (AnS/QnAS CPU) 590.00
A1SC07NB 700 mm CABLE CONNECTS TO AnN EXTENSION BASE & GOT 780.00
A1SC12B 1.2M BUS CONNECTION (AnS/QnAS CPU ) 850.00
A1SC30B 3M BUS CONNECTION (AnS/QnAS CPU) 1,350.00
A1SC30NB 3 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 1,980.00
A1SC50B 5M BUS CONNECTION (AnS/QnAS CPU) 1,990.00
A1SC50NB 5 M CABLE CONNECTS TO AnN EXTENSION BASE & GOT 2,650.00
A1SC60B 6 M EXTENSION CABLE 2,140.00
A1SCPUC24-R2 CPU, BUILT IN 8KSTEPS RAM, MAX. I/O 256, RS232 PORT 7,730.00
A1SD51S RS232C 2 CH., RS422/484 1 CH. 9,190.00
A1SD61 HIGH SPEED COUNTER, 1 CH., 50KPPS 6,210.00
A1SD62 HIGH SPEED COUNTER, 2 CH., 100KPPS, SINK 6,380.00
A1SD62D HIGH SPEED COUNTER, 2 CH., 200KPPS, SINK 6,830.00
A1SD62E HIGH SPEED COUNTER, 2 CH., 100KPPS, SOURCE 6,380.00
A1SD70 1 AXES, VOLTAGE OUTPUT 7,820.00
A1SD71-S2 2 AXIS, PULSE TRAIN, OUTPUT, SPEED CONTROL FUNCTION 13,980.00
A1SD71-S6 2 AXIS, PULSE TRAIN OUTPUT 14,530.00
A1SD71-S7 2 AXIS, PULSE TRAIN OUTPUT, MANUAL PULSAR INPUT 13,980.00
A1SD75-C01H CONNECTION CABLE BETWEEN A1SD75 & AD75TU 880.00
A1SD75M1 SSC NET, 1ASIS 6,830.00
A1SD75M2 SSC NET, 2ASIS 10,430.00
- 电话:0371-63897587
- 传真:0371-63897587
- email:weiyanbo1@126.com
三菱A系列可编程控制器(PLC)
