当前页面: 首页 >供求信息 >MACX MCR-UI-UI-UP-NC菲尼克斯隔离放大器特价
供稿:boyi1010 2014/1/24 9:06:18
人气:46
  • 型号:MACX MCR-UI-UI-UP-NC
  • 数量:200
  • 制造商:菲尼克斯
  • 有效期:2027/4/24 0:00:00
隔离放大器,带安全电气隔离和宽域电源输入(24 V ... 230 V AC/DC)。 前置DIP开关;可设置超过1600种信号转换功能。 标准组态(IN 0 ... 10 V/OUT 0 ... 20 mA),螺钉接线,SIL
上海博谊自控电气设备有限公司
传真:021-66100663
联系人:陈一非     手机:13817898648
RIF-0-BPT/1
FLM DI 16 M12
PLC-OSP-24DC/24DC/2/ACT
PSI-MOS-PROFIB/FO1300 T
ST-REL7-HG 48/4X2
MCR-SL-D-FIT
PSR-SCP-230UC/ESAM4/3X1/1X2/B
PLC-OSC-5DC/24DC/2/ACT
TP 5150T   触摸面板
DEK-OE-24DC/24DC/100KHZ-G
RFC 430 ETH-IB
PLC-RSC-12DC/21
PR1-BSC2/2X21
SUBCON-PLUS-PROFIB/SC2
MACX MCR-SL-RPSSI-2I
ELR W3-24DC/500AC-2I
EMG 12-B2
PLC-OSP-24DC/48DC/100
ILC 150 ETH
FLK50/EZ-DR/50/KONFEK
MACX MCR-UI-UI-UP
EMG 45-ELR3/1,5
PR1-RSC3-LDP-24DC/2X21
REL-MR-230AC/21-21
PSM-V24/TTY-P/AK/BB
RAD-IN-4A-I
RAD-OUT-4A-I
RAD-IN-8D
RAD-OUT-8D-REL
RAD-ISM-2400-SET-UD-ANT
MACX MCR-SL-RPSSI-I
PSI-MOS-PROFIB/FO 850 E-SO
PSI-MOS-PROFIB/FO 850 T-SO
SD-D/SP/LA
EMG 90-DIO 32P
EMG 90-DIO 32M/LP
EMG 90-DIO 32M
MCR-S-1-5-UI-SW-DCI-NC
EMG 22-REL/KSR- 24/21-21AU
MACX MCR-SL-RPSSI-I-SP
MACX MCR-SL-TC-I-NC
MCR-S-10-50-UI-SW-DCI
PLC-OSC-230UC/ 24DC/ 2
EMG17-REL/KSR-W230/21-21-LC
MACX MCR-EX-SL-IDSI-I
PSR-SPP- 24-230UC/ESAM4/3X1/1X2
PSR-SCP-24DC/ESD/5X1/1X2/T1
SUBCON-PLUS-CAN
PSR-SCP-24-230UC/ESAM4/3X1/1X2
MCR-DAC 8/I- 4/BUS
MCR-DAC 8-U-10-BUS
OPT-5DC/24DC/2
PSM-SET-B-FOC/4-HCS
MCR-2SP-UI-DC
MINI MCR-SL-U-U
PLC-RSC-120UC/21-21
ST-REL7-HG 24/4X21
MCR-SL-PT100-U-DC-24
PLC-OSC-24DC/24DC/2ACT
MCR-C-I-U- 0-DC
REL-IR/L- 24AC/4X21 AU
REL-IR/LDP-24DC/4X21AU
PR2-BSC2/4X21
REL-IR/L-230AC/4X21 AU
PLC-RSC-24DC/1AU/SEN
ST-OV2- 24DC/ 24DC/5
PSI-REP-DNET CAN
PSI-MOS-DNET/FO 850 E
EMG 10-REL/KSR-G 24/21-LCU
MCR-SL-S-16-SP-24
ELR H5-SC- 24DC/500AC-9
ELR H3-SC- 24DC/500AC-9
MCR-FL-D-U-I-2SP- 24
FLKM 50/S7/A-S400
PLC-BSP-230UC/21/SO46
FLKM 20
SKBI 64/C64
SKBI 128-C64/C64
UK 5-TWIN
UM 25-D15SUB/B/FRONT/Q
UM 25-D 9SUB/B/FRONT/Q
VIP-3/SC/D25SUB/M
VIP-3/SC/D50SUB/M
EB 80- DIK BU
EB 80- DIK RD
DIKD 1,
MACX MCR-S-MUX
MACX MCR-S-MUX-TB
PLC-RPT-24DC/21-21
MINI MCR-SL-TB
MINI MCR-SL-MUX-V8-FLK 16
VIP-CAB-FLK16/FR/OE/0,14/0,5M
ELR W3- 24DC/500AC- 9I
UM72-R-230UC/21-21/S046
PSI-MOS-DNET CAN/FO 660/EM
MCR-SL-D-SPA-UI
MCR-FL-HT-T-I
PSR-SPP- 24DC/URD3/4X1/2X2
MACX MCR-UI-UI-UP-SP
MACX MCR-UI-UI-SP-NC
EMG 10-0E-5VDC/24VDC/100
MINI MCR-BL-PT100-I-NC
PSR-SPP-24UC/ESA4/2X1/1X2
ST-OE2-24DC/48DC/100
PSR-SPP-24DC/TS/S
PSR-TRISAFE STARTER KIT
UM72-R-24DC/4*21
EMG 17-REL/KSR-24/21-21-LC AU
OPT-24DC/24DC/5
FLKM 50-PA-AB/OBN
FLK 50/EZ-DR/200/KONFEK/S
UM72-R-230UC/4*21/SO46
PSM-EG-RS232/LWL-K
UEGM 22,5
UM 45-FLK14
PSI-MOS-RS232/FO 660 E
MINI MCR-SL-I-I-SP
MINI MCR-SL-RPS-I-I-SP
FL MGUARD RS2000 TX/TX VPN
TMCP 1 M1 300 5,0A
PSR-SPP-24DC/ESP4/2X1/1X2
EEM-MA600
PLC-RSC-230UC/21HC
REL-MR-24DC/1IC
EEM-MA400
EEM-RS485-MA400
PLC-BSC-230UC/1/SEN
CM-KBL-RS232/USB
PLC-BSC-24DC/1/SEN
PLC-RSC-230UC/1AU/SEN
MACX MCR-SL-CAC-5-I
PSR-SCP-24UC/URM4/5X1/2X2
ST-RELT-HG220/4*21
UDK-RELG7
PLC-RSC-120UC/21-21
EMG45-DIO-8E
ST-REL7-HG24/4*21
REL-IR/LDPP-24DC/4*21AU
SACB-8/16-L-CGG
ST-REL2-KG 24/1
UDK-RELG 2 底座
PLC-BSP-24DC/21
MINI MCR-SL-UI-UI-NC
MINI MCR-SL-UI-2I-SP-NC
PI-EX-RPSS-I/I
PI-EX-ME-RPSS-I/I
PLC-RSC-230UC/21-21AU
PLC-RSC-24DC/21-21AU
PSR-SCP- 24DC/ESD/5X1/1X2/ T30
UM 45-FLK50/32IM/ZFKDS/PLC
PSR-SCP-24UC/ESAM4/8X1/1X2
MCR-S-10-50-UI-DCI
UMK-16 OM/AMSC/E/PLC
FLK 50/4X14/EZ-DR/ 300/KONFEK
FLK 50/4X14/EZ-DR/ 400/KONFEK
FLK 50/4X14/EZ-DR/ 600/KONFEK
FLK 50/EZ-DR/ 600/KONFEK
PSR-SPP- 24DC/ESD/5X1/1X2/ T 5
UM 72-R-24DC/21-21
SAC-4P-M 8MS/1,5-PUR 16
SAC-4P-M 8MS/ 0,3-PUR
SACC-M8MS-3CON-M
SACB-8/3-L-5.OPUR-M8
SACC-M12MS-5SC
HC-A 16-ESTS
HC-D 25-TFL-72/O1STM20S
MCR-SWS-I
MCR-SL-1CLP-I-I-00-4KV
MCR-PS-24DC/2X24DC
DEK-OE-24DC/48DC/100
PSI-MOS-RS422/FO 850 E
MINI MCR-BL-I-I
PLC-OSC-24DC/48DC/100
PSM-LWL-GDO- 50/125
FL CAT5 FLEX
UMK- 8 OM-R/MF/MKDS/P
UMK-16 OM-R/MF/MKDS/P
PSR-SPP- 24UC/ESAM4/2X1/1X2
VS-M12MSD-RJ45-931/ 2,0
FLM AI 4 SF M12
FLM AO 4 SF M12
MCR-T-UI
MINI MCR-SL-TC-UI
MINI MCR-SL-RPSS-I-I
PLC-OSP-230UC/ 24DC/ 2
MCR-C-U-I-4-DC
MINI MCR-SL-TC-UI-NC
EMG 90-2SD-D/LA
NEF 1-10
FLKM 50/32M/PLC
PR2-RSC3-LV-230AC/2X21
PR2-RSC3-LV-230AC/4X21AU
MCR-SL-HT-PT 100-I
PLC-OSC- 24DC/230AC/1
MCR-FL-UI-UI-B-DCI-24/230
MINI MCR-SL-R-UI
UM- 2 FLK50/4FLK20//LA/SO46
EMD-FL-3V-400
EMG 17-OV-TTL/ 24DC/2
FLKM 14-PA-S300
PSM-KAD 9 SUB 25/BS
MINI MCR-SL-UI-UI
MCR-C-UI-UI-450-DCI
MCR-S-1-5-UI-SW-DCI
MCR-SL-CUC-100-I
MINI MCR-BL-U-I-4
MINI MCR-BL-RPS-I-I
PLC-BSP-230UC/21
UM-32 RM/RT-G24/21/PLC
PLC-OSC-24DC/300DC/1
DFLK-D37 SUB/B
PSR-SCP-24UC/ESL4/3X1/1X2/B
UMK- 8 RM/MR-G24/ 1/PLC
UMK- 8 RM/MR-G24/ 1/HF/PLC
EMD-FL-C-10
ZFK-RELG 2
PLC-V8L/FLK14/OUT
UM 72-SEFE/R
UM 72-SEFE/L
UM 72-PROFIL 200CM
MCR-SPP-I-4
MCR-PT100-U-DC
  • 电话:021-66100983
  • 传真:021-66100663
  • email:boyi1010@126.com
