- 型号:76666-2
- 数量:200
- 制造商:美国VARCO
- 有效期:2027/4/24 0:00:00
联系人:王先生
联系手机:13646905585
QQ:525496709 以下部分产品型号:
VARCO华高 122627-57 BASE,ANALOG,SIEMENS S7 STK - 1 WK
VARCO华高 122627-58 BASE,DIGITAL,SIEMENS S7 STK - 1 WK
VARCO华高 127908-J2 SOLENOID,VALVE,3-POS 24 VDC STK - 1 WK
VARCO华高 122627-45 REMOTE-I/O,4PT,ANALOG STK - 1 WK
VARCO华高 122627-46 REMOTE-I/O,DIGITAL,24IN/8OUT STK - 1 WK
VARCO华高 122627-47 REMOTE-I/O,4ANALOG STK - 1 WK
VARCO华高 81736-2 POTENTIOMETER,2W,10K STK - 1 WK
VARCO华高 115299 ENCODER,DIGITAL STK - 1 WK
VARCO华高 120357 ENCODER,BELT-DRIVE,RETROFIT,KIT,TDS9S STK - 1 WK
VARCO华高 30183959-200-25-8-B CABLE ASSY SERVICE LOOP 18 COND. STK - 1 WK
VARCO华高 122517-200-25-6.5-B LOOP, SERVICE, COMPOSITE, TDS10 STK - 1 WK
VARCO华高 127908-D2 SOLENOID VALVE,D03,UL STK - 1 WK
VARCO华高 30087708-02 PUSHBUTTON,FLUSH LR/BLKDC STK - 1 WK
VARCO华高 30173216-1 ELEMENT,FILTER,HYD STOCK
VARCO华高 30111013-KIT KIT, FILTER, GEAR-OIL (FILTER AND O-RING) STOCK
VARCO华高 51300-153-B O-RING STK - 1 WK
VARCO华高 30158767-04 BEARING, CAM FOLLOWER STOCK
VARCO华高 30155438 CAM,FOLLOWER 6' STOCK
VARCO华高 16401-2 PYRAMID,TONG,DIE(TYPE'C'ROTARY-TONG) STOCK
VARCO华高 71847 CAM FOLLOWER STOCK
VARCO华高 109528-1 FRICTION PAD (REPLACEMENT) STOCK
VARCO华高 30119319 RING,GLYD,11.0DIA-ROD QTY. 2 STK - 1 WK; 6 WKS
VARCO华高 119547 SEAL,WIPER,11.0DIA-ROD STK - 1 WK
VARCO华高 INVALID
VARCO华高 112929 CLAMP,CYLINDER,BODY,MACH,PH50 (MTO) 17 WKS
VARCO华高 72220 SEAL ROD STK - 1 WK
VARCO华高 72221 WIPER, ROD STK - 1 WK
VARCO华高 11075 HEAD,ACTUATOR,10DIA STK - 1 WK
VARCO华高 11085 RING,HEAD,CYLINDER STK - 1 WK
VARCO华高 110083 SPRING,COMPRESSION STK - 1 WK
VARCO华高 110186 CYLINDER,ACTUATOR,IBOP ASSY TDS9S STK - 1 WK
VARCO华高 110103-500 UPPER IBOP, PH50 ASSY, 6-5/8 X 6-5/8, C/W CERT 1 WK
VARCO华高 114706-500 ASSY,LWR IBOP,65/8X65/8W/REL GRV-STD, C/W CERT 1 WK
VARCO华高 56519-12-12S ELBOW, O-RING BOXX/37 DEG (PLEASE VERIFY PART NUMBER BEFORE PURCHASING) STK - 1 WK
VARCO华高 59143P290122 HOSE,ASSY STK - 1 WK
VARCO华高 59124P290129 HOSE,ASSY STK - 1 WK
VARCO华高 59144P290135 HOSE,ASSY STK - 1 WK
VARCO华高 INVALID
VARCO华高 货期
VARCO华高 110042 SHELL,ACTUATOR (PH50) STK - 1 WK
VARCO华高 98897+30 HOUSING,CRANK STK - 1 WK
VARCO华高 107052 WASHER, LOCK, TAB, .56 DIA STOCK
VARCO华高 50008-14-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 99168+30 SPACER,SLEEVE,.88ODx.636IDx.250THK 2 WKS
VARCO华高 53201+50 FTG, GREASE, 1/8'NPT STK - 1 WK
VARCO华高 30115757 SCREW,CAP-HEX(METRIC),TDS9S STK - 1 WK
VARCO华高 30123562 RING,SNAP,3'WASH-PIPE,TDS STOCK
VARCO华高 30123288 RING,HOLDING,WASH-PIPE,TDS STOCK
VARCO华高 123284 NUT,3'WASH-PIPE STK - 1 WK
VARCO华高 30123563 ASSY,BOX-PACKING,3'WASH-PIPE,TDS STK - 1 WK
VARCO华高 53219-1 FITTING, GREASE STRAIGHT STOCK
VARCO华高 30123564 SCREW,CAP,SOCKET-HEAD,DOG-NOSE,WASHPIPE STK - 1 WK
VARCO华高 123585 BRACKET,MOUNTING,FILTER STK - 1 WK
VARCO华高 30123286 SPACER,MIDDLE,3'WASH-PIPE,TDS STOCK
VARCO华高 INVALID
VARCO华高 105599 IDS SEAL V-RING STK - 1 WK
VARCO华高 109555 (MT)ROTOR,BRAKE STK - 1 WK
VARCO华高 117783 PIN,RETAINER,.5DIAX7.0 STK - 1 WK
VARCO华高 117782 PIN,JOINT,2.0DIAX12.5,MS28 STK - 1 WK
VARCO华高 95523 SHACKLE,ANCHOR,25-TON*SCD* STK - 1 WK
VARCO华高 INVALID
VARCO华高 120117-3 BELT,TIMING,ENCODER,TDS9 STK - 1 WK
VARCO华高 122247-1 (MT)TUBE,HEAT-EXCHANGER,ASSY,TDS9 STK - 1 WK
VARCO华高 110173 TUBE,ASSY,BRAKE STK - 1 WK
VARCO华高 91250-1 (MT)OIL SEAL(VITON),,TDS STOCK
VARCO华高 98291+30 SEAL,POLYPAK,3.875,,TDS STK - 1 WK
VARCO华高 30154362 SHIELD, BEARING,SMALL BORE, TDS 4S STOCK
VARCO华高 118378 RETAINER,LANDING,COLLAR STK - 1 WK
VARCO华高 98290 LINER,STEM,UPPER STK - 1 WK
VARCO华高 8550-5093 GAUGE,TORQUE,7.5/8' HK20000 12 WKS
VARCO华高 8532-5077-20 HYD. MOTOR KIT, M4D1-088-3N00-B102 14 WKS
VARCO华高 107865-16 PDM HPU STRAINER,SUMP 1.0 7 WKS
VARCO华高 30113165 VALVE,RELIEF,.750NPT. STK - 1 WK
VARCO华高 56506-16-16S ELBOW, 90DEG EXT/37 STK - 1 WK
VARCO华高 56502-2-4-S ELBOW, 45DEG EXT PIPE/37 STK - 1 WK
VARCO华高 56506-8-6-S ELBOW, 90DEG EXT PIPE/37 STK - 1 WK
VARCO华高 56506-12-12S ELBOW, 90DEG EXT/37 STK - 1 WK
VARCO华高 52212-B ELBOW, 90DEG COMMON STK - 1 WK
VARCO华高 56506-6-4-S ELBOW, 90DEG EXT PIPE/37 STK - 1 WK
VARCO华高 50004-10-SD SCREW, CAP-HEX HD (UNC-2A) 3 WKS
VARCO华高 50008-12-SD SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50004-5-SD SCREW, CAP-HEX HD (UNC-2A) STK - 1 WK
VARCO华高 50004-5-C5D SCREW, CAP-HEX HD (UNC-2A) STK - 1 WK
VARCO华高 50016-28-C5D SCREW, CAP-HEX HD DRILLED 5 WKS
VARCO华高 50012-22-C5D SCREW, CAP-HEX HD DRILLED TDS 1 WK
VARCO华高 50016-12-C5D SCREW, CAP-HEX HD STK - 1 WK
VARCO华高 50012-26-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50012-24-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50012-20-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50012-18-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50012-16-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50012-12-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50010-18-C5D SCREW, CAP-HEX HD DRILLED, PHMD-1 STK - 1 WK
VARCO华高 50010-10-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 53301-4-4-SS SCREW,DRIVE TYPE STK - 1 WK
VARCO华高 50069-022F08 SCREW CAP HEX HEAD-METRIC (MTO) 6 WKS
VARCO华高 50103-5-BD SCREW,CAP,SOCKET-HEAD STK - 1 WK
VARCO华高 50004-4-C5D SCREW, CAP-HEX HD DR 5 WKS
VARCO华高 50104-8-S SCREW,CAP,SOC-HD,(UNC) STK - 1 WK
VARCO华高 50006-20-C5D SCREW, CAP-HEX HD (UNC) 4 WKS
VARCO华高 50008-7-C5D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50008-12-C5D SCREW, CAP-HEX HD DRILLED 1 WK
VARCO华高 30172172 SCREW,CAP-HEX HEAD STK - 1 WK
VARCO华高 50903-C WASHER, LOCK-REGULAR, # 10 STK - 1 WK
VARCO华高 50904-C WASHER, LOCK-REGULAR 1/4 CAD STK - 1 WK
VARCO华高 50905-C WASHER, LOCK-REGULAR 1 WK
VARCO华高 50910-C WASHER, LOCK-REGULAR 1 WK
VARCO华高 50912-C WASHER, LOCK-REGULAR (ALT P/N: 025062) STK - 1 WK
VARCO华高 50916-C WASHER, LOCK-REGULAR STK - 1 WK
VARCO华高 50908-S WASHER, LOCK-REGULAR SS STK - 1 WK
VARCO华高 50904-S WASHER, LOCK-REG STAINLESS 3 WKS
VARCO华高 50104-8-C SCREW, CAP-SOC HD (UNC) STK - 1 WK
VARCO华高 50006-12-C5D SCREW, CAP-HEX HD DRILLED 1 WK
VARCO华高 50168-012F06 SCREW,SOCKET-HEAD,METRIC (MTO) 5 WKS
VARCO华高 50506-C NUT, HEX-SLTD (UNC-2B) STK - 1 WK
VARCO华高 110008 (MT)O-RING,.275x50.5 STK - 1 WK
VARCO华高 53912-B NIPPLE, CLOSE STK - 1 WK
VARCO华高 109591 (MT)SLEEVE,FLANGED,7.87ID,300SS STK - 1 WK
VARCO华高 30171921 VALVE W/REWORKED HANDLE, DIRECTIONAL CONTROL STK - 1 WK
VARCO华高 98402-800D VALVE,CONTROL,FLOW STK - 1 WK
VARCO华高 108216-12 PDM4 BALL VALVE 3/4-14 BRASS STK - 1 WK
VARCO华高 30124191-500 HOSE,ASSY,PRESSURE/MANIFOLD 71' STK - 1 WK
VARCO华高 121726 TUBE,ASSY,DRAIN/MANIFOLD STK - 1 WK
VARCO华高 121724 TUBE,ASSY,PRESSURE/MANIFOLD STK - 1 WK
VARCO华高 30117020 TUBE,ASSY,FILTER/MANIFOLD (MTO) 4 WKS
VARCO华高 114083 TUBE,ASSY,CASE-DRAIN STK - 1 WK
VARCO华高 59024P230030 HOSE ASSY STK - 1 WK
VARCO华高 INVALID # PART NUMBER IS INCOMPLETE
VARCO华高 93024-4SAE FITTING,SAE-4 1 WK
VARCO华高 93024-6SAE FITTING,SAE-6 STK - 1 WK
VARCO华高 99353-1AN TDS9S REDUCING VALVE CART,RED/REL STK - 1 WK
VARCO华高 M854000259 MFLD ASY,PREFILL VLVE**(REPLACES 111712) STK - 1 WK
VARCO华高 128694-6-031 FLOW CONTROL STK - 1 WK
VARCO华高 56519-4-4-S ELBOW, O-RING BOSS /37DEG STK - 1 WK
VARCO华高 56519-4-6-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56519-10-12S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56519-10-8-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56518-6-6-S ELBOW, 90/SWIVEL INT 37/37 STK - 1 WK
VARCO华高 30123290-PK KIT,SEAL, WASHPIPE PACKING, 7500 PSI STOCK
VARCO华高 30119592 ACTUATOR,ASSY STK - 1 WK
VARCO华高 128844+30 CHART,VARCO WASHPIPE ASSY GUIDE,LAMINATE STK - 1 WK
VARCO华高 72219 SEAL,PISTON STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 110548 TDS9S GLYD-RING,ROTARY PH STK - 1 WK
VARCO华高 120117 (MT)BELT,TIMING STK - 1 WK
VARCO华高 122247-2 (MT)TUBE,HEAT-EXCHANGER,ASSY,TDS9 STK - 1 WK
VARCO华高 110172 (MT)TUBE,ASSY,BRAKE STK - 1 WK
VARCO华高 117116 (MT)TUBE,BRAKE,ASSY,TDS9S 3 WKS
VARCO华高 30171956 TUBE ASSY,BRAKE STK - 1 WK
VARCO华高 30171957 TUBE ASSY,BRAKE STK - 1 WK
VARCO华高 71613 BREATHER,RESERVOIR STOCK
VARCO华高 INVALID PART NUMBER IS INCOMPLETE
VARCO华高 30173216 FILTER, HYD STK - 1 WK
VARCO华高 8502-5177 CAM FOLLOWER, CFH-1-3/8-B-1 (MTO) 8 WKS
VARCO华高 8547-5168 ,TORQUE INDICATOR HK20000 (MTO) 15 WKS
VARCO华高 INVALID NOT A VALID PART NUMBER
VARCO华高
VARCO华高 PART NUMBER DESCRIPTION LEAD TIME
VARCO华高 114869-PL-RED CONNECTOR,POWER,QD,PIN/INLINE,RED 2 W
VARCO华高 114869-SL-WHT CONNECTOR,POWER,QD,SOCKET/INLINE,WHITE 2 W
VARCO华高 INVALID #
VARCO华高 INVALID #
VARCO华高 114869-SF-RED CONNECTOR,POWER,QD,SCKT/FLNG,INLNE,RED STK - 1 WK
VARCO华高 114869-SF-BLK CONNECTOR,POWER,QD,SCKT/FLNG,INLNE,BLACK STK - 1 WK
VARCO华高 INVALID #
VARCO华高 114869-SF-WHT CONNECTOR,POWER,QD,SCKT/FLNG,INLNE,WHITE 6 W
VARCO华高 50008-12-C5 SCREW, CAP-HEX HD (UNC) STK - 1 WK
VARCO华高 50108-12-C SCREW, CAP-SOC HD (UNC) STK - 1 WK
VARCO华高 107052 WASHER, LOCK, TAB, .56 DIA STK - 1 WK
VARCO华高 30172154 PIN,CYLINDER MOUNTING, PH-50 STK - 1 WK
VARCO华高 50512-C NUT, HEX-SLTD, (UNC-2B) STK - 1 WK
VARCO华高 30119546 PIN,1.0DIAX3.8,MS15 STK - 1 WK
VARCO华高 119731 RETAINER,.25x.75x1.8,MS17 STK - 1 WK
VARCO华高 50004-8-C5D SCREW, CAP-HEX HD DR STK - 1 WK
VARCO华高 99168+30 SPACER,SLEEVE,.88ODx.636IDx.250THK STK - 1 WK
VARCO华高
VARCO华高 114869-PL-RED CONNECTOR,POWER,QD,PIN/INLINE,RED STK - 1 WK
VARCO华高 114869-SL-WHT CONNECTOR,POWER,QD,SOCKET/INLINE,WHITE STK - 1 WK
VARCO华高 114869-SF-WHT CONNECTOR,POWER,QD,SCKT/FLNG,INLNE,WHITE 1 W
联系人:王先生
联系手机:13646905585
VARCO华高 119731 RETAINER,.25x.75x1.8,MS17 3 W
VARCO华高 INVALID #
VARCO华高 INVALID #
VARCO华高
VARCO华高 35585 CYLINDER ASSY AIR . MGG-EL STK - 1 WK
VARCO华高 51402-8 PIN 1/8 X1, COTTER STK - 1 WK
VARCO华高 50008-22-C8D CAP SCREW STK - 1 WK
VARCO华高 50010-10-C8D CAP SCREW, HEX HEAD STK - 1 WK
VARCO华高 8150 BJ LINK BLOCK NUT STK - 1 WK
VARCO华高 35178 SPRING AIR STK - 1 WK
VARCO华高 59001008-3 CHAIN, STRAIGHT LINK 8 W
VARCO华高 51433-10 COTTER PIN STK - 1 WK
VARCO华高 50910-C WASHER, LOCK-REGULAR STK - 1 WK
VARCO华高 939099-96 LINK BLOCK BOLT STK - 1 WK
VARCO华高 70354 HINGE PIN SPACER AIR -EL 8 W
VARCO华高 50005-6-C8D CAP SCREW, HEX HEAD STK - 1 WK
VARCO华高 979385-1 QUICK RELEASE VALVE STK - 1 WK
VARCO华高 13188+50 LATCH LOCK SPRING, MGG-GG-RGG-HYC-ELEVAT STK - 1 WK
VARCO华高 944042-6 BJ HAIR PIN COTTER 2-3/8 STK - 1 WK
VARCO华高 51403-10 PIN, COTTER STK - 1 WK
VARCO华高 939643-9 WASHER, LOCK SHAKEPROOF STK - 1 WK
VARCO华高 939575-188 BJ SET SCREW 3 W
VARCO华高 18940 TRIGGER SPRING AIR . STK - 1 WK
VARCO华高 35175 SPRING AIR OPERATED ELEVATOR STK - 1 WK
VARCO华高 50906-C WASHER, LOCK-REGULAR STK - 1 WK
VARCO华高 50704-3-B-C SCREW,SET . TDS-3 STK - 1 WK
VARCO华高 INVALID #
VARCO华高 35526 SHIM AIR . (5 pcs req per elev. assy) STK - 1 WK
VARCO华高 202180 LATCH SPRING, HGG STK - 1 WK
VARCO华高 939656-9 BJ LOCKWASHER STK - 1 WK
VARCO华高 31525+50 DOWEL PIN OLD TYPE HGG-EL. STK - 1 WK
VARCO华高 30609 LOCK BAR HGG-EL 500 TON STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 50908-C WASHER, LOCK STK - 1 WK
VARCO华高 31216 DOOR LUG PIN HGG-EL STK - 1 WK
VARCO华高 70217 HINGE PIN AIR -EL, (PART NUMBER REQUESTED IS NOT VALID, PLEASE VERIFY PART NUMBER PRIOR TO ORDERING) STK - 1 WK
VARCO华高 50008-18-C8D SCREW, CAP-HEX HD DRILLED STK - 1 WK
VARCO华高 50905-C WASHER, LOCK-REGULAR STK - 1 WK
VARCO华高 70242 PIVOT PIN AIR . STK - 1 WK
VARCO华高 55007-6-C8 CAP SCREW STK - 1 WK
VARCO华高 939512-2 BJ PIVOT PIN STK - 1 WK
VARCO华高 939360-17 BJ THRUST WASHER STK - 1 WK
VARCO华高 35646 TRIGGER HINGE PIN AIR . STK - 1 WK
VARCO华高 31650 SHIM SET AIR-EL STK - 1 WK
VARCO华高 50008-14-C8D SCREW, CAP-HEX HD DRILLED STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 QTY P/N DESCRIPTION
VARCO华高 1 110040-1 SLEEVE, MAINSHAFT, TDS11
VARCO华高 1 109591 (MT)SLEEVE,FLANGED,7.87ID,300SS
VARCO华高 1 91829-1 (MT)SLEEVE,STEM,,TDS
VARCO华高 2 117987 (MT)BEARING,ROLLER,SPHERICAL,80X170
VARCO华高 1 109519 (MT)BEARING,ROLLER,TAPER,200X310MM
VARCO华高 INVALID #
VARCO华高 1 109521 (MT)BEARING,ROLLER,CYLINDRICAL,200X360MM
VARCO华高 2 109522 (MT)BEARING,ROLLER,CYLINDRICAL,75X160MM
VARCO华高 1 109566 (MT)TUBE,BEARING,LUBE,A36
VARCO华高 1 30122104 HEAT EXCHANGER
VARCO华高 3 109586-1 (MT)TDS9S SHIM,BRG RETAIN.002
VARCO华高 3 109586-2 (MT)TDS9S SHIM,BRG RETAIN.003
VARCO华高 3 109586-3 (MT)TDS9S SHIM,BRG RETAIN.005
VARCO华高 3 109586-4 (MT)TDS9S SHIM,BRG RETAIN.010
VARCO华高 3 109586-5 (MT)TDS9S SHIM,BRG RETAIN.031
VARCO华高 1 56710-4-2-S REDUCER, PIPE-INT/EXT
VARCO华高 1 141304 VALVE,RELIEF,TDS
VARCO华高 1 30173521 ISOLATOR,UPPER BEARING
VARCO华高 1 53304-152 CLAMP, HOSE 7 1/8' (PHM-1)
VARCO华高 2 109538 (MT)RING,RETAINING
VARCO华高 2 96648-1 (MT)RING,RETAIN,INT,PHM3I,(TDS9S)
VARCO华高 1 51300-425-B 0-RING, 'S' TUBE, TDS
VARCO华高 1 77039 SEAL,LIP 8.25x9.5x.62
VARCO华高 1 91250-1 (MT)OIL SEAL(VITON),,TDS
VARCO华高 1 98291+30 SEAL,POLYPAK,3.875,,TDS
VARCO华高 2 98290 LINER,STEM,UPPER
VARCO华高 1 30154362 SHIELD, BEARING,SMALL BORE, TDS 4S
VARCO华高 2 109539 RING,SPACER
VARCO华高 2 51216-24 PIN,DOWEL
VARCO华高 1 110008 (MT)O-RING,.275x50.5
VARCO华高 2 51300-016-B O RING
VARCO华高 2 51300-223-F O-RING
VARCO华高 2 51300-258-B O-RING
VARCO华高 1 51300-277-B O-RING
VARCO华高 1 51300-279-B O-RING
VARCO华高 1 51300-385-F O-RING
VARCO华高 2 51300-387-F O-RING
VARCO华高 4 50012-16-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 27 50012-20-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 6 50012-24-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 9 50012-26-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 10 50016-18-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 2 51217-18 (MT)LOCKWASHER, BEARING
VARCO华高 47 50912-C WASHER, LOCK-REGULAR (ALT P/N: 025062)
VARCO华高 2 30172176 COUNTER BALANCE PIN
VARCO华高 2 30172176-502 CLEVIS PIN, COUNTERBALANCE
VARCO华高 4 50516-C NUT, HEX-SLTD (UNCB-2B)
VARCO华高 2 88990-9 (MT)NOZZLE,SPRAY,.86GPM
VARCO华高 2 88990-10 (MT)NOZZLE,SPRAY,1.3GPM
VARCO华高 2 108235-15 BEARING,DRIVE,END,MOTOR,AC,TDS9
VARCO华高 2 108235-2 BEARING,AC-MOTOR,NONDRIVE-END TDS9S
VARCO华高 2 108235-3 SEAL,AC-MOTOR,DRIVE-END TDS9S
VARCO华高 2 108235-4 SEAL,AC-MOTOR,NONDRIVE-END TDS9S
VARCO华高 2 108235-13 SEAL,SHAFT,INTERNAL,TDS-9S
VARCO华高 2 108235-14 HEATER,SPACE,MTR,TDS9S
VARCO华高 3 51216-12 PIN, DOWEL (PSDS)
VARCO华高 1 51300-273-B O-RING
VARCO华高 1 51300-381-B O-RING
VARCO华高 1 30119319 RING,GLYD,11.0DIA-ROD
VARCO华高 1 30119357 RING,THRUST,.125x7.75x10.0
VARCO华高 1 30173156 PISTON RING
VARCO华高 1 30119143 RING,GLYD,11.5 DIA-ROD(S48130-340A-29)
VARCO华高 10 118375 RING,GLYD,10.0 DIA-ROD
VARCO华高 1 119547 SEAL,WIPER,11.0DIA-ROD
VARCO华高 1 30117775 RING,RETAINER,EXTERNAL
VARCO华高 2 119358 BUSHING,SLEEVE,SPLIT,1.25X10.0DIA
VARCO华高 2 115176 BUSHING,SLEEVE,1.0X1.25
VARCO华高 2 112754-130 BEARING,SINTERED,BRONZE,FLANGED
VARCO华高 1 119359 RETAINER,SEAL,OIL,A514
VARCO华高 1 50020-24-C5D SCREW, CAP-HEX HD DRILLED, TDS
VARCO华高 1 50320-C NUT, HEX-JAM
VARCO华高 20 51405-24 PIN, COTTER
VARCO华高 10 56531-8-S PLUG, O-RING BOSS
联系人:王先生
联系手机:13646905585
VARCO华高 10 56529-8-6-S CONN, O-RING BOSS/37
VARCO华高 10 56529-8-4-S CONN, O-RING BOSS/37
VARCO华高 30 53408 PLUG, PLASTIC PIPE CLOSURE
联系人:王先生
联系手机:13646905585
VARCO华高 20 53405 PLUG, PLASTIC PIPE CLOSURE
VARCO华高 1 117603-1 (MT)PUMP,LUBE,GEARBOX,ASSY,TDS9S
VARCO华高 1 30173958 SHOT PIN,PH-100
VARCO华高 1 110056 SEAL,ROD,1.5BORE
VARCO华高 1 110061-326 SEAL,PISTON (same as 110061)
VARCO华高 1 118563 SLEEVE,SHOT PIN
VARCO华高 1 30112626 BUSHING,SLEEVE,1.5X1.94,BRS
VARCO华高 1 30123290 ASSY,WASH-PIPE,3'BORE, 7500 PSI
VARCO华高 2 127908-J2 SOLENOID,VALVE,3-POS 24 VDC
VARCO华高 5 127908-D2 SOLENOID VALVE,D03,UL
VARCO华高 1 30171921 VALVE W/REWORKED HANDLE, DIRECTIONAL CONTROL
VARCO华高 1 93667-M11 PLUG, CAVITY
VARCO华高 1 94520-1NN CARTRIDGE,VALVE,PRESSURE RELIEF TDS9S
VARCO华高 3 94534-1CXN CARTRIDGE,LOGIC,PHM3I
VARCO华高 3 94536-14N CARTRIDGE,CHECK,PHM3I
VARCO华高 2 94536-230N TDS9S VALVE CART,CHECK
VARCO华高 1 94537-130N TDS9S VALVE CART,CHECK
VARCO华高 1 98402-800D VALVE,CONTROL,FLOW
VARCO华高 1 99353-1AN TDS9S REDUCING VALVE CART,RED/REL
VARCO华高 1 107028-1ANB PDM VALVE CART,DIFF UNLDG
VARCO华高 4 107029-175N TDS9S VALVE CART,CHECK
VARCO华高 1 107031-1AN IDS VALVE, RELIEF CART.
VARCO华高 1 93667-M13 PLUG,CAVITY,TDS9S
VARCO华高 3 109858-1AN TDS9S VALVE CART,RED/REL
VARCO华高 1 111664-1EN CARTRIDGE, VALVE, RELIEF, TDS9S
VARCO华高 20 93024-4SAE FITTING,SAE-4
VARCO华高 10 93024-6SAE FITTING,SAE-6
VARCO华高 8 87196-2-S PLUG, O-RING .437-20 THD
VARCO华高 8 87196-4-S PLUG, O-RING .437-20 THD
VARCO华高 8 87196-6-S PLUG, O-RING .562-18 THD
VARCO华高 8 87196-8-S PLUG, O-RING .750-16 THD
VARCO华高 8 87196-10-S PLUG, O-RING SRT THD REC HEX
VARCO华高 60 53000-1-S PLUG, EXT PIPE 1/16-27 NPT
VARCO华高 20 53000-2-S PLUG, EXT PIPE-CTSK HEX
VARCO华高 8 53000-4-S PLUG, EXT PIPE-CTSK HEX
VARCO华高 20 53000-6-S PLUG, EXT PIPE-CTSK HEX
VARCO华高 6 56544-4-S CAP, FEM 37DEG SEAT
VARCO华高 20 56544-6-S CAP, FEM 37DEG SEAT
VARCO华高 8 56544-12-S CAP, FEM 37DEG SEAT
VARCO华高 36 50103-16-B SCREW, CAP-SOC HD PH
VARCO华高 8 56519-6-6-S ELBOW, O-RING BOSS/37DEG
VARCO华高 6 56529-10-8-S CONN, O-RING BOSS/37
VARCO华高 10 56529-6-6-S CONN, O-RING BOSS/37
VARCO华高 4 56529-8-6-S CONN, O-RING BOSS/37
VARCO华高 4 56519-10-12S ELBOW, O-RING BOSS/37DEG
VARCO华高 4 56519-10-8-S ELBOW, O-RING BOSS/37DEG
VARCO华高 4 56519-12-12S ELBOW, O-RING BOSS/37DEG
VARCO华高 8 56529-8-8-S CONN, O-RING BOSS/37
VARCO华高 4 56519-4-4-S ELBOW, O-RING BOSS /37DEG
VARCO华高 4 56519-6-4-S ELBOW, O-RING BOSS/37DEG
VARCO华高 4 56519-4-6-S ELBOW, O-RING BOSS/37DEG
联系人:王先生
联系手机:13646905585
VARCO华高 4 56529-4-6-S CONN, O-RING BOSS/37
VARCO华高 4 93018-18 ORIFICE,PLUG,1.8MM
VARCO华高 4 56518-6-6-S ELBOW, 90/SWIVEL INT 37/37
VARCO华高 8 109528-1 FRICTION PAD (REPLACEMENT)
VARCO华高 4 109528-2 SEAL KIT
VARCO华高 16 109528-3 SPRING,BRAKE,DISK,TDS9
VARCO华高 16 109528-4 SCREW,RETURN,SPRING
VARCO华高 2 98898+30 CRANK,ASSY,EXTERNAL
VARCO华高 4 107052 WASHER, LOCK, TAB, .56 DIA
VARCO华高 2 71847 CAM FOLLOWER
VARCO华高 30 30115757 SCREW,CAP-HEX(METRIC),TDS9S
VARCO华高 4 50008-11-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 4 50008-14-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 7 50008-16-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 7 50912-C WASHER, LOCK-REGULAR (ALT P/N: 025062)
VARCO华高 4 50914-C WASHER, LOCK REGULAR
VARCO华高 4 55214-C NUT, HEX, TDS-3
VARCO华高 2 50310-C NUT, HEX-JAM
VARCO华高 2 50320-C NUT, HEX-JAM
VARCO华高 4 51016-C WASHER, LOCK-HEAVY
VARCO华高 1 50314-C HEX JAM NUT, 7/8
VARCO华高 1 30172175 ACTUATOR LINK PIN
VARCO华高 1 30172173 ACTUATOR LINK PIN
VARCO华高 1 118844-12-16 BUSHING,SLEEVE,0.75x1.00,FIBERGLIDE
VARCO华高 1 118844-22-30 BUSHING,SLEEVE,1.38X1.88,FIBERGLIDE
VARCO华高 1 118844-16-16 BUSHING,SLEEVE,1.00x1.00,FIBERGLIDE
VARCO华高 1 30172174 PIN, ACTUATOR LINK
VARCO华高 4 30172177 ACTUATOR LINK WASHER
VARCO华高 4 56557-8-8-S ELBOW, 45 O-RING BOSS/37
VARCO华高 16 50005-20-C5D SCREW, CAP-HEX HD (UNC)
VARCO华高 16 50905-C WASHER, LOCK-REGULAR
VARCO华高 1 110191-501 BLADDER,RESERVOIR TDS9S 5 gallon
VARCO华高 1 110132 GASKET,COVER
VARCO华高 1 51300-038-B O-RING
VARCO华高 1 71613 BREATHER,RESERVOIR
VARCO华高 1 108119-16B PDM HPU SIGHT GAUGE
VARCO华高 1 30113165 VALVE,RELIEF,.750NPT.
VARCO华高 1 118368 STABILIZER,ASSY,FRONT
VARCO华高 1 30176111 STABILIZER,ASSY REAR
VARCO华高 2 79179 SPRING,COMPRESSION,1.0x2.0x3.0
VARCO华高 4 117989 SCREW,CAP-HEX-HEAD,1.0-8X6.0
VARCO华高 8 50816-N-C WASHER, FLAT
VARCO华高 2 76443 COMPRESSION SPRING 1.95
VARCO华高 8 50008-13-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 24 50908-C WASHER, LOCK
VARCO华高 2 76442-1 ARM,GUIDE, MODIFIED
VARCO华高 4 50906-C WASHER, LOCK-REGULAR
VARCO华高 1 110083 SPRING,COMPRESSION
VARCO华高 1 30119597 SLEEVE,SPRING,2.1X3.25 DIA
VARCO华高 4 50006-8-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 10 50012-16-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 10 50912-C WASHER, LOCK-REGULAR (ALT P/N: 025062)
VARCO华高 32 50006-8-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 32 50908-C WASHER, LOCK
VARCO华高 4 16401-2 PYRAMID,TONG,DIE(TYPE'C'ROTARY-TONG)
VARCO华高 2 108894-P32 KIT,HI-LOAD,PISTON,SEAL
VARCO华高 2 108894-G13 KIT,ROD-SEAL,BRONZE-GLAND
VARCO华高 2 108894-P40 PISTON SEALS-SAME AS 76764-3
VARCO华高 2 108894-B40 BODY SEALS(SAME-AS-13718-31)
VARCO华高 2 108894-G20 SEAL,ROD
VARCO华高 1 108894-G17 SEAL,ROD/GLAND SET
VARCO华高 1 108894-L25 SEAL,LIP,PISTON (Same as 16701-3,87018-2)
VARCO华高 1 11085 RING,HEAD,CYLINDER
VARCO华高 2 72219 SEAL,PISTON
VARCO华高 1 72220 SEAL ROD
VARCO华高 1 72221 WIPER, ROD
VARCO华高 8 109944 BUSHING,FLANGED,2.75X1.5,BRZ
VARCO华高 16 30158767-04 BEARING, CAM FOLLOWER
VARCO华高 16 55324-C NUT, HEX-JAM (UNF-2B)
VARCO华高 16 51024-C WASHER, LOCK-HEAVY
VARCO华高 4 30155438 CAM,FOLLOWER 6'
VARCO华高 8 80569+30 NUT,HEX,JAM,2.0-12UN
VARCO华高 8 51132-C WASHER, LOCK-HI COLLAR
VARCO华高 12 50016-20-C5D SCREW, CAP-HEX HD DRILLED
联系人:王先生
联系手机:13646905585
VARCO华高 4 51222-12-16 PIN,SPIROL, 3/4 X 2
VARCO华高 4 30157306 LYNCH,PIN
VARCO华高 4 30152845 PIN
VARCO华高 6 50512-C NUT, HEX-SLTD, (UNC-2B)
VARCO华高 6 51716-24-C BOLT, SHOULDER-SOC HD
VARCO华高 6 50812-N-C WASHER, FLAT
VARCO华高 1 114859 REPAIR KIT,UPPER IBOP,PH-50 STD AND NAM
VARCO华高 1 99498-2 REPAIR KIT,LOWER IBOP STD&NAM
VARCO华高 1 83095-1 PHM3I SW,PRESS UL/CSA
VARCO华高 1 87541-1 SWITCH, 30' Hg-20 PSI (EExd)
VARCO华高 2 76841 TDS-3 SWITCH PRESSURE EEX
VARCO华高 1 115299 ENCODER,DIGITAL
VARCO华高 1 120119-1 (MT)PULLEY,ADAPTER
VARCO华高 1 120119-2 (MT)PULLEY,ENCODER
VARCO华高 1 120117 (MT)BELT,TIMING
VARCO华高 1 109542 PUMP,PISTON
VARCO华高 1 107783-5C11R TDS9S PUMP,HYDRAULIC VANE
VARCO华高 1 110023 COUPLING,PUMP,HYD,.750BOREX1.375BORE
VARCO华高 24 50008-10-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 4 50070-025F06 SCREW,CAP-HEX,METRIC
VARCO华高 8 51008-C WASHER, LOCK-HEAVY
VARCO华高 4 51007-C WASHER, LOCK
VARCO华高 4 50006-10-C5D SCREW, CAP-HEX HD DRILLED
VARCO华高 4 50806-N-C WASHER, FLAT
VARCO华高 4 56556-16-8-S REDUCER, O-RING BOSS
VARCO华高 4 56529-6-6-S CONN, O-RING BOSS/37
VARCO华高 4 56529-16-16-S Male Connector W/O Ring
VARCO华高 4 56506-12-8-S ELBOW, 90DEG EXT/37
VARCO华高 4 56522-6-6-S ELBOW, 90 BULKHEAD 37/37
VARCO华高 2 56513-12-S TEE, BULKHEAD UNION 37DEG
VARCO华高 1 55913-12-12 VLVD NIPPLE, QD (AEROQUIP _disibledevent= 1 SET) STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 TOTAL EXTENDED NET
VARCO华高 TOTAL EXTENDED WT
VARCO华高
VARCO华高 30158189 CRANK,ASSEMBLY STK - 1 WK
VARCO华高 110022-1B TDS9S RECEPT, POWER BLACK STK - 1 WK
VARCO华高 110022-1R TDS9S RECEPT, POWER RED STK - 1 WK
VARCO华高 110022-1W TDS9S RECEPT, POWER WHITE STK - 1 WK
VARCO华高 77408 WRENCH,SOCKET,HEX,.88 STK - 1 WK
VARCO华高 79489-14 TDS UPPER IBOP ASSY TOOL STK - 1 WK
VARCO华高 77039 SEAL,LIP 8.25x9.5x.62 STK - 1 WK
VARCO华高 109519 (MT)BEARING,ROLLER,TAPER,200X310MM 14 W
VARCO华高 109519-AM AFTERMARKET ROLLER BEARING, 200X310MM STK - 1 WK
VARCO华高 109522 (MT)BEARING,ROLLER,CYLINDRICAL,75X160MM STK - 1 WK
VARCO华高 109522-AM AFTERMARKET CYLINDRICAL ROLLER BEARING 75X160MM STK - 1 WK
VARCO华高 117987 (MT)BEARING,ROLLER,SPHERICAL,80X170 STK - 1 WK
VARCO华高 117987-AM AFTERMARKET SPHERICAL ROLLER BEARING, 80X170MM STK - 1 WK
VARCO华高 109567-B TDS9S BEARING,ROLLER STK - 1 WK
VARCO华高 109567B-AM AFTERMARKET ROLLER BEARING STK - 1 WK
VARCO华高 51024-C WASHER, LOCK-HEAVY STK - 1 WK
VARCO华高 55324-C NUT, HEX-JAM (UNF-2B) STK - 1 WK
VARCO华高 50008-12-C SCREW, CAP-HEX HD (UNC) (MTO) 5 W
VARCO华高 50108-10-C SCREW,CAP,SOCKET-HEAD (UNC) STK - 1 WK
VARCO华高 127908-D2 SOLENOID VALVE,D03,UL (LAF) STK - 1 WK
VARCO华高 87605 KIT,SEAL,REPAIR-PACK,ACCUMULATOR STOCK
VARCO华高 98898+30 CRANK,ASSY,EXTERNAL STK - 1 WK
VARCO华高 141559-1 COMBINATION WRENCH SET QTY. 2 STK; 3 W
VARCO华高 141559-2 OPEN END WRENCH SET (MTO) 3 W
VARCO华高 88905-2 12 IN. ADJUSTABLE WRENCH (MTO) 3 W
VARCO华高 80098 SUB,SPACER(6 5/8' BOX/6 5/8' PIN) (T) (MTO) 7 W
VARCO华高 109521 (MT)BEARING,ROLLER,CYLINDRICAL,200X360MM STK - 1 WK
VARCO华高 109521-AM AFTERMARKET CYLINDRICAL ROLLER BEARING 200X360MM STK - 1 WK
VARCO华高 79410-3 SUB,CROSSOVER,NC50x6 5/8 11 W
VARCO华高 30158690 LINER, STABILIZER STK - 1 WK
VARCO华高 30124191 HOSE,ASSY,PRESSURE MANIFOLD STK - 1 WK
VARCO华高 59046P08X036 HOSE ASSY STK - 1 WK
VARCO华高 59124P290093 HOSE,ASSY STK - 1 WK
VARCO华高 59143P290086 HOSE,ASSY,C'BAL,TDS9S STK - 1 WK
VARCO华高 59144P290099 HOSE,ASSY STK - 1 WK
VARCO华高 107029-175N TDS9S VALVE CART,CHECK STK - 1 WK
VARCO华高 109858-1AN TDS9S VALVE CART,RED/REL STK - 1 WK
VARCO华高 111664-1EN CARTRIDGE, VALVE, RELIEF, TDS9S STOCK
VARCO华高 59024P080032 HOSE ASSY STK - 1 WK
VARCO华高 94520-1AN CARTRIDGE,VALVE,RELIEF,PHM3I STK - 1 WK
VARCO华高 94522-1EN CARTRIDGE,VALVE,RELIEF TDS9S STK - 1 WK
VARCO华高 94536-230N TDS9S VALVE CART,CHECK STK - 1 WK
VARCO华高 94537-130N TDS9S VALVE CART,CHECK STK - 1 WK
VARCO华高 94534-1CXN CARTRIDGE,LOGIC,PHM3I STK - 1 WK
VARCO华高 94536-14N CARTRIDGE,CHECK,PHM3I STK - 1 WK
VARCO华高 87541-1 SWITCH, 30' Hg-20 PSI (EExd) STK - 1 WK
VARCO华高 116551 THROTTLE,VDC,TDS9S STK - 1 WK
VARCO华高 116199-16 POWER SUPPLY MODULE PSU2) TDS-9S (LAF) STK - 1 WK
VARCO华高 122627-34 CONNECTOR,BUS(PROFIBUS),SIEMENS S7 STK - 1 WK
VARCO华高 122627-64 MODULE,16PT,OUTPUT,SIEMENS STK - 1 WK
VARCO华高 30087708-26 SEL SWITCH MT 2 POS LR DC STK - 1 WK
VARCO华高 30087708-30 SEL SWITCH 3 POS RET CTR STK - 1 WK
VARCO华高 30087708-33 SEL SWITCH 3 POS SRFRLRDC STK - 1 WK
VARCO华高 30087708-36 SEL SWITCH 3 POS MT/LR STK - 1 WK
VARCO华高 30087708-38 INDICATING LIGHT, 24V DC RED STK - 1 WK
VARCO华高 30087708-40 INDICATING LIGHT, 24V DC AMBER STK - 1 WK
VARCO华高 30087708-44 LAMP MIN. BAYONET 24V STK - 1 WK
VARCO华高 30087708-46 DC OPERATOR,POT STK - 1 WK
VARCO华高 30087708-48 INDICATING LITE 230VCLEAR QTY. 4 STK; 4 W
VARCO华高 30087708-67 SW,PB MUSHROOM HD LR/RED STK - 1 WK
VARCO华高 30157674-2.2 2.2 KW MOTOR O/L (BREAKER) 6A STK - 1 WK
VARCO华高 30157674-7.5 7.5 KW MOTOR O/L(BRKR) 4 W
VARCO华高 30157674-9-120 CONTACTOR,9A,120VAC STK - 1 WK
VARCO华高 30157674-12-120 CONTACTOR, 12A, 120VAC STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 BX-160P BX-160 CAD PLATED RING GASKET STK - 1 WK
VARCO华高 R-35P R-35 CAD PLATED RING GASKET STK - 1 WK
VARCO华高 BX-159P BX-159 CAD PLATED RING GASKET STK - 1 WK
VARCO华高 73109 VARCO PNEUMATIC SPINNING WRENCH MODEL SSW-40, RIGHT & LEFT HAND ROTATION FOR 3-1/2' - 9-1/2' . DRILL PIPE AND DRILL COLLARS COMPLETE WITH VERTICAL POSTIONING SYSTEMS, LUBRICATOR-FILTER-REGULATOR ASSY. AND 25 FT. BY 1-1/4' AIR HOSE WITH FITTINGS (NOV) 3 - 4 WK
VARCO华高 C-73109 CAM-TECH MODEL SSW-40 PNEUMATIC SPINNING WRENCH WITH VERTICAL POSITIONING SYSTEM, RIGHT AND LEFT HAND ROTATION, SELF-ADJUSTING FOR 3.1/2' - 9.1/2' . DRILL PIPE/DRILL COLLARS. INCLUDES FILTER, LUBRICATOR AND REGULATOR ASSY. AND 25' X 1-1/4' AIR HOSE W/ FITTINGS. 4 - 6 WK
VARCO华高 1344-45 SET, 5.1/4' API HEX. ROLLERS HDP/HDS 4KRP/4KRS KELLY BUSHINGS (MTO) (NOV) 12 WK
VARCO华高 C-1344-45 SET, 5-1/4' API HEXAGON ROLLERS ONLY, HDP/HDS/4KRP/4KRS KELLY BUSHING. CONSISTING OF 2 X FLAT ROLLER & 2 X VEE ROLLER (CAM-TECH) 4 - 6 WK
联系人:王先生
联系手机:13646905585
VARCO华高 E328-1 LOAD CELL,COMP,50IN,STL/ZNPL (MTO) 3 W
VARCO华高 NO QUOTE INVALID PART NUMBER
VARCO华高 J234-20 HOSE ASSY,1/4'X 20' (MTO) 4 W
VARCO华高 J10900A-02 COUPLER,FEM,17K PSI,1/4' FNPT STK - 1 WK
VARCO华高 J10900A-20 COUPLER,M,17K PSI,1/4' FNPT STK - 1 WK
VARCO华高 KT1001A-000004 KIT ANCILLARY COMPONENTS (MTO) 1 W
VARCO华高 J996 NIPPLE,HEX,1/4'NPT X 1.5' SST STK - 1 WK
VARCO华高 119561-SL CONNECTOR,COMPSTE,QD,SOCKET/INLINE,TDS10 STK - 1 WK
VARCO华高 119561-PL CONNECTOR,COMPSTE,QD,PIN/INLINE,TDS10 STK - 1 WK
VARCO华高 210367 TEE,HEX STRT,1/4'NPT SST 7 W
VARCO华高 J808-21B BUSHING, 1/4' X 1/8' NPT, BRASS (MTO) STK - 1 WK
VARCO华高 J197A TUBING, 3/16'X.065WL COPPER (MTO) 4 W
VARCO华高 E40-1 CUP, MUD DIAPHRAGM VITON STK - 1 WK
VARCO华高 NO QUOTE NEED END USER INFORMATION
VARCO华高 10435 SSW-10 DRIVE ROLLER STK - 1 WK
VARCO华高 10576+50 CLI, HITCH PIN, SSW-10, IR-1000 STK - 1 WK
VARCO华高 10549 ROLLER ARM DETENT PIN, SSW 10 STK - 1 WK
VARCO华高 15126 PIN, PRESSURE ROLLER STK - 1 WK
VARCO华高 10439 ASSY,THRUST WASHER STK - 1 WK
VARCO华高 72380+50 ROLLER BEARING SET, (Matched Set of 3) STK - 1 WK
VARCO华高 12047 BEARING, ROLLER (For Units No 419 &Up) STK - 1 WK
VARCO华高 12083 BEARING, THRUST STK - 1 WK
VARCO华高 10882+50 GASKET, BEARING COVER, IR-1000 STK - 1 WK
VARCO华高 12051 RACE, INNER (2.000 ID), IR-1000 STK - 1 WK
VARCO华高 10475 GASKET, GEAR COVER, IR-1000 IRON STK - 1 WK
VARCO华高 10632 GASKET, AIR MOTOR, SSW 10 STK - 1 WK
VARCO华高 51300-347-B O-RING, ID 4.844/4.874 THICK STK - 1 WK
VARCO华高 10742 DRIVE ROLLER SEAL STK - 1 WK
VARCO华高 13000 BUTTON OPERATOR, HEAVY DUTY STK - 1 WK
VARCO华高 30013001 SSW 10 BODY SEAL KIT STK - 1 WK
VARCO华高 12070-8 SSW10, AIR V SPOOL STK - 1 WK
VARCO华高 15953+50 SSW-10 SPARE PARTS KIT (THIS ITEM INCLUDES ALL ITEMS 1 - 17 ABOVE. ) STK - 1 WK
VARCO华高 14694-25 GASKET, COVER STK - 1 WK
VARCO华高 14694-37 BEARING,BALL,AIR MOTOR,6600SPINNER,SSW-40WRENCH STK - 1 WK
VARCO华高 14694-39 BLADE, ROTOR, AIR MOTOR STK - 1 WK
VARCO华高 14694-49 Gear, 1ST - 52 Teeth STK - 1 WK
VARCO华高 14694-50 Pinion - 14 Teeth STK - 1 WK
VARCO华高 14694-70 SEAL, OIL STK - 1 WK
VARCO华高 14694-66 BALL BEARING STK - 1 WK
VARCO华高 14694-69 BEARING, ROLLER STK - 1 WK
VARCO华高 15955 SW-10 C/P SPARE PART KIT (THIS ITEM INCLUDES ALL ITEMS 19-27 ABOVE) STK - 1 WK
VARCO华高 2166-54 5' BY 4.1/2' INSERT SET, SDS/SDXL ROTARY SLIP STK - 1 WK
VARCO华高 15522 VARCO 3-1/2' SDML ROTARY SLIP COMPLETE WITH INSERTS QTY. 7 STK; 19 WKS
VARCO华高 2630-112 CIRCULAR BUTTON KIT-9 1/4-11 1/4 DCSL STK - 1 WK
VARCO华高 6415591 DIE-TOOL JOINT BREAKER STK - 1 WK
VARCO华高 81788+30 DIE,WRENCH,TORQUE STOCK
VARCO华高 0001-0870-32 ENCODER-INCREMENTAL,5VDC,EEXD, 3 W
VARCO华高 30122725-256-HE DIGITAL ENCODER (MTO) 15 W
VARCO华高 30122725-HE ENCODER,DIGITAL. LOW TEMP STK - 1 WK
VARCO华高 40943311-030 MODULE,ANALOG OUTPUT,2 CHAN STK - 1 WK
VARCO华高 126907-133B-S648S-E CONNECTOR,7 SOCKET W/STRAIGHT PLUG(ATEX)(MTO) 5 W
VARCO华高 126907-133B-S354S-N CONNECTOR,7 SOCKET W/STRAIGHT PLUG(ATEX) (MTO) 5 W
VARCO华高 114724-BLK-100 CABLE,POWER,W/QD,100',ASSY,BLACK SCD STK - 1 WK
VARCO华高 114724-WHT-100 CABLE,POWER,W/QD,100',ASSY,WHITE STK - 1 WK
VARCO华高 114724-RED-100 CABLE,POWER,W/QD,100',ASSY,RED STK - 1 WK
VARCO华高 123985-125-B CABLE,COMPOSITE,ASSY,TDS10 (MTO) 7 W
VARCO华高 124458-125-B ASSEMBLY,JUMPER CABLE-18 COND (MTO) 4 W
VARCO华高 30181755-175-B CABLE ASSY, 7/C X 1.5MM (MTO) 8 W
VARCO华高 30181756-175-B CABLE ASSY, PROFIBUS (MTO) 8 W
VARCO华高 125093-100 CABLE, EARTHING, 444MCM, ASSY (MTO) 6 W
联系人:王先生
联系手机:13646905585
VARCO华高 0001-0870-32 ENCODER-INCREMENTAL,5VDC,EEXD, STK - 1 WK
VARCO华高 30122725-256-HE DIGITAL ENCODER (MTO) STK - 1 WK
VARCO华高 15522 VARCO 3-1/2' SDML ROTARY SLIP COMPLETE WITH INSERTS (VARCO) STOCK
VARCO华高 940287-819 2ND RED. GEAR SHAFT SEAL (CAVINS) STK - 1 WK
VARCO华高 252192135 OTECO DUAL SPLIT RAP-A-ROUND PIPE WIPER/ NATURAL RUBBER, 19' X 3-1/2' (OTECO) STK - 1 WK
VARCO华高 16401-2 BJ Tong Die Pyramid, 1/2' x 1.1/4' x 5' (VARCO) STOCK
VARCO华高 WP16401-2 WPSI TONG DIE, 1/2' X 1.1/4' X 5' (AFTERMARKET) STOCK
VARCO华高 103141-7 FEMALE ROD CLEVIS STK - 1 WK
VARCO华高 118844-16-24 BUSHING,SLEEVE,1.00x1.50,FIBERGLIDE STK - 1 WK
VARCO华高 125594 CYLINDER,HYD,IBOP,ACTUATOR,ASSY,PH100 STK - 1 WK
VARCO华高 E80 TENSION LOAD CELL, TYPE D, E, EB, C/W CERT STK - 1 WK
VARCO华高 212450-101 PUMP,HAND W/ 1/4'NPT SWIVEL STK - 1 WK
VARCO华高 W15 FLUID, INSTRUMENT QUART 'RED', C/W MSDS STK - 1 WK
VARCO华高 213779-105 NEED END USER INFORMATION IN ORDER TO QUOTE
VARCO华高 7804314 ELEMENT, BRAKE STK - 1 WK
VARCO华高 88083 VALVE,QUICK,EXHAUST,.75NPT STK - 1 WK
VARCO华高 69100290200 RING,RETAINING SPIROLOX RST-2 STK - 1 WK
VARCO华高 GM4-254 IND, 6', CMPD, B/M, 16K PSI, E17-152, 25FT HOSE (MTO) 2 W
VARCO华高 J234-50 HOSE ASSY,1/4'X 50', 5K PSI STK - 1 WK
VARCO华高 NO QUOTE NEED MORE INFORMATION
VARCO华高 40219908 BATTERY PACK ASSY,EDMS,TOTAL STK - 1 WK
VARCO华高 GM4-254 IND, 6', CMPD, B/M, 16K PSI, E17-152, 25FT HOSE (MTO) 2 WK
联系人:王先生
联系手机:13646905585
VARCO华高 50108-16-C SCREW, CAP-SOC HD STK - 1 WK
VARCO华高 30173958 SHOT PIN,PH-100 STK - 1 WK
VARCO华高 110056 SEAL,ROD,1.5BORE STK - 1 WK
VARCO华高 30151951 SLEEVE,SHOT PIN,PH-100 STK - 1 WK
VARCO华高 30125052 JAW,NC50,ASSY,PH100 STK - 1 WK
VARCO华高 30124575 SEALS,ACCUM,6' STK - 1 WK
VARCO华高 30124576 SEALS,ACCUM,2' STK - 1 WK
VARCO华高 87605-1 SEAL KIT FLOOR 4' ID ACCUMULATOR STK - 1 WK
VARCO华高 114446 CHARGING ASSY, ACCUMULATOR, W/O GAUGE STK - 1 WK
VARCO华高 114446-500 CHARGING ASSY,ACCUMULATOR C/W GAUGE STK - 1 WK
VARCO华高 30173216-1 ELEMENT,FILTER,HYD STK - 1 WK
VARCO华高 110070 RING,SPACER,.78X1.74X.75,MS15 STK - 1 WK
VARCO华高 NO QUOTE INCOMPLETE PART NUMBER; PLEASE VERIFY
VARCO华高 55909-12-12 VALVED NIPPLE 3/4', QD AEROQUIP STK - 1 WK
VARCO华高 30122112 BOLT, RETAINER, JAW, .5 X 6.5 STK - 1 WK
VARCO华高 50508-C NUT, HEX-SLTD (UNC-2B) STK - 1 WK
VARCO华高 30122367 U-BOLT,.75-UNC,500T,LINKTILT,PH50 STK - 1 WK
VARCO华高 50412-C NUT, HEX-HEAVY (UNC-2B) STK - 1 WK
VARCO华高 53219-1 FITTING, GREASE STRAIGHT STK - 1 WK
VARCO华高 56557-8-8-S ELBOW, 45 O-RING BOSS/37 STK - 1 WK
VARCO华高 53408 PLUG, PLASTIC PIPE CLOSURE STK - 1 WK
VARCO华高 30173958 SHOT PIN,PH-100 (REPLACES 117831) STK - 1 WK
VARCO华高 118563 SLEEVE,SHOT PIN STK - 1 WK
VARCO华高 110061-326 SEAL,PISTON (same as 110061) STK - 1 WK
VARCO华高 30123562 RING,SNAP,3'WASH-PIPE,TDS STK - 1 WK
VARCO华高 51300-348-F O-RING STK - 1 WK
VARCO华高 76841 TDS-3 SWITCH PRESSURE EEX STK - 1 WK
VARCO华高 119139 U-BOLT,.75DIA,MS21 STK - 1 WK
VARCO华高 119122 CLAMP,LINK STK - 1 WK
VARCO华高 51012-C WASHER, LOCK-HEAVY STK - 1 WK
VARCO华高 51402-10-S PIN, COTTER STK - 1 WK
VARCO华高 30157224-04S CAM FOLLOWER, 4'DIA,SHORT SHANK TDS/IDS 1 W
VARCO华高 98291+30 SEAL,POLYPAK,3.875,,TDS 4 W
VARCO华高 53208 SPART,FTG, GREASE STR, DRIVE STK - 1 WK
VARCO华高 50914-C WASHER, LOCK REGULAR STK - 1 WK
VARCO华高 30172060 HEX NUT, MODIFIED STK - 1 WK
VARCO华高 111924-1 RING, DUST, RUBBER STK - 1 WK
VARCO华高 83095-1 PHM3I SW,PRESS UL/CSA STK - 1 WK
VARCO华高 56519-12-12S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56519-6-6-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56519-16-12S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56519-6-4-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56529-8-8-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56529-8-6-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56529-6-6-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56529-10-8-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56519-16-16S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56529-4-4-S CONNECTOR,O-RING BOSS/37 STK - 1 WK
VARCO华高 56518-4-4-S ELBOW, 90/SWVEL INT 37/37 STK - 1 WK
VARCO华高 56529-8-4-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56519-8-6-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56529-16-16S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 56522-6-6-S ELBOW, 90 BULKHEAD 37/37 STK - 1 WK
VARCO华高 56551-16-12S CONN, O-RING BOSS/INT P STK - 1 WK
VARCO华高 56519-8-8-S ELBOW, O-RING BOSS/37DEG STK - 1 WK
VARCO华高 56506-4-4-S ELBOW, 90DEG EXT/37 STK - 1 WK
VARCO华高 56501-4-4-S CONN, EXT PIPE/37DEG STK - 1 WK
VARCO华高 56524-8-8-S ELBOW STK - 1 WK
VARCO华高 56501-24-16S CONN, EXT PIPE/37DEG STK - 1 WK
VARCO华高 56524-4-4-S ELBOW STK - 1 WK
VARCO华高 56529-4-6-S CONN, O-RING BOSS/37 STK - 1 WK
VARCO华高 93018-10 PLUG,ORIFICE,.039 3 W
VARCO华高 93018-08 PLUG,ORIFICE STK - 1 WK
VARCO华高 93018-14 ORIFICE PLUG, #10-32X.055 STK - 1 WK
VARCO华高 110844-18 PLUG,ORIFICE,.250 NPT(.071)(PRS8) STK - 1 WK
VARCO华高 87196-2-S PLUG, O-RING .437-20 THD STK - 1 WK
VARCO华高 87196-4-S PLUG, O-RING .437-20 THD STK - 1 WK
VARCO华高 87196-6-S PLUG, O-RING .562-18 THD STK - 1 WK
VARCO华高 87196-8-S PLUG, O-RING .750-16 THD STK - 1 WK
VARCO华高 87196-10-S PLUG, O-RING SRT THD REC HEX STK - 1 WK
VARCO华高 53000-1-S PLUG, EXT PIPE 1/16-27 NPT STK - 1 WK
VARCO华高 53000-2-S PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-4-S PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-6-S PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-2-C PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-4-C PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-6-C PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-8-C PLUG, EXT PIPE-CTSK HEX STK - 1 WK
VARCO华高 53000-12-C PLUG, EXT PIPE-CTSK HEX 3 W
VARCO华高 53000-48-C PLUG,PIPE,EXT,CTSK,HEX STK - 1 WK
VARCO华高 53002-32-C PLUG, PIPE-SQ HD STK - 1 WK
VARCO华高 53003-16 PLUG, SQ HD MAGNETIC STK - 1 WK
VARCO华高 56531-4-S PLUG, O-RING BOSS STK - 1 WK
VARCO华高 56531-8-S PLUG, O-RING BOSS STK - 1 WK
VARCO华高 94821 (MT)PLUG,MODIFIED, 3'NPT,W/.38NPT HOLE STK - 1 WK
VARCO华高 110704 ACTUATOR,ASSY,COUNTER BALANCE STK - 1 WK
VARCO华高 30123290-PK KIT,SEAL, WASHPIPE PACKING, 7500 PSI STK - 1 WK
VARCO华高 SAME AS ITEM ABOVE 30123290-PK
VARCO华高 30123289 WASH PIPE, 3'BORE, 7,500 PSI STK - 1 WK
VARCO华高 114706-502 ASSY,LWR,IBOP6 5/8X6 5/8W/RLFGRV,H2SW, C/W CERT STK - 1 WK
VARCO华高 110103-502 ASSY,UPPER IBOP,6 5/8X 6 5/8,PH50,H2S, C/W CERT STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 SAME AS ITEM ABOVE 30119592
VARCO华高 7032A415 BRAKE,HYDRA RELEASE STK - 1 WK
VARCO华高 26740078 COUPLING, SPLINE STK - 1 WK
VARCO华高 26740098 SHAFT, INPUT, 350 AUX WINCH 10 W
VARCO华高 26740079 SHAFT, INPUT 350 BOOM WINCH STK - 1 WK
VARCO华高 26740076 SLEEVE 8 W
VARCO华高 26750039-26 SHAFT, INPUT SIPCO SS70443 11 W
VARCO华高 26750024-18 BEARING, CYLINDRICAL ROLLER NJ 220 ECP 7 W
VARCO华高 26750024-25 BEARING, SPHERICAL ROLLER 22222E 5 W
VARCO华高 26750039-21 BEARING, BALL 16012 SIPCO XB15 7 W
VARCO华高 26750039-22 BEARING, BALL 6012 SIPCO XB121 7 W
VARCO华高 26750039-23 SEAL, SHAFT 4 W
VARCO华高 26750001 MOTOR, HYDRAULIC LINDE HMV135 51 W
VARCO华高 26750034 VALVE, PRIMARY CONTROL 19 W
VARCO华高 NO QUOTE PLEASE VERIFY PART NUMBER & DESCRIPTION
VARCO华高 26280003 VALVE,OVERSPEED SENSING 4 W
VARCO华高 2111730 VALVE, EMERGENCY BRAKE SET STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 212371-1000 LOAD CELL ASSY, 6.53 T F/S, C/W CERT STK - 1 WK
VARCO华高 24747+50 TONG PULL BACK - CODE TUGGER STK - 1 WK
VARCO华高 24747-AM AFTERMARKET TONG PULL BACK TUGGER STOCK
VARCO华高 30153710 BEAM,GUIDE,TOP SECTION (MTO) 26 W
VARCO华高 30154381 BEAM,GUIDE,BOTTOM INTERMEDIATE SECTION (MTO) STK - 1 WK
VARCO华高 124517-502 BEAM,GUIDE,INTERMED,24',TDS11 STK - 1 WK
VARCO华高 124517-503 BEAM,GUIDE,INTERMED,6',TDS11 STK - 1 WK
VARCO华高 124517-502 BEAM,GUIDE,INTERMED,24',TDS11 (MTO) STK - 1 WK
VARCO华高 30154900 ASSY,HANG OFF LINK (MTO) (VERIFY PART NUMBER TO MAKE SURE THERE IS NO DASHES, THIS NUMBER IS LISTED MULTIPLE TIMES W/ THE SAME DESCRIPTION. -500, -501, -502 & -503) 14 W
VARCO华高 NO QUOTE INCOMPLETE PART NUMBER, PLEASE VERIFY (OPTIONS ARE 30154685 -100, -101 OR -200)
VARCO华高 30154700 ASSY, STK - 1 WK
VARCO华高 30154905 ASSY,BRACE HANG-OFF 8 W
VARCO华高 117496-1 RETAINER,SELF-LOCK,TDS9S STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 191703 BAFFLE PLATE, 4-1/2 API REG STK - 1 WK
VARCO华高 191705 BAFFLE PLATE, 6-5/8 API REG STK - 1 WK
VARCO华高 86871-25 TDS NYLON WASHER 25MM STK - 1 WK
VARCO华高 2170-54 VARCO 5-1/2' INSERT SET, SDL/SDXL ROTARY SLIP STOCK
VARCO华高 NO QUOTE UNABLE TO IDENTIFY; PLEASE PROVIDE MORE INFO.
VARCO华高 E17-152 DIAPHRAGM PROT ASSY,15K STK - 1 WK
VARCO华高 WE4-15 IND,16',SPCL APP,SI/ENG,JIANG HAN ANCH. JZG 41 (MTO) 3 W
VARCO华高 232389 PROXIMITY SENSOR ASSY (UL) STK - 1 WK
VARCO华高 212450-101 PUMP,HAND W/ 1/4'NPT SWIVEL (REPLACES P/N YA2) (PLEASE VERIFY DESCRIPTION AND PART NUMBER) STK - 1 WK
VARCO华高 222573-001 SENSOR,LEVEL,ULTRASONIC STK - 1 WK
VARCO华高 19000-6 VARCO Spinning Wrench Model SSW-30. Hydraulic Powered, with Vertical Positioning
VARCO华高 59044P230073 HOSE ASSY STK - 1 WK
VARCO华高 59044P230074 HOSE,ASSY STK - 1 WK
VARCO华高 119732 CLEVIS,ROD,MODIFIED STK - 1 WK
VARCO华高 110703 ACTUATOR ASSY, COUNTER BALANCE STK - 1 WK
VARCO华高 30118405 TUBE,ASSY,MAINIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 30113974 TUBE,ASSY,MOTOR/MANIFOLD STK - 1 WK
VARCO华高 30115421 TUBE,ASSY,MANIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 115422 TUBE,ASSY,MANIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 115423 TUBE,ASSY,MANIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 118410 TUBE,ASSY,ACCUMULATOR/LOAD-STEM STK - 1 WK
VARCO华高 117570 TUBE,ASSY,MANIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 30115425 TUBE,ASSY,MANIFOLD/LOAD-STEM STK - 1 WK
VARCO华高 113984 TUBE,ASSY,ACCUMULATOR STK - 1 WK
VARCO华高 113988 TUBE,ASSY,PRESSURE,SWITCH STK - 1 WK
VARCO华高 30114087 TUBE,ASSY,MANIFOLD/PUMP STK - 1 WK
VARCO华高 117019 TUBE,ASSY,BRAKE-UNION STK - 1 WK
VARCO华高 30125103 ASSY, TUBE, LUBRICATOR-OUT STK - 1 WK
VARCO华高 56501-12-12S CONN, EXT PIPE/37DEG STK - 1 WK
VARCO华高 59124P290180 HOSE ASSY STK - 1 WK
VARCO华高 55908-12-12S COUPLER, VALVED QUICK DISC. STK - 1 WK
VARCO华高 55914-12 PLUG, DUST 3/4' AEROQUIP STK - 1 WK
VARCO华高 97507-1 IDS LUBE OIL PUMP,10 GPM (REPLACES 30176013) STK - 1 WK
联系人:王先生
联系手机:13646905585
VARCO华高 80450 UNABLE TO IDENTIFY
VARCO华高 71091 ACTUATOR,LIFT,2.5BOREXX33.0 STK - 1 WK
VARCO华高 87018 ACTUATOR,2.5BOREX7.0(NO-DASH-NUMBERS!) STK - 1 WK
VARCO华高 82737+30 ACTUATOR,HYD,4.0PISTONX10.0 STK - 1 WK
VARCO华高 412125g1208 UNABLE TO IDENTIFY
VARCO华高 50108-14-C SCREW,CAP-SOC HD STOCK
VARCO华高 30173216-1 ELEMENT,FILTER,HYD (REPLACES 114416-1) STOCK
VARCO华高 H34001T BODY, MACHINE 3' TITAN CLASS C STK - 1 WK
VARCO华高 31948/M2 SUB, M2 / TITAN 1 - 2 WK
VARCO华高
VARCO华高 2037188 IBOP, 4'ID DUAL CRANK 7-5/8REG P X 6-5/8 12 W
VARCO华高 2037193 BODY,X-OVER 6-5/8 IF PIN/PIN 4 STK - 1 WK
VARCO华高 2037189 IBOP, 4'ID SNGL CRANK 6-5/8FH 40 W
VARCO华高 2037220 SHIM, 1/16' L-PIPE SUPPORT, LA (MTO) 5 W
VARCO华高 060155041 VALVE, 7DD U5C-EEF SUPREME STK - 1 WK
VARCO华高 061101507 SEAT, SUP 7DD-B1 SUPREME STK - 1 WK
VARCO华高 NO QUOTE
VARCO华高 H36020 KIT, REPAIR TITAN RX RRVALVE (** ONLY 4 IN STOCK) STK - 1 WK
VARCO华高 07326551 LINER, 5-1/2' CERAMIC 12 - 14 W
VARCO华高 012180338 PISTON, 5-1/2' WL 14/15 STK - 1 WK
VARCO华高 012180395 PISTON, 6' WL6HHB 14/15 STK - 1 WK
VARCO华高 012180618 PISTON S 7 H-L-14/15 2 - 3 W
VARCO华高 50012-14-C5D SCREW, CAP-HEX HD STK - 1 WK
VARCO华高 50812-W-C WASHER, FLAT WIDE STK - 1 WK
VARCO华高 114860-2 REPAIR KIT, UPPER IBOP, PH-50 H2S STK - 1 WK
VARCO华高 114860-1 REPAIR KIT, UPPER IBOP, PH-50 H2S STK - 1 WK
VARCO华高 99503-1 SEAL KIT,LWR IBOP,H2S STK - 1 WK
VARCO华高 99503-2 REPAIR KIT,LWR IBOP H2S STK - 1 WK
VARCO华高 141279-2 KIT,TDS-11S L SPARES STK - 1 WK
VARCO华高 30150450-1 SPARES,MTR HSG,TDS11,KIT(MTO) 22 W
VARCO华高 124623-CH SPECIAL TOOLS KIT 14 W
VARCO华高 30182026-1 SPARES KIT,COMMISS,CONTROL ABB TDS-911S (MTO) 9 W
VARCO华高 30171150-S-2-CH KIT,SPARES PH-75 (MTO) 16 W
VARCO华高 114869-PL-BLK CONNECTOR,POWER,QD,PIN/INLINE,BLACK STK - 1 WK
VARCO华高 114869-PL-WHT CONNECTOR,POWER,QD,PIN/INLINE,WHITE STK - 1 WK
VARCO华高 122109 JAW,ASSY,6-6.6,TOOL-JOINT STK - 1 WK
VARCO华高 30123114 STAB-GUIDE,7-7.5',ASSY,PH50 STK - 1 WK
VARCO华高 75577 RING, SHOULDER, SSW-40 SPINNING STOCK
VARCO华高 75541 SHAFT, IDLER, SSW-40 SPINNING STK - 1 WK
VARCO华高 75542 SHAFT, COMPOUND, SSW-40 SPINNING STK - 1 WK
VARCO华高 75504 BEARING, NEEDLE, SSW-40 SPINNING STK - 1 WK
VARCO华高 73090 BALL BEARING, SSW-40 SPINNING STK - 1 WK
VARCO华高 73092 GASKET, GEAR COVER, SSW-40 SPINNING STK - 1 WK
VARCO华高 73091 BEARING,ROLLER,1.6X3.5X1.3 STOCK
VARCO华高 76089 SPACER, SHIELD, S/N 13 AND UP STOCK
VARCO华高 51300-152-B O-RING STOCK
VARCO华高 73078-1 KEY, DRIVE ROLLER, SSW-40 STK - 1 WK
VARCO华高 75249 KEY, DRIVE ROLLER, SSW-40 SPINNING STK - 1 WK
VARCO华高 73110 SSW-40 EXTENSION SPRING STK - 1 WK
VARCO华高 74233 MUFFLERM SSW-40 SPINNING WRENCH STK - 1 WK
VARCO华高 53600-181 RING, RETAINING-EXT STK - 1 WK
VARCO华高 74954 SSW40 NAME PLATE (MTO) 8 W
VARCO华高 74555-1 SHAFT, OUTPUT, AIR MOTOR STOCK
VARCO华高 74555-2 SEAL, AIR MOTOR 6600 KELLY SPINNER STOCK
VARCO华高 14694-37 BEARING,BALL,AIR MOTOR,6600SPINNER,SSW-40WRENCH STOCK
VARCO华高 74555-24 BEARING, BALL, AIR MOTOR 6600 KELLY STOCK
VARCO华高 74555-30 BEARING, BALL, PNEUMATIC AIR MOTOR STK - 1 WK
VARCO华高 14694-42 SHIM, ROTOR 0.001 STK - 1 WK
VARCO华高 14694-43 SHIM, ROTOR 0.002 STK - 1 WK
VARCO华高 14694-44 SHIM, ROTOR 0.003 STK - 1 WK
VARCO华高 14694-45 SHIM, ROTOR 0.005 STK - 1 WK
VARCO华高 59024P080051 HOSE ASSY STK - 1 WK
VARCO华高 75924 HOSE ASSY, MOTOR RIGHT, SSW-40 STK - 1 WK
VARCO华高 56506-16-12S ELBOW, 90DEG EXT/37 STK - 1 WK
VARCO华高 75925 HOSE ASSY, MOTOR LEFT, SSW-40 STK - 1 WK
VARCO华高 74253 FITTING, TEE, RIGHT HAND, SSW-40 STK - 1 WK
VARCO华高 56502-12-12S ELBOW, 45DEG EXT PIPE/37 STK - 1 WK
VARCO华高 75920 SSW40 FITTING-TEE STK - 1 WK
VARCO华高 76261-1 HOSE ASSY, INBOARD SSW-40 STK - 1 WK
VARCO华高 76261-2 HOSE ASSY, OUTBOARD, SSW-40 STK - 1 WK
VARCO华高 946900-001 CABLE,COAX,RG-59/U,BLK JKT 5 W
VARCO华高 73469 CLUTCH, 6600/6800 KELLY SPINNERS STK - 1 WK
VARCO华高 73406 KS PINION GEAR SHAFT STK - 1 WK
VARCO华高 73402 KS CLUTCH REDUCTION GEAR (MTO) 7 W
VARCO华高 73402-AM KS CLUTCH REDUCTION GEAR (AFTERMARKET) STK - 1 WK
VARCO华高 73195-1 SHIM, .010, 6600/6800 KELLY SPINNER STK - 1 WK
VARCO华高 73195-2 BJ SHIM, 0.005 STK - 1 WK
VARCO华高 73195-3 BJ SHIM 0.002 STK - 1 WK
VARCO华高 74825 NO QUOTE; NOV WILL NOT SELL AS A SPARE PART N/A
VARCO华高 74825-AM KS TUBE ASSY MTR SHORT (AFTERMARKET) STK - 1 WK
VARCO华高 70807 KS HYD MOTOR GASKET (MTO) 9 W
VARCO华高 70807-AM MOTOR GASKET, HYD. KELLY SPINNER (AFTERMARKET) STK - 1 WK
VARCO华高 70813 KS HYD MOTOR (MTO) 9 W
VARCO华高 70813-AM KS HYD. MOTOR (AFTERMARKET) 2 WK
VARCO华高 73627 BJ HOSE ASSEMBLY, SHUTTLE STK - 1 WK
VARCO华高 74195 KS SHAFT-MOTOR STK - 1 WK
VARCO华高 74195-AM KS SHAFT - MOTOR (AFTERMARKET) 1 WK
VARCO华高 6563 GREASE SEAL, SUB (LOWER & UPPER) STK - 1 WK
VARCO华高 114090-500 ASSY,TUBE,MANIFOLD/FILTER,TDS9 (MTO) 5 W
VARCO华高 109528-1 FRICTION PAD (REPLACEMENT) STK - 1 WK
VARCO华高 109523 ADAPTER,S-TUBE 7 W
VARCO华高 55109-8-C SCREW,CAP SOC-HD STK - 1 WK
VARCO华高 30160614 ROLLER,KNURLED STK - 1 WK
VARCO华高 30172354-502 MANIFOLD,ADJUSTMENT STK - 1 WK
VARCO华高 30173757 SLIDE RING STK - 1 WK
VARCO华高 30160658 ASSY, PISTON, SW CLAMP STK - 1 WK
VARCO华高 30160658-SK SEAL KIT STK - 1 WK
VARCO华高 94518-13HN PLS-1 VALVE,C'BALANCE STK - 1 WK
VARCO华高 93939+30 SENSOR, PROXIMITY STK - 1 WK
VARCO华高 116199-76 CUCV BOARD, AC INVERTER SIEMENS STK - 1 WK
VARCO华高 P10120A-01 TENSION CYLINDER, 4.50 SQ IN, 20K LB (MTO) STK - 1 WK
VARCO华高 F230-3 BODY,DAMPER,HP,PNL MNT .25'-20 (MTO) 4 W
VARCO华高 GA113-5 INDICATOR,6 IN 5,000 PSI, P/M 3 W
VARCO华高 E17-152+40 DIAPHRAGM PROT ASSY,15K STK - 1 WK
VARCO华高 222573-002 KIT,SENSOR MNT,ULTRASONIC,2'NPT,150# ANSI FLANGE 1 W
VARCO华高 H10992A-779P BARR,IS,28V,300 OHM,93MA,POS, (MTO) 5 W
VARCO华高 H10992A-787SP BARR,IS,28V,300 OHM,93MA,POS, (MTO) 5 W
VARCO华高 H10992A-768P BARR,IS,22V,150 OHM,147MA,POS, (MTO) 7 W
VARCO华高 951540-007 BARRIER,TIB,PROX,NPN,DUAL 10 W
VARCO华高 H10992A-765A BARR,IS,15V,100 OHM,150MA,AC, (MTO) 12 W
VARCO华高 H12010A MDL,ISMI MASTER STK - 1 WK
VARCO华高 220451-002 HORN ASSY,ALARM, .,DUAL TONE STK - 1 WK
VARCO华高 938201-023 FUSE SB 2A 3AGA2 (REPLACES H1507-23) (MTO) 5 W
VARCO华高 219484 PCBA,DAQ COMM BRD (TESTED) (MTO) 6 W
联系人:王先生
联系手机:13646905585
VARCO华高 641102181 SHAFT SLEEVE STOCK
VARCO华高 30156795 FILTER/REG/LUB-ASSY STK - 1 WK
VARCO华高 73785 BEARING,ROLLER,CAM,6.0DIAX2.5ROD STK - 1 WK
VARCO华高 51140-C WASHER, LOCK-HI COLLAR STK - 1 WK
VARCO华高 73784 NUT,HEX,2.5-12UN STK - 1 WK
VARCO华高 88484 SHACKLE,13.5 TON, C/W PROOF TEST CERTS STK - 1 WK
VARCO华高 53200-454 COMPOUND, ADHESIVE .7 OZ QTY. 1 STK; 3 W
VARCO华高 B678A-160 DIAL,CMPD PRESS,6',16K PSI (MTO) 2 W
VARCO华高 0613-1233-04 KNOB-S/S,ROTARY TORQUE LMT,WIT LEVEL: 04 STK - 1 WK
VARCO华高 B04G0001 ASSY-PWR SPLY,PROGRAMMABLE, (MTO) 3 W
VARCO华高 B01H0001 ASSY-HAND THROTTLE,3 OD (4/95) STK - 1 WK
VARCO华高 02T00011 BLOWER DUAL TURBINE,1200CFM,120V AC/50/60HZ 7 W
VARCO华高 14T00081 SW-3POS,CB OPEN-CLOSE,1NO1NC (MTO) 5 W
VARCO华高 20T00204 METER-TEMP,RTD,DIGITAL W/ALARM (MTO) 7 W
VARCO华高 14T00063 SW-8POS,MAIN,5DK,,OVAL HNDL (MTO) 5 W
VARCO华高 14T00086 PB-ESTOP,HD,1NC,RED,NEMA 4,30. (MTO) STK - 1 WK
VARCO华高 01T00155 FILTER-RFI,POWER LINE,120VA @ (MTO) 3 W
VARCO华高 14T00015 SW-DIFF,PRESS,1NO1NC,0 15 0 5 4 W
VARCO华高 B07H0000 ASSY-REVERSING DC EXCITATION, W/FIELD WEAKENING STK - 1 WK
VARCO华高 14T00010 PB-PUSH/PULL,MUSHROOM HD,1NO1BC,RED NEMA (MTO) 5 W
VARCO华高 05466650 LINER,6-1/2'NAT.12P-160 SS0259 STK - 1 WK
VARCO华高 12180535 PISTON S 6 1/2H-L-14/15 2 - 3 W
VARCO华高 1560985 VALVE, TYPE G 2 FLUID CPT STK - 1 WK
VARCO华高 1561440 SEAT, VALVE STK - 1 WK
VARCO华高 07499650 LINER, 6-1/2 CER F/ FB1600 12 - 14 W
VARCO华高 1502062 PISTON, 6-1/2' GREEN_DUO 14/15 STK - 1 WK
VARCO华高 935676-006 PROT,AC,240V,1 AMP QTY. 3 STK; 8 WK
VARCO华高 GA60A-160 INDICATOR,COMP 16,000 PSI, B/M, C/W CERT (MTO) 2 WK
VARCO华高 55912-12-12 VLVD COUPLR, QD(AEROQUIP ONLY) STK - 1 WK
VARCO华高 55913-12-12 VLVD NIPPLE, QD (AEROQUIP ONLY) STK - 1 WK
VARCO华高 53002-48 PLUG, PIPE-SQ HD (MTO) 4 W
VARCO华高 121131 (MT) SHAFT, MAIN, W/LANDING COLLAR STK - 1 WK
联系人:王先生
联系手机:13646905585
- 电话:13646905585
- 传真:0595-36617079
- email:2291817214@qq.com
VARCO华高76666-2 油田进口件
