- 型号:FW6100GC-J
- 数量:9999
- 制造商:进申防爆
- 有效期:2027/4/24 0:00:00
FW6100GC-J强光泛光工作灯
适用场所:
※ 适用于电力、铁路、市政等行业户外移动照明。
※ 适用于各种作业、事故抢修、异常情况处理等现场对大范围移动照明灯具的需要。
※ suitable for electric power, railway, municipal and other outdoor mobile lighting industry.
※ suitable for a wide range of mobile lighting needs in various operation, accident repair, exception handling site.
结构特性:
※ 采用特殊气体放电光源,发光效率高,寿命长,节能环保。
※ 高能无记忆电池可随时充电,一次充电后半年内储电量不低于满容量的85%,两年内储电量不低于满容量的55%,并设有低电压放电保护,可靠保护电池过充过放。
※ 灯具整体采用全密性工艺设计,防水防尘;特制合金外壳和防弹胶外壳确保灯具能经受强力碰撞和冲击。
※ 灯头既可固定在灯体或其他支撑物上使用,也可方便地卸下手持使用;选配三脚架,灯头可在1.2~3米高度范围内任意升降。
※ 外形美观,结构紧凑,装有方便移动的轮子和手拖带,使用方便。
※ adopts special gas discharge light source, high luminous efficiency, long life, energy saving and environmental protection.
※ high-energy no memory battery can be charged at any time, one time charge within six months after the storage capacity of not less than 85% of full capacity, storage capacity of not less than two years full capacity of 55%, and a low voltage discharge protection, reliable protection battery overcharge and over discharge.
The whole lamp adopts full sealing process design, waterproof and dustproof; special alloy shell and bulletproof glue casing to ensure that the lamp can withstand the collision and impact strength.
The lamp can be fixed on the lamp body or other support, but also can be conveniently disassembled for handheld use; option three tripod, lamp holder can lift in 1.2 ~ 3 meters height range.
The beautiful appearance, compact structure, a convenient moving wheels and hand towing, easy to use.
技术参数:
额定电压 DC24V
电池容量 18Ah
光源额定功率 35W
光源光通量 3200 lm
光源平均使用寿命 10000h
连续工作时间 >10h
充电时间: 12h(正常使用后)/ ≥16h(电池耗尽后)
电池使用寿命 约1000(循环)
外形尺寸 271× 227×568mm
重量 15kg
外壳防护等级 IP65
- 电话:15067779037
- 传真:0577-61719511
- email:20502026@qq.com
更多内容请访问 xiaojing0316(http://home.gongkong.com/profile/?uid=2013071516161100001)
FW6100GC-J强光泛光工作灯,防水防尘泛光工作灯
