当前页面: 首页 >供求信息 >WRA960-24 DRA480-24 DRA300-24
供稿:modulepower 2013/6/18 23:23:54
人气:12
  • 型号:DRA480-24
  • 数量:200
  • 制造商:CHINFA
  • 有效期:2027/4/24 0:00:00
DRA480-24 DRA480-48
Features:
? AC/DC DIN Rail mountable power supply
? Compact design
? High efficiency up to 90%
? Active P.F.C. function
? Parallel function available (switch)
? Universal input voltage
? 3 years warranty
CASE SIZE
 Screw Terminal Type:
 124.5 x 175.5 x 123.6mm ( 4.9 x 6.91 x 4.87 inches )
 Detachable Connector Type:
 143.5 x 175.5 x 123.6mm ( 5.65 x 6.91 x 4.87 inches)
CASE MATERIAL
 Metal
WEIGHT
 1920g
WRA960-24 WRA960-48
Features:
? 3 phase AC input voltage
? Compact design
? High efficiency up to 93%
? 3 years warranty
CASE SIZE
 126.2 x 275.8 x 118.8mm ( 4.97 x 10.86 x 4.68 inches )
CASE MATERIAL
 Metal
WEIGHT
 3400g
MODEL NO.
INPUT
VOLTAGE
OUTPUT
VOLTAGE
OUTPUT
CURRENT
EFF.
(min.)
EFF.
(typ.)
***   Single Output Models  ***
 WRA960-24
 3? 340~575 VAC
 + 24 VDC
40 A
90%
92%
 WRA960-24L
 3? 340~575 VAC
 + 24 VDC
40 A
90%
92%
 WRA960-48
 3? 340~575 VAC
 + 48 VDC
20 A
91%
93%
WRA480-24   WDR480-48
Features:
? 3 phase AC Input voltage
? Compact design
? High efficiency up to 91%
? 3 years warranty
CASE SIZE
 124 x 150 x 118.8mm ( 4.88 x 5.91 x 4.68 inches )
CASE MATERIAL
 Metal
WEIGHT
 1720g
MODEL NO.
INPUT
VOLTAGE
OUTPUT
WATTAGE
OUTPUT
VOLTAGE
OUTPUT
CURRENT
EFF.
(min.)
EFF.
(typ.)
 WRA480-24
 3? 340~575 VAC
 480 WATTS
 + 24 VDC
20 A
88%
90%
 WRA480-48
 3? 340~575 VAC
 480 WATTS
 + 48 VDC
10 A
89%
91%
  • 电话:0755-61672087
  • 传真:0755-61672087-3
  • email:sun520sun@hotmail.com
更多内容请访问 modulepower(http://home.gongkong.com/profile/?uid=2011022315014300001)
