当前页面: 首页 >供求信息 >BXD防爆动力配电箱
BXD防爆动力配电箱
供稿:mgx918918 2013/5/14 15:47:00
人气:36
  • 型号:BXD
  • 数量:10000
  • 制造商:顺新
  • 有效期:2027/4/24 0:00:00
BXD防爆动力配电箱 BXM防爆照明动力配电箱 防爆动力电器箱厂家 防爆动力电器箱多少钱
一、BXD防爆动力配电箱产品特点Features
1、转盘及防爆插销壳体为铸铝合金•表面喷塑:
2、内可装带漏电保护小型断路器;
3、插销上有分、合指示•插头上接地触头比主触头长, 插入时接地触头先接•拔脱时,接地触头后脱离;
4、插座与插头设有联锁装置.断电后方能插拔:
5、电缆盘转动炅活,移动时有托架及行走轮.移动方便
6、电缆长度标准配置为30米,可根据要求加长至100米:
7、电缆布线。
1、The rotary plate and the enclosure of explosion-proof bolt are cast with aluminium alloy, the surface is sprayed with plastic;
2、Built-in creepage protection mini circuit breaker:
3、There are open&close indication, the earthing contact is longer than the main contact, when pluging. the earth plug first; when pulling out.die earth contact later;
4、The sockct and plug arc interlocked, so they arc drawn out after cutting (he power;
5、The cable plate can be turned actively and moved easily because of the bracket and moving wheels;
6、Cable length (standard): 30m.the length can be added to 100m on request:
7、Wiring with cable.
三、BXD防爆动力配电箱主要技术参数 Main technical parameters
二、BXD防爆动力配电箱适用范围Applications
1、I区、2区危检场所:
2、II A. IIB类爆炸性气体环境;
4、户内、户外(IP54,    IP65*)
1、Hazardous : division I&2;
2、Explosive gas atmospheres : class II A, IIB;
3、Indoor or outdoor (IP54.IP65*).
额定电流(A)
额定电压
带总开关电流(A)
防爆标志
防护等级
出线口螺纹
电缆外径
16x2
220/380
32
Exde II BT6
IP54
3/4
10-14
32x2
63
ExdeIIBT5/T4
IP65#
1 1/4
18-22
•:订货时需提出
乐清市顺新防爆专业生产防爆电器设备,欢迎来询主要产品:
防爆电器类:防爆空调,防爆除湿机,防爆电铃,防爆插接装置,防爆插销,防爆镇流器,防爆变压器,防爆轴流屋顶风机,防爆照明开关,防爆断路器,防爆控制箱,防爆配电柜,防爆检修电源插座箱,防爆动力电磁启动配电箱,防爆照明动力配电箱,防爆检修箱,防爆操作柱
  • 电话:13588991453
  • 传真:0577-62618387
  • email:2683508593@qq.com
