当前页面: 首页 >供求信息 >防爆检修电缆盘
防爆检修电缆盘
供稿:mgx918918 2013/5/14 15:40:14
人气:95
  • 数量:10000
  • 制造商:顺新
  • 有效期:2027/4/24 0:00:00
一、防爆检修电缆盘适用范围Applications
1、I区、2区危检场所:
2、II A. IIB类爆炸性气体环境;
4、户内、户外(IP54,    IP65*)
1、Hazardous : division I&2;
2、Explosive gas atmospheres : class II A, IIB;
3、Indoor or outdoor (IP54.IP65*).
 二、防爆检修电缆盘产品特点Features
1、转盘及防爆插销壳体为铸铝合金•表面喷塑:
2、内可装带漏电保护小型断路器;
3、插销上有分、合指示•插头上接地触头比主触头长, 插入时接地触头先接•拔脱时,接地触头后脱离;
4、插座与插头设有联锁装置.断电后方能插拔:
5、电缆盘转动炅活,移动时有托架及行走轮.移动方便
6、电缆长度标准配置为30米,可根据要求加长至100米:
7、电缆布线。
1、The rotary plate and the enclosure of explosion-proof bolt are cast with aluminium alloy, the surface is sprayed with plastic;
2、Built-in creepage protection mini circuit breaker:
3、There are open&close indication, the earthing contact is longer than the main contact, when pluging. the earth plug first; when pulling out.die earth contact later;
4、The sockct and plug arc interlocked, so they arc drawn out after cutting (he power;
5、The cable plate can be turned actively and moved easily because of the bracket and moving wheels;
6、Cable length (standard): 30m.the length can be added to 100m on request:
7、Wiring with cable.
三、防爆检修电缆盘主要技术参数 Main technical parameters
额定电流(A)
额定电压
带总开关电流(A)
防爆标志
防护等级
出线口螺纹
电缆外径
16x2
220/380
32
Exde II BT6
IP54
3/4
10-14
32x2
63
ExdeIIBT5/T4
IP65#
1 1/4
18-22
•:订货时需提出
乐清市顺新防爆专业生产防爆电器设备,欢迎来询主要产品:
防爆电器类:防爆空调,防爆除湿机,防爆电铃,防爆插接装置,防爆插销,防爆镇流器,防爆变压器,防爆轴流屋顶风机,防爆壁式排风扇,防爆轴流风机,防爆吊风扇,防爆变频调速箱,防爆软起动器,防爆自耦减压电磁起动箱,防爆综合电磁起动器,防爆电磁起动器,防爆控制按钮,防爆行程开关,防爆转换开关,防爆照明开关,防爆断路器,防爆控制箱,防爆配电柜,防爆检修电源插座箱,防爆动力电磁启动配电箱,防爆照明动力配电箱,防爆检修箱,防爆操作柱
  • 电话:13588991453
  • 传真:0577-62618387
  • email:2683508593@qq.com
