当前页面: 首页 >供求信息 >广州莱捷电器有限公司 代理销售 ORTEC核电子学仪器
供稿:gzlaijie 2012/8/1 17:36:14
人气:58
  • 有效期:2027/4/24 0:00:00
ORTEC核电子学仪器
广州莱捷电器有限公司
广州莱捷电器有限公司代理销售ORTEC核电子学仪器
产品描述:
 ORTEC核电子学仪器种类齐全,性能稳定,为广大科研工作者提供了最广泛的选择,在国内外都以得到广泛应用。
PL Subsection Name Amplifiers
FTA820A
Octal Fast-Timing Amplifier (200 gain, non-inverting)
427A
Delay Amplifier
460
Delay Line Amplifier (with standard 1-μs delay lines)
474
Timing Filter Amplifier
533
Dual Sum and Invert Amplifier
570
Spectroscopy Amplifier
572A
575A
579
Fast-Filter Amplifier
590A
Amplifier and Timing SCA
671
672
Spectroscopy Amplifier (with AUTO-PZ)
673
Spectroscopy Amplifier and Gated Integrator
855
Dual Spectroscopy Amplifier
863
Quad Timing Filter Amplifier
9302
Amplifier and Discriminator
9327
1-GHz Amplifier and Timing Discriminator
Counters, Timers, and Ratemeters
Model No.
Description
449
Log/Lin Ratemeter
449-2
Log/Lin Ratemeter with audible output option
661
Ratemeter
871
Timer and Counter (non-printing)
974
CCNIM Quad 100-MHz Counter/Timer
994
CCNIM Dual Counter and Timer (requires interface option for computer operation)
995
CCNIM Dual Counter (requires interface option for computer operation)
996
CCNIM Timer and Counter (requires interface option for computer operation)
99X-1
994, 995, and 996 Options - RS-232-C Interface Option (requires C-75 Cable)
99X-2
994, 995, and 996 Options - IEEE-488 Interface Option (requires C-488-2 or C-488-4 Cable)
99X-4
994 and 995 Options - Internal +6 V Supply Option
9349
Log/Lin Ratemeter
Delays, Gate and Delay Generators, Logic Modules, and Linear Gates
Model No.
Description
CO4020
Quad 4-Input Logic Unit (requires 6 V)
DB463
Delay Box
GG8020
Octal Gate and Delay Generator (requires 6 V)
414A
Fast Coincidence
416A
418A
Universal Coincidence
425A
Nanosecond Delay
426
Linear Gate
542
Linear Gate and Stretcher
Fast-Timing Discriminators
Model No.
Description
CF8000
Octal Constant-Fraction Discriminator
CFD-DELAY-5NS
Delay Plug-in (CF8000 Options)
CFD-DELAY-10NS
Delay Plug-in
CFD-DELAY-30NS
Delay Plug-in
CFD-DELAY-50NS
Delay Plug-in
583B
Constant-Fraction Differential Discriminator/SCA (requires 6 V)
584
935
Quad 200-MHz Constant-Fraction Discriminator (requires 6 V)
9302
9307
pico-TIMING Discriminator (requires 6 V)
HV Bias/NIM Power Supplies and Bins
Model No.
Description
428
Detector Bias Supply
495
Power Supply (6 V)
556
High-Voltage Power Supply (3 kV)
556H
659
5-kV Detector Bias Supply
660
Dual 5-kV Detector Bias Supply
710
Quad 1-kV Bias Supply
4001A
NIM Bin
4001A/4002A
NIM Bin and 96-W Power Supply (with ±12 V, ±24 V)
4001A/4002D
NIM Bin and 160-W Power Supply (with ±6 V, ±12 V, ±24 V)
4001C
NIM Bin (with copper bus bars)
4001C/4002D
NIM Bin (with copper bus bars) and 160-W Power Supply (with ±6 V, ±12 V, ±24 V)
4001C/4002E
NIM Bin (with copper bus bars) and BLACK MAX PS (with ±6 V, ±12 V, ±24 V)
4002A
96-W Power Supply for NIM Bin (with ±12 V, ±24 V)
4002D
160-W Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V)
4002E
BLACK MAX Power Supply for NIM Bin (with ±6 V, ±12 V, ±24 V)
4002P
Portable Power Supply (with ±12 V, ±24 V)
4002P-C1
Preamp Power Fan-Out Cable (for 4002P)
4003
Preamplifier Power Output
4006
Mini Bin and Power Supply
NIM MCA/MCB,PCI Card MCA
Model No.
Description
919E
EtherNIM 4-Input Multichannel Buffer
919-OPT1
Pigtail Cable
920E
EtherNIM 16-Input Multichannel Buffer
920-16-OPT1
Pigtail Cable
921E
EtherNIM High-Rate Multichannel Buffer
926
8k ADCAM Multichannel Buffer
926-M32
8k ADCAM Multichannel Buffer with MAESTRO-32 Software
926-USB
8k ADCAM Multichannel Buffer with USB Interface
926-M32-USB
8k ADCAM Multichannel Buffer with USB Interface and MAESTRO-32 Software
926-C-2
Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 2-ft length
926-C-10
Interface and Cable for NIM MCB - Printer Port Cable, male to female, 25 pin conductor; 10-ft length
ASPEC-927
Dual 16k Multichannel Buffer with MAESTRO-32 Software and 10-ft. USB Cable
DPM-USB
Dual-Port Memory to USB Interface Converter, 15-ft. Cable
918-OPTC5
Dual-Port Memory Cable, 5-ft shielded ribbon cable
C-DPM-10
Dual-Port Memory Cable, 10-ft shielded ribbon cable
918A-OPTB
PC-Bus Interface
TRUMP-PCI-2K
2k MCA PCI Plug-In Card with MAESTRO-32 Software
TRUMP-PCI-8K
8k MCA PCI Plug-In Card with MAESTRO-32 Software
CAMAC ADCs and Memory
Model No.
Description
AD114
CAMAC 16k ADC
AD413A
CAMAC Quad 8k ADC
CMC203
CAMAC FERA Driver, Memory, and Histogrammer
HM413
CAMAC FERAbus Histogramming Memory
C-ECLBUS
Cable Kit for FERAbus readout with Models AD114, AD413A, CMC203, and HM413
Multichannel Scalers and/or Multiple-Stop Time Spectrometers
Model No.
Description
MCS-PCI
Multichannel Scaler with A73-B32 software, documentation, and FullShot software
MCS-PCI-OPT2
Fan-Out Cable for MCS-PCI
9353
100-ps Time Digitizer/MCS with 9353-B32 software
9353-FANOUT
Fan-out Cable for the 9353 9-pin D Connector
Pulse Generators
Model No.
Description
419
Precision Pulse Generator
480
Pulser
Special Instruments
Model No.
Description
439
Digital Current Integrator
Single-Channel Pulse-Height Analyzers
Model No.
Description
550A
Single-Channel Analyzer
551
Timing Single-Channel Analyzer
552
Pulse-Shape Analyzer/Timing SCA
850
Quad Single-Channel Analyzer (requires 6 V)
Time-to-Amplitude Converters and Time Calibrator
Model No.
Description
462
Time Calibrator
566
567
Time-to-Amplitude Converter/SCA
  • 电话:020-87268766
  • 传真:020-87268766
  • email:gzlaijie@163.com
