当前页面: 首页 >供求信息 >BXC防爆检修电源插座箱|隔爆插座箱配件|防爆电源插座箱
供稿:jingjing818 2011/11/16 11:50:17
人气:10
  • 型号:XC
  • 数量:100000000
  • 制造商:防爆检修电源插座箱
  • 有效期:2027/4/24 0:00:00
BXC防爆检修电源插座箱\XC防爆检修电源插座箱
手机:15958771970
电话:0577-57572534
QQ:1067075748
邮箱:1067075748@qq.com
网址:http://www.xqfbex.com/
  适用范围:
1. 爆炸性气体环境危险场所:1区、2区;
2. 可燃性气体、蒸气级别:ⅡA、ⅡB、ⅡC;
3. 温度组别:T1~T6;
4. 户内、户外(IP54)。
1. For the dangerous sites with explosive air mixture:
1 division, 2 division;
2. Flammable gas, steam class: ⅡA、ⅡB、ⅡC;
3. Temperatures classification: T1~T6;
4. Indoor and outdoor (IP54).
1. 铸铝合金外壳,表面喷塑;
2. 插座上带有分合指示;
3. 支路极数及电流可混合设置,便于检修用电源;
4. 可带有总开关及带漏电保护分开关,具有过载,
短路保护功能;
5. 可根据用户要求特制;
6. 符合GB3836-2000、IEC60079, GB12476.1-2000、
IEC61241标准要求。
   1. Diecasted of Al-alloy shell with and plastic-sprayed surface;
2. Socket has open-close indicator;
3. Branch pole number and current mixed divice is convenient to maintain current;
4. Can be matched with general switch for protecting the circuit from the damages of overload and short;
5. Can be customized according to user s requirements.
6. Suitabe for GB3836-2000、IEC60079、GB12476.1-2000、IEC61241 standard request.
  • 电话:0577-57572534
  • 传真:0577-57572534
  • email:870174748@qq.com
更多内容请访问 jingjing818(http://home.gongkong.com/profile/?uid=2011111215415000001)
