当前页面: 首页 >供求信息 >1FT6084、1FK7101系列维修找天津大成恒业.电话:13910546327
供稿:dachenghengye 2009/5/4 11:10:29
人气:58
  • 型号:1FT6084-8AK71-3AG2 、1FK7103-5AF71-1AH0
  • 数量:大量
  • 制造商:西门子
  • 有效期:2027/4/24 0:00:00
1FK7083、1FK7100、系列维修找天津大成恒业机电设备有限公司
1FK7083-5AF71-1AA0 16Nm,3000rpm,incremental encoder, with fitted key and keyway
1FK7083-5AF71-1AG0 16Nm,3000rpm,incremental encoder, plain shaft
1FK7083-5AF71-1AH0 16Nm,3000rpm,incremental encoder, plain shaft,with brake
1FK7083-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 16NM,without brake
1FK7083-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 16NM,with brake
1FK7083-5AF71-1SG0 16Nm,3000rpm, 8-POLE resolver [RESOLVER P=4],plain shaft
1FK7083-5AF71-1SH0 16Nm,3000rpm, 8-POLE resolver [RESOLVER P=4],plain shaft, BRAKE
1FK7100-5AF71-1AG0 18Nm,3000rpm,incremental encoder,plain shaft
1FK7100-5AF71-1AH0 18Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7100-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 18NM,without brake
1FK7100-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 18NM,with brake
1FK7100-5AF71-1SG0 18Nm,3000RPM,8-POLE resolver [RESOLVER P=4], plain shaft
1FK7100-5AF71-1SH0 18Nm,3000RPM,8-POLE resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7100-5AF71-1TG0 18NM,3000rpm, 2-POLE resolver [RESOLVER P=1], plain shaft
1FK7101-5AF71-1AA0 27Nm,3000rpm,incremental encoder,with fitted key and keyway
1FK7101-5AF71-1AG0 27Nm,3000rpm,incremental encoder,plain shaft
1FK7101-5AF71-1AH0 27Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7101-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 27NM,without brake
1FK7101-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 27NM,with brake
1FK7101-5AF71-1SG0 27Nm,300rpm, 8-pole resolver [RESOLVER P=4], plain shaft
1FK7101-5AF71-1SH0 27Nm,300rpm, 8-pole resolver [RESOLVER P=4], plain shaft, BRAKE
1FK7103-5AF71-1AA0 36Nm,3000rpm,incremental encoder,with fitted key and keyway
1FK7103-5AF71-1AG0 36Nm,3000rpm,incremental encoder,plain shaft
1FK7103-5AF71-1AH0 36Nm,3000rpm,incremental encoder,plain shaft,with brake
1FK7103-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 36NM,without brake
1FK7103-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 36NM,with brake
1FK7103-5AF71-1SG0 36Nm,plain shaft
1FK7103-5AF71-1SH0 36Nm,plain shaft,with brake
1FK7105-5AF71-1DG5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 45NM,without brake
1FK7105-5AF71-1DH5 3000RPM,Inc Encoder,IP65,D.E: IP67,paint, 45NM,with brake
1FT5102-1AA71-4FA0 33NM/1200RPM/ROD320
1FT5102-1AC71-1FA0 33NM/2000RPM/ ADDTIONALLY INSTALLED ROD320 2500 P/REV
1FT6084-8AK71-3AG2 20Nm,600rpm, IM B5, I-2048, plain shaft
  • 电话:010-65431486
  • 传真:010-88603269-8005
  • email:dchyldm@163.com
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
