当前页面: 首页 >供求信息 >现货供应ABB所有系列变频器,ACS510/550/800
供稿:顾先东_17 2009/3/19 20:27:42
人气:395
  • 型号:ACS800-01-0003-3+P901
  • 数量:100000
  • 制造商:日本
  • 有效期:2027/4/24 0:00:00
以下为部分产品型号以及参数供大家参考,详情请来电咨询!  谢谢!
3ABD00015741-D ACS510-01-03A3-4 1.1 3.3 R1
3ABD00015742-D ACS510-01-04A1-4 1.5 4.1
3ABD00015743-D ACS510-01-05A6-4 2.2 5.6
3ABD00015744-D ACS510-01-07A2-4 3 7.2
3ABD00015745-D ACS510-01-09A4-4 4 9.4
3ABD00015746-D ACS510-01-012A-4 5.5 11.9
ACS800-01-0025-3+P901 ACS510-01-017A-4 7.5 17 R2
ACS800-01-0030-3+P901 ACS510-01-025A-4 11 25
3ABD00015749-D ACS510-01-031A-4 15 31 R3
3ABD00015750-D ACS510-01-038A-4 18.5 38
3ABD00021615-D ACS510-01-046A-4 22 46
3ABD00015752-D ACS510-01-060A-4 30 60 R4
3ABD00015753-D ACS510-01-072A-4 37 72
3ABD00021616-D ACS510-01-088A-4 45 88
3ABD00019055-D ACS510-01-125A-4 55 125 R5
3ABD00015756-D ACS510-01-157A-4 75 157 R6
3ABD00015757-D ACS510-01-180A-4 90 180
3ABD00015758-D ACS510-01-195A-4 110 205
3ABD00022031-D ACS510-01-246A-4 132 245
输入电压: 三相AC380V-480V(频率:50/60Hz;价格不含控制盘;防护等级 IP54)
    Square Torque Frame
Code No. Type 平方转矩应用 Size
产品代号 产品型号 PNkW                I2NA                           规格
      电机额定功率 额定输出电流
3ABD00015759-D ACS510-01-03A3-4+B055 1.1 3.3 R1
3ABD00015760-D ACS510-01-04A1-4+B055 1.5 4.1
3ABD00015761-D ACS510-01-05A6-4+B055 2.2 5.6
3ABD00015762-D ACS510-01-07A2-4+B055 3 7.2
3ABD00015763-D ACS510-01-09A4-4+B055 4 9.4
3ABD00015764-D ACS510-01-012A-4+B055 5.5 11.9
3ABD00015765-D ACS510-01-017A-4+B055 7.5 17 R2
3ABD00015766-D ACS510-01-025A-4+B055 11 25
3ABD00015767-D ACS510-01-031A-4+B055 15 31 R3
3ABD00015768-D ACS510-01-038A-4+B055 18.5 38
3ABD00021617-D ACS510-01-046A-4+B055 22 46
3ABD00015770-D ACS510-01-060A-4+B055 30 60 R4
3ABD00015771-D ACS510-01-072A-4+B055 37 72
3ABD00021618-D ACS510-01-088A-4+B055 45 88
3ABD00019056-D ACS510-01-125A-4+B055 55 125 R5
3ABD00015774-D ACS510-01-157A-4+B055 75 157 R6
3ABD00015775-D ACS510-01-180A-4+B055 90 180
3ABD00015776-D ACS510-01-195A-4+B055 110 205
3ABD00022032-D ACS510-01-246A-4+B055 132 245
ACS510可选项  Option
Code No. Option Name Type
产品代号 可选项名称 产品型号
3ABD64739000 基本控制盘  Basic Control Panel    ACS-CP-C
3ABD68232902 高级中文控制盘  Assistant Control Panel for Asia ACS-CP-D
3ABD68294673 螺钉式控制盘安装组件,含一根3米长电缆,一个密封垫, ACS/H-CP-EXT
固定螺钉和安装模板
3ABD00014656 托架式控制盘安装组件,含一根3米长电缆,一个塑料固定 ACS/H-CP-CABINET
托架
3ABD68300029 控制盘3米连线 OCAT-02
3AUA0000002040-D 继电器输出扩展模块 Relay output extension OREL-01
3AUA0000003489-D (110/230V)/24V数字输入转换模块 OHDI-01
制动斩波器(外装)和制动电阻  Brake choppers(separate kit) and brake resistor
3ABD00017551 法兰安装件用于R1         Flange Mounting Set, R1 FMS-R1
3ABD00017550 法兰安装件用于R2         Flange Mounting Set, R2 FMS-R2
3ABD00017549 法兰安装件用于R3         Flange Mounting Set, R3 FMS-R3
3ABD00017548 法兰安装件用于R4        Flange Mounting Set, R4 FMS-R4
3ABD00017552 法兰安装件用于R5         Flange Mounting Set, R5 FMS-R5
3ABD00017553 法兰安装件用于R6       Flange Mounting Set, R6 FMS-R6
输出滤波器  du/dt Filter
Type Output Choke
产品型号 输出滤波器型号
ACS510-01-03A3-4 NOCH0016-6X
ACS510-01-04A1-4
ACS510-01-05A6-4
ACS510-01-07A2-4
ACS510-01-09A4-4
ACS510-01-012A-4
ACS510-01-017A-4
ACS510-01-025A-4 NOCH0030-6X
ACS510-01-031A-4
ACS510-01-038A-4
ACS510-01-046A-4 NOCH0070-6X
ACS510-01-060A-4
ACS510-01-072A-4
ACS510-01-088A-4
ACS510-01-125A-4 NOCH0120-6X
ACS510-01-157A-4 FOCH0260-70
ACS510-01-180A-4
ACS510-01-195A-4
ACS510-01-246A-4
Code No. Type 一般应用 重载应用   Size Chopper
产品代号 产品型号 PNkW  I2NA  PNkW  I2NA 规格 制动斩波器
    电机额定功率  额定输出电流 电机额定功率 额定输出电流
3AUA0000003385-D ACS550-01-03A3-4 1.1 3.3 0.75 2.4 R1 内含
3AUA0000003386-D ACS550-01-04A1-4 1.5 4.1 1.1 3.3
3AUA0000003387-D ACS550-01-05A4-4 2.2 5.4 1.5 4.1
3AUA0000002415-D ACS550-01-06A9-4 3 6.9 2.2 5.4
3AUA0000002419-D ACS550-01-08A8-4 4 8.8 3 6.9
3AUA0000002420-D ACS550-01-012A-4 5.5 11.9 4 8.8
3AUA0000002412-D ACS550-01-015A-4 7.5 15.4 5.5 11.9 R2
ACS800-01-0025-3+P901 ACS550-01-023A-4 11 23 7.5 15.4
ACS800-01-0030-3+P901 ACS550-01-031A-4 15 31 11 23 R3 无内含
3AUA0000002431-D ACS550-01-038A-4 18.5 38 15 31
3AUA0000012789-D ACS550-01-045A-4 22 45 18.5 38
3AUA0000002546-D ACS550-01-059A-4 30 59 22 44 R4
3AUA0000002547-D ACS550-01-072A-4 37 72 30 59
3AUA0000013108-D ACS550-01-087A-4 45 87 37 77
3ABD68589657 ACS550-01-125A-4 55 125 45 96 R5
3ABD64726820 ACS550-01-157A-4 75 157 55 124 R6
3ABD64726838 ACS550-01-180A-4 90 180 75 156
3ABD68294479 ACS550-01-195A-4 110 205 90 162
3AUA0000014490-D ACS550-01-246A-4 132 245 110 192
输入电压: 三相AC380V~480V(频率: 50/60Hz;价格不含控制盘;防护等级 IP54
    Normal Use Heavy Duty Use  Frame Brake
3AUA0000004217-D ACS550-01-03A3-4+B055 1.1 3.3 0.75 2.4 R1 内含
3AUA0000004220-D ACS550-01-04A1-4+B055 1.5 4.1 1.1 3.3
3AUA0000004223-D ACS550-01-05A4-4+B055 2.2 5.4 1.5 4.1
3AUA0000004224-D ACS550-01-06A9-4+B055 3 6.9 2.2 5.4
3AUA0000004227-D ACS550-01-08A8-4+B055 4 8.8 3 6.9
3AUA0000004230-D ACS550-01-012A-4+B055 5.5 11.9 4 8.8
3AUA0000004233-D ACS550-01-015A-4+B055 7.5 15.4 5.5 11.9 R2
3AUA0000004236-D ACS550-01-023A-4+B055 11 23 7.5 15.4
3AUA0000004239-D ACS550-01-031A-4+B055 15 31 11 23 R3 无内含
3AUA0000004242-D ACS550-01-038A-4+B055 18.5 38 15 31
3AUA0000012787-D ACS550-01-045A-4+B055 22 45 18.5 38
3AUA0000004248-D ACS550-01-059A-4+B055 30 59 22 44 R4
3AUA0000004251-D ACS550-01-072A-4+B055 37 72 30 59
3AUA0000013240-D ACS550-01-087A-4+B055 45 87 37 77
3ABD68632994 ACS550-01-125A-4+B055 55 125 45 96 R5
3ABD68265312 ACS550-01-157A-4+B055 75 157 55 124 R6
3ABD68265339 ACS550-01-180A-4+B055 90 180 75 156
3ABD68294487 ACS550-01-195A-4+B055 110 205 90 162
3AUA0000015782-D ACS550-01-246A-4+B055 132 245 110 192
控制盘、连线和安装组件 Control Panel/Cable/Mounting Platform
产品代号 可选项名称 产品型号
3ABD64738984 HVAC 控制盘  HVAC Control Panel ACH-CP-B
3ABD68294673 螺钉式控制盘安装组件,含一根3米长电缆,一个密封垫,固定螺钉和安装模板 ACS/H-CP-EXT
3ABD00014656 托架式控制盘安装组件,含一根3米长电缆,一个塑料固定托架 ACS/H-CP-CABINET
可选适配器模块 Option Modules
产品代号 可选项名称 产品型号
3AUA0000003489-D (110/230V)/24V 数字输入转换模块 110/230 V Digital Input Module OHDI-01
3AUA0000002051-D 脉冲编码器接口模块 Pulse Encoder Interface Module OTAC-01
参见ACS800 总线适配器DeviceNet Adapter RDNA-01
参见ACS800 总线适配器LonWorks Adapter RLON-01
参见ACS800 总线适配器Profibus DP Adapter RPBA-01
参见ACS800 总线适配器CANOpen Adapter  RCAN-01
参见ACS800 总线适配器ControlNet Adapter RCNA-01
参见ACS800 总线适配器Ethernet Adapter RETA-01
输出滤波器 du/dt filter
Type
产品型号
ACS550-01-03A3-4 NOCH0016-6X
ACS550-01-04A1-4
ACS550-01-05A4-4
ACS550-01-06A9-4
ACS550-01-08A8-4
ACS550-01-012A-4
ACS550-01-015A-4
ACS550-01-023A-4 NOCH0030-6X
ACS550-01-031A-4
ACS550-01-038A-4
ACS550-01-045A-4 NOCH0070-6X
ACS550-01-059A-4
ACS550-01-072A-4
ACS550-01-087A-4
ACS550-01-125A-4 NOCH0120-6X
ACS550-01-157A-4 FOCH0260-70
ACS550-01-180A-4
ACS550-01-195A-4
ACS550-01-246A-4
额外加装EMC滤波器 EMC Filter
Code No. Type Remark
产品代号 型号 备注
3ABD63998702 ACS400-IF11-3 ACS550 R1,EMC filter, max cable length 100 m
3ABD63998711 ACS400-IF21-3 ACS550 R2,EMC filter, max cable length 100 m
3ABD64058401 ACS400-IF31-3 ACS550 R3,EMC filter, max cable length 100 m
3ABD64058428 ACS400-IF41-3 ACS550 R4,EMC filter, max cable length 100 m
3ABD64278118 ACS400-IF22-3 ACS550 IP21 R1/2, EMC filter, max.cable length 10 m
调试工具 Commissioning Tools
Code No. Name and Description Type
产品代号 名称及描述 型号
3ABD64532871  DriveWindow Light 最新正版软件并包含 OPCA-02连线 DriveWindow Light
3ABD68239745 计算机与ACS550 连线 PC-drive Cable Connection OPCA-02
制动斩波器和制动电阻 Brake Chopper & Brake Resistor
Type 制动斩波器 外置 制动电阻 斩波器和电阻
产品型号 配置 制动斩波器 型号 一体式套件
ACS550-01-03A3-4 内置标配 不需要 CBR-V 210 DT 281 200R
ACS550-01-04A1-4 内置标配 不需要 CBR-V 210 DT 281 200R
ACS550-01-05A4-4 内置标配 不需要 CBR-V 210 DT 281 200R
ACS550-01-06A9-4 内置标配 不需要 CBR-V 460 DT 281 80R
ACS550-01-08A8-4 内置标配 不需要 CBR-V 460 DT 281 80R
ACS550-01-012A-4 内置标配 不需要 CBR-V 460 DT 281 80R
ACS550-01-015A-4 内置标配 不需要 CBR-V 460 DT 281 80R
ACS550-01-023A-4 内置标配 不需要 CBR-V 460 DT 281 80R
ACS550-01-031A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - C
ACS550-01-038A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - D
ACS550-01-045A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - D
ACS550-01-059A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - D
ACS550-01-072A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - D
ACS550-01-087A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800 ACS - BRK - D
ACS550-01-125A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800
ACS550-01-157A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800
ACS550-01-180A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800
ACS550-01-195A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800
ACS550-01-246A-4 外置可选 NBRA系列(参考ACS800 匹配NBRA(参考ACS800
ACS - BRK - CACS - BRK - DCBR-V系列电阻及其防护外罩转主菜单选 CompAC Options
ACS5X0-07-03A3-4 R1
ACS5X0-07-04A1-4
ACS5X0-07-05A6-4
ACS5X0-07-07A2-4
ACS5X0-07-09A4-4
ACS5X0-07-012A-4
ACS800-01-0025-3+P901 R2
ACS5X0-07-031A-4 R3
ACS5X0-07-038A-4
ACS5X0-07-045A-4 R4
ACS5X0-07-060A-4
ACS5X0-07-072A-4
ACS5X0-07-096A-4 R5
ACS5X0-07-124A-4 R6
ACS5X0-07-157A-4
ACS5X0-07-180A-4
ACS5X0-07-195A-4
ACS5X0-07-012A/012A-4 2*R1
ACS5X0-07-012A/025A-4 1*R1+1*R2
ACS5X0-07-025A/025A-4 2*R2
ACS800-01-0004-3+P901
ACS800-01-0005-3+P901
ACS800-01-0006-3+P901
ACS800-01-0009-3+P901
ACS800-01-0011-3+P901
ACS800-01-0016-3+P901
ACS800-01-0020-3+P901
ACS800-01-0040-3+P901
ACS800-01-0050-3+P901
ACS800-01-0060-3+P901
ACS800-01-0075-3+P901
ACS800-01-0070-3+P901
ACS800-01-0100-3+P901
ACS800-01-0120-3+P901
ACS800-01-0135-3+P901
ACS800-01-0165-3+P901
ACS800-01-0004-5+P901
ACS800-01-0005-5+P901
ACS800-01-0006-5+P901
ACS800-01-0009-5+P901
ACS800-01-0011-5+P901
ACS800-01-0016-5+P901
ACS800-01-0020-5+P901
ACS800-01-0025-5+P901
ACS800-01-0030-5+P901
ACS800-01-0040-5+P901
ACS800-01-0050-5+P901
ACS800-01-0060-5+P901
ACS800-01-0070-5+P901
ACS800-01-0105-5+P901
ACS800-01-0100-5+P901
ACS800-01-0120-5+P901
ACS800-01-0140-5+P901
ACS800-01-0165-5+P901
ACS800-01-0205-5+P901
ACS800-01-0011-7+P901
ACS800-01-0016-7+P901
ACS800-01-0020-7+P901
ACS800-01-0025-7+P901
ACS800-01-0030-7+P901
ACS800-01-0040-7+P901
ACS800-01-0050-7+P901
ACS800-01-0060-7+P901
ACS800-01-0070-7+P901
ACS800-01-0100-7+P901
ACS800-01-0120-7+P901
ACS800-01-0145-7+P901
ACS800-01-0175-7+P901
ACS800-01-0205-7+P901
  • 电话:0512-82098825
  • 传真:0512-82098825
  • email:hy07990@163.com
更多内容请访问 顾先东_17(http://home.gongkong.com/profile/?uid=2008072618060000001)
