- 型号:C200H-ID215
- 数量:10000
- 制造商:法国
- 有效期:2027/4/24 0:00:00
欧姆龙电气自动化产品,全国区域指定一级代理! 欢迎各位顾客的来电垂寻..
部分型号如下:
| C200H-CN222 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200H-OD212 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CP1W-40EDT | SYS-OTHER-CJ | PLC本体 |
| C500-CE404 | SYS-TJ | 数字量输入、输出混合模块 |
| CPM1A-30CDR-A-V1 | SYS-CPM1A-TJ | PLC本体 |
| CP1L-L14DR-A | SYS-TJ | 一体化PLC |
| C200H-PRO27-E | SYS-TJ | 数字量输入、输出混合模块 |
| NT631C-ST153B-EV3 | SYS-NS-CJ | 触摸屏 |
| C500-CE404 | SYS-OTHER-TJ | 数字量输入、输出混合模块 |
| CPM1A-10CDR-A-V1 | SYS-CPM1A-CJ | PLC本体 |
| CQM1H-CPU21 | SYS | CPU单元 |
| CP1L-L14DT-D | SYS-TJ | 一体化PLC |
| C200HW-BC081-V1 | SYS-C200-JXS | 数字量输入、输出混合模块 |
| C200HW-PA204 | SYS-C200-CJ | 电源单元 |
| CP1L-L20DR-D | SYS-TJ | 一体化PLC |
| CJ1W-OD261 | SYS-TJ | 数字量输出模块 |
| CQM1-AD041 | SYS-OTHER-CJ | 模拟量输入、输出混合模块 |
| C200H-CN711 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200HG-CPU43-E | SYS-C200-CJ | CPU单元 |
| CJ1W-ID211 | SYS | 模拟量输入、输出混合模块 |
| CPM2A-20CDT-D | SYS-OTHER-CJ | PLC本体 |
| CJ1W-ID261 | SYS-TJ | 数字量输入模块 |
| CP1L-L14DR-D | SYS-TJ | 一体化PLC |
| CQM1-IPS01 | SYS-TJ | 数字量输入、输出混合模块 |
| FH-3 | SYS-OTHER | PLC本体 |
| CJ1W-AD081-V1 | SYS-OTHER-CJ | 模拟量输入模块 |
| C200HW-BC031 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CQM1H-MAB42 | SYS-OTHER-CJ | 模拟量输入模块 |
| C200HW-BC101-V1 | SYS-TJ | 数字量输入、输出混合模块 |
| NS10-TV00B-ECV2 | SYS-OTHER-DLS | 触摸屏 |
| CPM2A-60CDT-D | SYS-OTHER-CJ | PLC本体 |
| C200H-ID212 | SYS | 分布式I/O |
| CPM1A-40CDR-A-V1 | SYS-CPM1A-CJ | PLC本体 |
| C200H-CN311 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CQM1H-CPU21 | SYS-OTHER-CJ | CPU单元 |
| C200H-ID212 | SYS-C200-CJ | 分布式I/O |
| C200HW-BC051 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200HW-BC081-V1 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200HW-BI081-V1 | SYS-SH | 数字量输入、输出混合模块 |
| CQM1-CIF02(J) | SYS-OTHER-CJ | 连接电缆 |
| CJ1W-PA202 | SYS-TJ | 电源单元 |
| CJ1W-PA202 | SYS-OTHER-CJ | 电源单元 |
| CPM2A-60CDR-A | SYS-OTHER-DLS | PLC本体 |
| C200H-BAT09 | SYS-C200-CJ | 电源单元 |
| CJ1M-CPU23 | SYS-OTHER-CJ | CPU单元 |
| C200H-IA122 | SYS-C200-DLS | 分布式I/O |
| CP1H-X40DT-D | SYS-OTHER-CJ | PLC本体 |
| CPM2AE-60CDR-A | SYS-A | PLC本体 |
| CP1H-X40DR-A | SYS-SH | PLC本体 |
| CJ1W-NC113 | SYS-OTHER-JXS | 其他特殊功能模块 |
| C200H-IA122 | SYS-TJ | 分布式I/O |
| C200H-DA004 | SYS-TJ | 数字量输入模块 |
| C200HW-BI081-V1 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CPM1A-30CDR-A-V1 | SYS-CPM1A-DLS | PLC本体 |
| CJ1W-ID211 | SYS-TJ | 数字量输入模块 |
| CJ1W-OD211 | SYS-OTHER-DLS | 数字量输出模块 |
| C200H-BAT09 | SYS-TJ | 电源单元 |
| CPM2AH-60CDR-A | SYS-OTHER-CJ | PLC本体 |
| C200H-OD212 | SYS-C200-DLS | 数字量输入、输出混合模块 |
| CPM1A-20CDR-A-V1 | SYS-CPM1A-TJ | PLC本体 |
| CPM1A-40CDT-D-V1 | SYS-TJ | PLC本体 |
| C200H-CN131 | SYS-TJ | 数字量输入、输出混合模块 |
| CQM1H-CPU11 | SYS-OTHER-CJ | CPU单元 |
| CPM2A-BAT01 | SYS-OTHER-CJ | 电源单元 |
| CP1H-XA40DR-A | SYS-OTHER-CJ | PLC本体 |
| CJ1M-CPU13 | SYS-OTHER-CJ | CPU单元 |
| CQM1-OD212 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CP1H-XA40DT-D | SYS-OTHER-CJ | PLC本体 |
| CPM2A-BAT01 | SYS | 电源单元 |
| CP1H-XA40DR-A | SYS-TJ | PLC本体 |
| CQM1-OD213 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CQM1-PA206 | SYS-OTHER-CJ | 电源单元 |
| CQM1-ID213 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| C200HW-PA204S | SYS | 数字量输入、输出混合模块 |
| CP1H-X40DR-A | SYS-OTHER-CJ | PLC本体 |
| CP1L-M30DR-A | SYS-TJ | PLC本体 |
| CJ1W-AD041-V1 | SYS-OTHER-CJ | 模拟量输入模块 |
| C200HE-CPU42-E | SYS-C200-TJ | CPU单元 |
| CP1L-M30DR-A | SYS-SH | PLC本体 |
| C200H-OC225 | SYS-C200-TJ | 数字量输入、输出混合模块 |
| CJ1W-ID211 | SYS-OTHER-CJ | 数字量输入模块 |
| CQM1-ID212 | SYS-OTHER-TJ | 数字量输入、输出混合模块 |
| CPM1A-8ED | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CP1H-XA40DR-A | SYS-SH | PLC本体 |
| CJ1W-PA205R | SYS-OTHER-CJ | 电源单元 |
| CJ1W-OC211 | SYS-OTHER-CJ | 数字量输出模块 |
| CPM1A-40CDR-A-V1 | SYS-SH | PLC本体 |
| CPM1A-8ER | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CQM1H-CPU51 | SYS-OTHER-CJ | CPU单元 |
| CQM1-OD212 | SYS | 数字量输入、输出混合模块 |
| CP1W-CIF01 | SYS-OTHER-CJ | 连接电缆 |
| C200H-BAT09 | SYS | 电源单元 |
| CJ1W-OC211 | SYS | 数字量输入、输出混合模块 |
| ZEN-10C1AR-A-V2 | SYS-OTHER-CJ | PLC本体 |
| CPM2AE-60CDR-A | SYS | PLC本体 |
| CP1L-L14DT-D | SYS | 一体化PLC |
| CQM1-ID212 | SYS | 数字量输入、输出混合模块 |
| CPM2A-40CDT-D | SYS-OTHER-CJ | PLC本体 |
| CQM1-PA203 | SYS | 电源单元 |
| CPM1A-20EDR1 | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CP1L-L20DR-A | SYS | 一体化PLC |
| CPM1A-40CDR-A-V1 | SYS | PLC本体 |
| CQM1H-CPU11 | SYS | CPU单元 |
| CJ1W-PA202 | SYS | 电源单元 |
| CQM1-OD213 | SYS | 数字量输入、输出混合模块 |
| C200HW-BC051 | SYS | 数字量输入、输出混合模块 |
| CPM1A-30CDR-A-V1 | SYS-CPM1A-CJ | PLC本体 |
| CP1L-M40DT-D | SYS-CP1L-CJ | PLC本体 |
| CPM1A-20CDR-A-V1 | SYS-CPM1A-CJ | PLC本体 |
| C200H-DA004 | SYS | 数字量输入模块 |
| CQM1-PA206 | SYS | 电源单元 |
| CPM2AH-60CDR-A | SYS | PLC本体 |
| CJ1W-IC101 | SYS | 分布式I/O |
| C200HW-PA204 | SYS | 电源单元 |
| C200H-CN211 | SYS-A | |
| CJ1M-CPU12 | SYS-OTHER-CJ | CPU单元 |
| C200H-OD212 | SYS-A | 数字量输入/输出模块 |
| C500-DA101 | SYS-A | 模拟量输入/输出模块 |
| CPM1A-40CDR-D-V1 | SYS | PLC本体 |
| CJ1W-OC211 | SYS-OTHER-TJ | 数字量输出模块 |
| CJ1W-ID211 | SYS-OTHER-TJ | 数字量输入模块 |
| CQM1-CIF02(国产) | SYS | 数字量输入、输出混合模块 |
| CJ1W-II101 | SYS-OTHER-CJ | 分布式I/O |
| CJ1W-OC201 | SYS-OTHER-CJ | 数字量输出模块 |
| CPM1A-30CDR-A-V1 | SYS-CPM1A | PLC本体 |
| C200H-TC001 | SYS-A | 功能单元名称 |
| CP1W-CIF01 | SYS-OTHER | 连接电缆 |
| C200HW-BC081-V1 | SYS | 数字量输入、输出混合模块 |
| CS1W-ETN21 | SYS-OTHER | 模拟量输入、输出混合模块 |
| C200H-OC225 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CS1W-CN313 | SYS-OTHER-CJ | 模拟量输入、输出混合模块 |
| CJ1W-OD201 | SYS-OTHER-CJ | 数字量输出模块 |
| CPM1A-16ER | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CPM2A-40CDT-D | SYS | PLC本体 |
| C200H-DA003 | SYS-A | 数字量输入模块 |
| CP1W-40EDR | SYS-OTHER-CJ | PLC本体 |
| CJ1W-IC101 | SYS-OTHER-CJ | 分布式I/O |
| C500-OD213 | SYS-OTHER | 数字量输入、输出混合模块 |
| CPM1A-40CDT-D-V1 | SYS-CPM1A-CJ | PLC本体 |
| CPM2AH-30CDR-A | SYS-OTHER-CJ | PLC本体 |
| CP1L-L20DT-D | SYS | PLC本体 |
| C200HW-ME16K | SYS | 数字量输入、输出混合模块 |
| MPT-CN200 | SYS | PLC底板 |
| C200H-SP001 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CJ1W-AD081-V1 | SYS | 数字量输入模块 |
| C200H-ID212 | SYS | 专用I/O单元 |
| CJ1W-PA202 | SYS-OTHER-JXS | 电源单元 |
| CPM1A-10CDT1-D-V1 | SYS | |
| C200H-SP001 | SYS | 数字量输入、输出混合模块 |
| C200H-OC225 | SYS-C200 | 数字量输入、输出混合模块 |
| NP5-MQ001B | SYS-OTHER-CJ | 触摸屏 |
| CPM2AH-20CDR-A | SYS-OTHER | PLC本体 |
| CJ1W-ID231 | SYS-OTHER-CJ | 数字量输入模块 |
| CPM2AE-60CDR-A | SYS-OTHER-CJ | PLC本体 |
| C200H-IA222 | SYS-C200-CJ | 分布式I/O |
| CQM1-OC222 | SYS-OTHER-DLS | 数字量输入、输出混合模块 |
| CPM2AH-40CDR-A | SYS | PLC本体 |
| CPM1A-30CDR-D-V1 | SYS-OTHER-CJ | PLC本体 |
| CPM1A-8ET | SYS | 数字量输入、输出混合模块 |
| C200HW-PA204 | SYS-C200-DLS | 电源单元 |
| C200HE-CPU11-E | SYS-C200-TJ | CPU单元 |
| CQM1-IPS01 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CJ1M-CPU13 | SYS-CJ-CJ | CPU单元 |
| CQM1-AD041 | SYS | 模拟量输入、输出混合模块 |
| C200HW-BC101-V1 | SYS-C200-JXS | 数字量输入、输出混合模块 |
| CQM1-IPS01 | SYS | 数字量输入、输出混合模块 |
| C200HW-BI101-V1 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200H-ID212 | SYS-C200-DLS | 分布式I/O |
| CPM2A-60CDR-A | SYS-OTHER-CJ | PLC本体 |
| CPM1A-AD041 | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| C200HG-CPU43-E | SYS-C200-DLS | CPU单元 |
| CQM1H-CPU51 | SYS | CPU单元 |
| CJ1W-SCU41-V1 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CPM2AH-20CDR-A | SYS-OTHER-CJ | PLC本体 |
| C200HW-PA204S | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200HG-CPU43-E | SYS | CPU单元 |
| C200H-AD003 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200H-PRO27-E | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CPM2A-40CDR-A | SYS-OTHER-CJ | PLC本体 |
| CJ1W-OD261 | SYS-OTHER-CJ | 数字量输出模块 |
| CQM1-OC222 | SYS-OTHER-JXS | 数字量输入、输出混合模块 |
| MPT-CN200 | SYS-OTHER-CJ | PLC底板 |
| C200HW-BC081-V1 | SYS-C200-DLS | 数字量输入、输出混合模块 |
| NS8-TV00B-ECV2 | SYS-OTHER-CJ | 触摸屏 |
| CJ1M-CPU13 | SYS-OTHER-JXS | CPU单元 |
| CJ1W-PA205R | SYS-OTHER-JXS | 电源单元 |
| C200H-IA222 | SYS | 分布式I/O |
| C200HE-CPU42-E | SYS-C200-CJ | CPU单元 |
| CP1H-XA40DT-D | SYS | 一体化PLC |
| C200H-OC222 | SYS | 数字量输入、输出混合模块 |
| C200H-TS001 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| CP1L-L14DR-A | SYS | 一体化PLC |
| C200H-OC225 | SYS | 数字量输入、输出混合模块 |
| CPM2A-30CDR-A | SYS-OTHER-CJ | PLC本体 |
| C200HE-CPU42-E | SYS | CPU单元 |
| C200H-OC225 | SYS-C200-DLS | 数字量输入、输出混合模块 |
| CP1W-40EDR | SYS | PLC本体 |
| CQM1-IPS02 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| C200HW-PA204 | SYS-C200-JXS | 电源单元 |
| C200HW-PA204R | SYS | 开关电源 |
| C200H-CT021 | SYS-C200-CJ | 高速计数模块 |
| CJ1W-ID261 | SYS-OTHER-CJ | 数字量输入模块 |
| CPM1A-40CDR-A-V1 | SYS-CPM1A-DLS | PLC本体 |
| CPM1A-40EDT | SYS-CPM1A-CJ | 扩展模块 |
| DRT1-OD08-1 | SYS | 专用I/O单元 |
| CPM2AH-20CDR-A | SYS | PLC本体 |
| CQM1H-SCB41 | SYS-OTHER-CJ | 高速计数模块 |
| C200HE-CPU11-E | SYS | CPU单元 |
| CPM1A-20CDR-A-V1 | SYS | PLC本体 |
| CPM1A-MAD02 | SYS | 数字量输入、输出混合模块 |
| CJ1W-AD081-V1 | SYS-CJ-CJ | 模拟量输入模块 |
| C200HW-BC101-V1 | SYS-C200-CJ | 数字量输入、输出混合模块 |
| C200HW-BI081-V1 | SYS | 数字量输入、输出混合模块 |
| CPM1A-10CDR-A-V1 | SYS | PLC本体 |
| C200HW-BI101-V1 | SYS | 数字量输入、输出混合模块 |
| CP1H-XA40DT-D | SYS | PLC本体 |
| CS1W-CIF31 | SYS-OTHER-CJ | 模拟量输入、输出混合模块 |
| CP1L-L20DR-D | SYS | 一体化PLC |
| CP1L-L14DT-D | SYS-SH | 一体化PLC |
| CQM1-OC221 | SYS-SH | 数字量输入、输出混合模块 |
| CPM1A-DA041 | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CPM1A-20CDR-A-V1 | SYS-SH | PLC本体 |
| CQM1-OC222 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CS1W-CN114 | SYS-OTHER-TJ | 模拟量输入、输出混合模块 |
| CP1L-L14DR-D | SYS | 一体化PLC |
| CQM1-OC221 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CPM1A-20CDR-D-V1 | SYS-CPM1A-TJ | PLC本体 |
| C200HW-BC081-V1 | SYS-C200-TJ | 数字量输入、输出混合模块 |
| CP1H-X40DT-D | SYS | PLC本体 |
| CJ1W-OC211 | SYS | 数字量输出模块 |
| CP1L-L20DR-A | SYS-SH | 一体化PLC |
| CPM1A-20CDR-D-V1 | SYS-CPM1A-CJ | PLC本体 |
| CP1L-L20DT-D | SYS-SH | PLC本体 |
| C200H-CN711 | SYS-C200-TJ | 数字量输入、输出混合模块 |
| CJ1W-II101 | SYS | 分布式I/O |
| CJ1W-AD041-V1 | SYS | 模拟量输入模块 |
| CQM1-PA203 | SYS-OTHER-CJ | 电源单元 |
| CP1L-M40DT-D | SYS-SH | PLC本体 |
| CPM1A-MAD02 | SYS-CPM1A-CJ | 数字量输入、输出混合模块 |
| CQM1-AD041 | SYS-OTHER-DLS | 模拟量输入、输出混合模块 |
| CPM2AE-60CDR-A | SYS-OTHER-JXS | PLC本体 |
| CPM1A-40CDT-D-V1 | SYS-SH | PLC本体 |
| CP1H-X40DT-D | SYS-SH | PLC本体 |
| CPM2A-40CDT-D | SYS-SH | PLC本体 |
| CQM1-ID212 | SYS-CQ-JXS | 数字量输入、输出混合模块 |
| CP1L-L20DT-D | SYS | 一体化PLC |
| CQM1-PA203 | SYS-SH | 电源单元 |
| CS1W-CN114 | SYS-OTHER-CJ | 模拟量输入、输出混合模块 |
| CQM1H-CPU21 | SYS-OTHER-TJ | CPU单元 |
| C200H-OC224 | SYS-TJ | 数字量输入、输出混合模块 |
| CS1W-CIF31 | SYS-TJ | 模拟量输入、输出混合模块 |
| C200HW-BC051 | SYS-TJ | 数字量输入、输出混合模块 |
| CP1L-M30DT-D | SYS | 一体化PLC |
| CJ1W-AD041-V1 | SYS-TJ | 数字量输入模块 |
| C200H-OC224 | SYS | 数字量输入、输出混合模块 |
| C200HE-CPU42-E | SYS-TJ | CPU单元 |
| CQM1-OD214 | SYS-TJ | 数字量输入、输出混合模块 |
| C200HW-BI081-V1 | SYS-TJ | 数字量输入、输出混合模块 |
| C200HW-BI101-V1 | SYS-TJ | 数字量输入、输出混合模块 |
| C200H-DAC01 | SYS-TJ | 数字量输入、输出混合模块 |
| CJ1W-TER01 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CJ1W-ID211 | SYS-OTHER-JXS | 数字量输入模块 |
| CJ1W-OC211 | SYS-OTHER-JXS | 数字量输出模块 |
| CJ1G-CPU44H | SYS-OTHER-JXS | CPU单元 |
| CJ1W-SCU41-V1 | SYS-OTHER-JXS | 数字量输入、输出混合模块 |
| CJ1W-AD041-V1 | SYS-OTHER-JXS | 模拟量输入模块 |
| CJ1W-ID231 | SYS-OTHER-JXS | 数字量输入模块 |
| CJ1W-AD081-V1 | SYS-OTHER-JXS | 模拟量输入模块 |
| CJ1W-OD261 | SYS-OTHER-JXS | 数字量输出模块 |
| C200HW-PA204 | SYS | PLC |
| CJ1M-CPU22 | SYS-OTHER-JXS | CPU单元 |
| CPM1A-30CDR-A-V1 | SYS | PLC本体 |
| CQM1-PA203 | SYS-OTHER-TJ | 电源单元 |
| CPM1A-8ER | SYS-CPM1A-DLS | 数字量输入、输出混合模块 |
| CPM1A-30CDR-A-V1 | SYS-SH | PLC本体 |
| CP1L-M40DR-A | SYS-CP1L-CJ | PLC本体 |
| CJ1M-CPU12 | SYS-SH | CPU单元 |
| CP1L-M30DT-D | SYS-SH | PLC本体 |
| C200HW-BC051 | SYS-SH | 数字量输入、输出混合模块 |
| CPM1A-40CDR-A-V1 | SYS-CPM1A-TJ | PLC本体 |
| CJ1W-ID211 | SYS | 数字量输入模块 |
| CS1W-CN313 | SYS | 模拟量输入、输出混合模块 |
| CJ1W-DA021 | SYS | 模拟量输出模块 |
| CJ1W-ID231 | SYS | 数字量输入模块 |
| CP1L-M40DR-A | SYS | PLC本体 |
| CJ1W-MAD42 | SYS-OTHER-CJ | 数字量输入、输出混合模块 |
| CJ1W-OD231 | SYS-OTHER-JXS | 数字量输出模块 |
| CS1W-CIF31 | SYS-OTHER-TJ | 模拟量输入、输出混合模块 |
| CP1L-L14DR-A | SYS-CP1L | PLC本体 |
| CQM1-ID212 | SYS-OTHER-DLS | 数字量输入、输出混合模块 |
| C200H-OD213 | SYS-TJ | 数字量输入、输出混合模块 |
| C200H-CN311 | SYS-TJ | 数字量输入、输出混合模块 |
| CJ1W-DA021 | SYS-OTHER-CJ | 模拟量输出模块 |
| CPM1A-40CDR-A-V1 | SYS-CPM1A-JXS | PLC本体 |
| C200HW-PA204 | SYS-TJ | 电源单元 |
- 电话:0512-82098825
- 传真:0512-82098825
- email:hy07990@163.com
更多内容请访问 顾先东_17(http://home.gongkong.com/profile/?uid=2008072618060000001)
OMRON 产品库存促销,特价现货供应
