当前页面: 首页 >供求信息 >西门子编程电缆6FX2001-3EB02 6FX2001-3EC50 6FX2001-7KF10
供稿:dachenghengye 2009/1/10 22:40:10
人气:199
  • 型号:6FX2003-0CE12 6FX2003-0CB10 6FX2003-0CA10
  • 数量:大量
  • 制造商:德国
  • 有效期:2027/4/24 0:00:00
天津大成恒业机电设备有限公司
西门子编程电缆长期现货
6FX2001-3EB02 sin/cos 1 Vpp incremental encoder, Synchronous flange and 5 V DC supply voltage, Connection: Radial flange outlet, 1024 S/R
6FX2001-3EC50
6FX2001-5FE13 EnDat absolute encoder, Synchronous flange and 5 V DC supply voltage Connection: • Radial flange outlet, Resolution: Single-turn 8192 steps/revolution(13-bit)
6FX2001-7KF10 spring disk coupling
6FX2001-7KP01 clamp
6FX2001-7KS06 spring disk coupling
6FX2002-1AA01-1AD0 V24-RS232 CABLE 9Pins[SOCKET]-9Pins[SOCKET]
6FX2002-1DC00-1AF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(5M)
6FX2002-1DC00-1BA0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(10M)
6FX2002-1DC00-1BF0 Drive CLiQ cable from 802D sl PCU to SINAMICS line module(15M)
6FX2002-2CE02-1BA0 Signal cable built-in ROD320 L=10M
6FX2002-3AB01-1AF0
6FX2002-3AD01-1AH0 Cable 802C BL - 611U(7M)
6FX2002-3AD01-1BA0 Cable 802C BL - SIMODIRVE L=10M
6FX2002-4EA01-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=5m;l1=1m)
6FX2002-4EA04-1AF0 MPI bus cable with three connectors CNC-MMC-MSTT(l2=1m;l1=5m)
6FX2002-4EA80-1BA0 Pre-assembled MPI bus cable
6FX2002-5AA12-1BF0 POWER CABLE 1FT5, CONNECTOR SIZE 2, 4X4 SQMM, L=15M
6FX2003-0AA02 Profibus connector
6FX2003-0CA10 power cable connector
6FX2003-0CB10 power cable connector
6FX2003-0CB20 power cable connector
6FX2003-0CE12 connector type 12-way
  • 电话:010-88603269/65431486/654334982
  • 传真:010-65431486-8005
  • email:dachenghengye@yahoo.con
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
