当前页面: 首页 >供求信息 >西门子编程电缆6FX5002-5CS12-1BA0/6FX5002-5CS31-1AF0/6FX5002-5CS41-1BF0
供稿:dachenghengye 2009/1/8 9:43:25
人气:174
  • 型号:6FX6002-2CA31-1BF0/6FX6002-2CA31-1BA0/6FX6002-2CA31-1AE0
  • 数量:大量
  • 制造商:德国
  • 有效期:2027/4/24 0:00:00
天津大成恒业机电设备有限公司
电话010-88603269/65431486          西门子编程电缆6FX长期现货
6FX5002-5CS12-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103
6FX5002-5CS12-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M open connection in motor side, 4x2.5 sqr.mm,used for 1PH7103
6FX5002-5CS31-1AF0 Power cable for 27NM,5M
6FX5002-5CS31-1BA0 Power cable for 27NM,10M
6FX5002-5CS31-1BF0 Power cable for 27NM,15M
6FX5002-5CS41-1AF0 Power cable for 36NM,5M
6FX5002-5CS41-1BA0 Power cable for 36NM,10M
6FX5002-5CS41-1BF0 Power cable for 36NM,15M
6FX5002-5CS42-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M open connection in motor side, 4x4 sqr.mm, used for 1PH7107
6FX5002-5CS42-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M open connection in motor side, 4x4 sqr.mm,used for 1PH7107
6FX5002-5CS42-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M open connection in motor side, 4x4 sqr.mm,used for 1PH7107
6FX5002-5CS51-1AF0 Power cable for 45NM,5M
6FX5002-5CS51-1BA0 Power cable for 45NM,10M
6FX5002-5CS51-1BF0 Power cable for 45NM,15M
6FX5002-5CS52-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5CS52-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5CS52-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M open connection in motor side, 4x6 sqr.mm, used for 1PH7133-xxD02
6FX5002-5DA01-1AF0 power cable for 3.2-16NM,5M
6FX5002-5DA11-1AF0 power cable for 18 Nm motor,5M,brake
6FX5002-5DA11-1BA0 power cable for 18 Nm motor,10M,brake
6FX5002-5DA11-1BF0 power cable for 18 Nm motor,15M,brake
6FX5002-5DA11-1CA0 power cable for 18 Nm motor,20M,brake
6FX5002-5DA31-1AF0 power cable for 27 Nm motor,5M,brake
6FX5002-5DA31-1BA0 power cable for 27 Nm motor,10M,brake
6FX5002-5DA31-1BF0 power cable for 27 Nm motor,15M,brake
6FX5002-5DA41-1AF0 power cable for 27 Nm motor,5M,brake
6FX5002-5DA41-1BA0 power cable for 27 Nm motor,10M,brake
6FX5002-5DA41-1BC0 power cable for 27 Nm motor,12M,brake
6FX5002-5DA41-1BF0 power cable for 27 Nm motor,15M,brake
6FX5002-5DA41-1CA0 power cable for 27 Nm motor,20M,brake
6FX5002-5DA51-1AF0 power cable for 36 Nm motor,5M,brake
6FX5002-5DA51-1BA0 power cable for 36 Nm motor,10M,brake
6FX5002-5DA51-1BF0 power cable for 36 Nm motor,15M,brake
6FX5002-5DS01-1AF0 Power cable below 18NM,5M,With brake
6FX5002-5DS01-1BA0 Power cable below 18NM,10M,With brake
6FX5002-5DS01-1BF0 Power cable below 18NM,15M,With brake
6FX5002-5DS31-1AF0 Power cable for 27NM,5M,with brake
6FX5002-5DS31-1BA0 Power cable for 27NM,10M,with brake
6FX5002-5DS31-1BF0 Power cable for 27NM,15M,with brake
6FX5002-5DS41-1AF0 Power cable for 36NM,5M,with brake
6FX5002-5DS41-1BA0 Power cable for 36NM,10M,with brake
6FX5002-5DS41-1BF0 Power cable for 36NM,15M,with brake
6FX5002-5DS51-1AF0 Power cable for 45NM,5M,with brake
6FX5002-5DS51-1BA0 Power cable for 45NM,10M,with brake
6FX5002-5DS51-1BF0 Power cable for 45NM,15M,with brake
6FX5008-1BA11-1FA0 POWER CABLE, 4X1.5 +2X1.5C L=50M
6FX5008-1BB51-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB51-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB51-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M open connection in motor side, 4x10 sqr.mm, used for 1PH7133-xxG02/1PH7137xxD02
6FX5008-1BB61-1AF0 Power cable for 1FT/1FK/1PH spindle motor,5M open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD03
6FX5008-1BB61-1BA0 Power cable for 1FT/1FK/1PH spindle motor,10M open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD03
6FX5008-1BB61-1BF0 Power cable for 1FT/1FK/1PH spindle motor,15M open connection in motor side, 4x16 sqr.mm, used for 1PH7137-xxG02/1PH7163xxD04
6FX5008-1BD21-2AA0 SIGNAL CABLE, 4X2X0.34+4X0.5C L=100M
6FX5008-1BD51-2AA0 SIGNAL CABLE, 3X2X0.14+4X0.14+2X0.5+4X0.22C C L=100M
6FX6002-2CA31-1AB0 signal cable,1M
6FX6002-2CA31-1AD0 signal cable,3M
6FX6002-2CA31-1AE0 signal cable,4M
6FX6002-2CA31-1AF0 signal cable,5M
6FX6002-2CA31-1AG0 signal cable,6M
6FX6002-2CA31-1AH0 signal cable,7M
6FX6002-2CA31-1AJ0 signal cable,9M
6FX6002-2CA31-1BA0 signal cable,10M
6FX6002-2CA31-1BC0 signal cable,12M
6FX6002-2CA31-1BF0 signal cable,15M
  • 电话:010-88603269/65431486/654334982
  • 传真:010-65431486-8005
  • email:dachenghengye@yahoo.con
更多内容请访问 dachenghengye(http://home.gongkong.com/profile/?uid=2008070812083700001)
