当前页面: 首页 >供求信息 >科尔摩根伺服驱动 620 S62000-SE
供稿:番禺艺鑫自动化配件销售部 2008/10/31 22:41:19
人气:863
  • 型号:620
  • 数量:10000000
  • 制造商:ServoStar
  • 有效期:2027/4/24 0:00:00
kollmorgen servostar 600伺服驱动器
S60301 S60601 S61000 S61001 S61400 S61401 S62000 S6961 S6962 S6M4H/S6T
S60100   S60300   S60600   S61000   S61400  S62000   S62001   S64001   S67001 S610-30
Servo amplifiers
Article EU order code US order code
SERVOSTAR 601 DE-89700 not available
SERVOSTAR 603 DE-89701 S60300-NA
SERVOSTAR 606 DE-89702 S60600-NA
SERVOSTAR 610 DE-89703 S61000-NA
SERVOSTAR 610-30 DE-102192 S610-3000-NA
SERVOSTAR 614 DE-90846 S61400-NA
SERVOSTAR 620 DE-89704 S62000-NA
SERVOSTAR 601-AS DE-90350 not available
SERVOSTAR 603-AS DE-90351 S60301-NA
SERVOSTAR 606-AS DE-90352 S60601-NA
SERVOSTAR 610-AS DE-90353 S61001-NA
SERVOSTAR 610-30-AS DE-102897 S610-3001-NA
SERVOSTAR 614-AS DE-91448 S61401-NA
SERVOSTAR 620-AS DE-90354 S62001-NA
S600系列伺服驱动器ServoStar S600驱动器
型号:S60100   S60300   S60600   S61000   S61400  S62000   S62001   S64001   S67001
servostaR 346;
DANAHERMOTION数字伺服放大器servostaR600:
servostaR601, servostaR603, servostaR606, servostaR610, servostaR614, servostaR620, servostaR640, servostaR670
S200,   Kollmorgen  S200
SERVOSTAR S200部分型号:
S20260-VTS, S20630-VTS,S20330,S20630,S20360,S21260,S22460,S24860
S20330-VTS,S20330-CNS,S20330-DNS,S20630-VTS,S20630-CNS,S20630-DNS,
S20260-VTS,S20260-CNS,S20260-DNS,S20360-VTS,S20360-CNS,S20360-DNS
S400,   Kollmorgen  S400
403-M,406-M,403-A,406-A,443-M,446-M,403-A,406-A
 S300   Kollmorgen S300
S30101-NA  S30301  S30361-NA  S30601  S30661  S31061-NA  S30363
S30661    S31061  S30301    S30601  S30101 SERVOSTAR 303 S30361-NA  SERVOSTAR 306 S30661-NA   SERVOSTAR 310  S31061-NA  SERVOSTAR 341 S30101-NA
SERVOSTAR 343 S30301-NA  SERVOSTAR 346  S30601-NA
SERVOSTAR S600部分型号:
S60100   S60300   S60600   S61000   S61400  S62000   S62001   S64001   S67001 S610-30ServoStar CD系列驱动器:
CD2系列:CR03250    CR06250(有现货)   CR06251 CR10250 CR10251 CE03250 CE06250
CD5系列:CR03550 CR06550(现货)CR06560(现货) CR10550(有现货)   CE03550 CE06550 CE10550   CB03550 CB06550 CE10550   LR03565 LR06565 LR10565  LE03565(现货)     LR06565    LR10565
CD2系列:CR03250 CR06250 CR06251 CR10250 CR10251 CE03250 CE06250
CD5系列:CR03550 CR06550 CR10550 CE03550 CE06550 CE10550 CB03550 CB06550 CE10550
 LR03565 LR06565 LR10565 LE03565 LR06565 LR10565 CE06660 CE03200 CE03250 CE03260 CE03550 CR03250 CR03550 CR03560 CR06250 CR06260 CR06550 CR10260 CR10550 CR20560 CB06250 CB03560 CB03561 CB06550 CB06551 CB06560 CB06561 CB10550 CB10551 CB10660 CB20560 CE03250 CE03550 CE03560 CE03561 CE06250 CE03561 CE06250 CE06550 CE06560 CE10560 CE20560 CE20570 CE03250 CR03302 CR03550 CR03560 CR03561 CR0625O
CR0625K CR06550 CR06560 CR06561 CR10250 CR10550 CR10560 CR10561 CR10660 CR10750 CR20560 CR20561
SERVOSTAR S200部分型号:
S20260-VTS,S20630-VTS,S20330,S20630,S20360,S21260,S22460,S24860S20330-VTS S20330-CNS,S20330-DNS,S20630-VTS,S20630-CNS,S20630-DNS,S20260-VTS,S20260-CNS,S20260-DNS,S20360-VTS,S20360-CNS,S20360-DNS
ServoStar CD系列驱动器:
Kollmorgen SERVOSTAR 700部分选型:
S70101  S70301  S70601  S71201 S7120P  S72401 S7240P
Servo amplifier S701 S70101-NA
Servo amplifier S701-FN2 S70101-FN2
Servo amplifier S701-FN3 S70101-FN3
Servo amplifier S703 S70301-NA
Servo amplifier S703-FN2 S70301-FN2
Servo amplifier S703-FN3 S70301-FN3
Servo amplifier S706 S70601-NA
Servo amplifier S706-FN2 S70601-FN2
Servo amplifier S706-FN3 S70601-FN3
Servo amplifier S712 S71201-NA
Servo amplifier S712-FN2 S71201-FN2
Servo amplifier S712-FN3 S71201-FN3
Servo amplifier S712/30 S7120P-NA
Servo amplifier S712/30-FN2 S7120P-FN2
Servo amplifier S712/30-FN3 S7120P-FN3
Servo amplifier S724 S72401-NA
Servo amplifier S724-FN2 S72401-FN2
Servo amplifier S724-FN3 S72401-FN3
Servo amplifier S724/72 S7240P-NA
Servo amplifier S724/72-FN2 S7240P-FN2
Servo amplifier S724/72-FN3 S7240P-FN3
Servo amplifier S70102 S70102-NANANA
Servo amplifier S70302 S70302-NANANA
Servo amplifier S70602 S70602-NANANA
Servo amplifier S71202 S71202-NANANA
Servo amplifier S7120S S7120S-NANANA
Servo amplifier S72402 S72402-NANANA
Servo amplifier S7240S S7240S-NANANA
*= Standard: with internal brake resistor, CANopen and EtherCAT onboard, dual channel
STO, 208...480V mains voltage. See "Part number scheme" on p. 22.
Article (standard version with F2 option
built Slot 2)
Servo amplifier S70102-NAF2NA S70102-NAF2NA
Servo amplifier S70302-NAF2NA S70302-NAF2NA
Servo amplifier S70602-NAF2NA S70602-NAF2NA
Servo amplifier S71202-NAF2NA S71202-NAF2NA
Servo amplifier S7120S-NAF2NA S7120S-NAF2NA
Servo amplifier S72402-NAF2NA S72402-NAF2NA
Servo amplifier S7240S-NAF2NA S7240S-NAF2NA
built in Slot 3)
Servo amplifier S70102-NANAF2 S70102-NANAF2
Servo amplifier S70302-NANAF2 S70302-NANAF2
Servo amplifier S70602-NANAF2 S70602-NANAF2
Servo amplifier S71202-NANAF2 S71202-NANAF2
Servo amplifier S7120S-NANAF2 S7120S-NANAF2
Servo amplifier S72402-NANAF2 S72402-NANAF2
Servo amplifier S7240S-NANAF2 S7240S-NANAF2
KOLLMOR 5W697 44114-49D02204
Kollmorgen LB06565
Kollmorgen B-404S-C-93-B3-072
Kollmorgen S200 S20260-VTS
KOLLMOR PRO-0019200-00
KOLLMOR PRO-00190301-08
KOLLMOR PRO-SC30200F-40
KOLLMOR SC1E06260-0000000
Kollmorgen 1-604-0222
Kollmorgen 6SM 57M-3.000-G
Kollmorgen H-342-H-0015
Kollmorgen U12D-BENC 516864
Kollmorgen  D101B (300mm)
Kollmorgen MTC306B1-S2C1
Kollmorgen D101A
Kollmorgen D101A
Kollmorgen U9M4GH110ENC
Kollmorgen H-344-H-0212
Kollmorgen MTC506C1
Kollmorgen SERVOSTAR 600 606 S60600
Kollmorgen 5AF-1300-05
KOLLMORGEN AKM53K-CNC2R-00
Kollmorgen MTC304A1-R2C1
Kollmorgen MTC302A1-R2C1
Kollmorgen MT302A1-M2C1
Kollmorgen MT304A1-R2C1
KOLLMORGEN B206-A-24 BRUSHLESS SERVO
Kollmorgen B-204-A-22 GOLDLINE BRUSHLESS
Magnetek M812A-0000 Servomotor - Kollmorgen
Kollmorgen AKM44J-EKCN2-00
Kollmorgen MTC504C1-R1A1-013
KOLLMORGEN伺服电机6SM 27M-4.000
ServoStar CD系列驱动器:
CD5系列:CR03550 CR06550 CR06560 CR10550 B-606-A-B1
CD2 Series: CR03550  CR03250 CR06250  CR06251 CR10250 CR10251 CE03250 CE06250
CD5 Series: CR03550 CR06550  CR06560  CR10550  B-606-A-B1 spot
CD2 Series: CR03250 CR06250 CR06251 CR10250 CR10251 CE03250 CE06250
CD5 Series: CR03550 CR06550 CR10550 CE03550 CE06550 CE10550 CB03550 CB06550 CE10550
CE03550 CE06550 CE10550 CB03550 CB06550 CE10550  LR03565 LR06565 LR10565 LE03565 LR06565 LR10565
ServoStar S300驱动器:
型号:S30363   S30661   S31061       S30301   S30601   S30101
ServoStar S600驱动器 型号:S60100   S60300   S60600   S61000   S61400    S62000   S62001   S64001   S67001
servostaR 300: servostaR 303, servostaR 306, servostaR 310, servostaR 341, servostaR 343, servostaR 346;
servostaR601,servostaR603,servostaR606,servostaR610,servostaR614,servostaR620,servostaR640,servostaR670
  • 电话:18928819993
  • 传真:020-28662339
  • email:powerwin@163.com
更多内容请访问 番禺艺鑫自动化配件销售部(http://home.gongkong.com/profile/?uid=4-B9D7-43476DBF454D)
