当前页面: 首页 >供求信息 >PSM-EG-RS232/RS 422-P/4K菲尼克斯产品
供稿:boyi1010 2008/9/29 13:20:04
人气:131
  • 型号:PSM-EG-RS232/RS 422-P/4K
  • 制造商:菲尼克斯
  • 有效期:2027/4/24 0:00:00
PSM-EG-RS232/RS422-P/4K
FL CRIMPTOOL
ZB 6,6:UNBEDRUCKT
FL SWITCH 5TX
FL SWITCH SFN 5TX
VIO K 1,5
EB 10- DIK BU
EB 10- DIK RD
IB IL AO 2/U/BP-PAC
FLM DO 8 M12
IB ST 24 AI 4/SF4
FLS IB M12 DO 8 M12-2A
FLS IB M12 DI 8 M12
IB ST 24 AO 4/BP
IB ST 24 AI 4/SF
FL HUB 8TX-ZF
FL SWITCH 5TX-ZF
PSI-DATA/FAX-MODEM/SET1
PSI-DATA/FAX-MODEM/RS232
FL SWITCH SFN 4TX/FX
IBS IP 400 ME-VFD 1-3A DI4
IB IL 24 DI 8
IB IL 24 DI 2
IB IL 24 PWR IN/F
IB IL 24 DO 8
IB IL 24 DI 32/HD-PAC
IB IL 24 DO 32/HD-PAC
IBS MC FLASH 2MB
IBS RL 24 DI 16/8-T
IBS RL PLUG-T
IBS S7 300 DSC-T
IBS IP CDIO/R 24-8/SF
IB STME 24 BDO 32/2
IBS DSUB 9/C
SUBCON 9/F-SH
IBS TR5 5AT
FL IL 24 BK-PN-PAC
IBS RBC METER-T
IBS PC CB/TDOS486/I-T
IBS ST 24 BK-T
IB IL SSI-IN-PAC
IL PB BK DP/V1
IBS PC ISA SC/I-T
IB IL 400 ELR R-3A
IB IL 400 ELR 1-3A
FL SWITCH Sf 14TX/2FX
FL SWITCH SFN 6TX/2FX
PSI-MOS-PROFIB/FO 660 E
PSM-SET-FSMA/4-HC
IB ST 24 DI 32/2
IB ST 24 DI 16/4
IB IL 24 PWR IN/2-F
FLS IB M12 DI 8 M12
FL SWITCH 4TX/FX
SST-IBS-CLX-RLL
IL MII BK DI8 DO4-PAC
FL SWITCH MM HS
FL CAT5 TERMINAL BOX
FL MC10/100BASE-T/FOG1300
  • 电话:021-66100983 66100663
  • 传真:021-61638399-9148
  • email:boyi1010@126.com
