- 型号:PU 1 TSG 50KA / 1,5KV
- 数量:100
- 制造商:威德米勒
- 有效期:2027/4/24 0:00:00
PU 4 BR 275 VAC
PU 2 C 130 VAC
PU 3 C 130 VAC
PU 4 C 130 VAC
PU 4 CR 130 VAC
PU 1 C 550 VAC
PU 2 C 550 VAC
PU 4 C 550 VAC
WDK 2.5 2D 1R 1K5 OR.
WOS2 115VUC
RS SD37S LD LP2HR
DK F-I DK5 0-50KHZ
OST EG7 RC FILTER
AP 80
AP DK6 PA BE
MCZ TO 24VDC/50MS
MCZ O 24VDC
UPAC U-I 0-10V/4-20MA
UPAC I-U 4-20MA/0-10V
UPAC ANALOG ISO I-IN
UPAC ANALOG ISO U-IN
PU 0 C 385 VAC
RS F10 8R OUT 24VDC
UPAC ALARM DC I-IN
DKZA DK5 24VDC 1-100S
UPAC ANALOG I-IN +/-OUT
SIM S7/400 FB40 2.0M
SIM S7/400 FB40 2.5M
SIM S7/400 FB40 3.0M
SIM S7/400 FB40 5.0M
SIM S7/400 FB4*10 2.0M
SIM S7/400 FB4*10 2.5M
SIM S7/400 FB4*10 3.0M
SIM S7/400 FB4*10 5.0M
PU 0 C 280 VAC
PU 2 C 75 VAC
LON BK PASSIV XSL 511
SH 2S (064172E) (E)
TIMER ITM 0.1S-100H
TIMER ITR 0.1S-10H
TIMER ITWO 0.1S-10H
TIMER ITTO 0.06S-160S
MCZ O 24VUC
MCZ R 24VDC
PSR 24VDC LD 1CO
PSR 24VDC LD 2CO
PSR 230VAC LD 2CO
PS 35 RT 78625
RS 100 PROFIL 65,5MM
PS RC P RT 16016
PU 1 C 75 VAC
PU 3 CR 385 VAC
PU 0 B 275 VAC
PU 3 B 275 VAC
PU 3 BR 275 VAC
SCHRACK-RELAIS RT314024
EGO EG7 RC 230VAC
AP MCZ1.5
MCZ R 24VUC
OST EG7 230VAC RC
PB-DP SUB-D
MCZ 5 SET
MCZ O 5VTTL
MCZ CCC 0-20mA/0-20mA
PU D 230V 16A
PU 3+1 C 275 VAC
WRS1 24/115VUC 1U
WRS1 24VUC/230VAC 1U
WRS2 12/24VDC 2A
WRS2 24/48VUC 2A
WRS2 115VUC/230VAC 2A
WRS2 12/24VDC 1A1R
WRS2 24/48VUC 1A1R
WRS2 115VUC/230VAC 1A1R
WRS2 12/24VDC 2U
WRS2 24/48VUC 2U
WRS2 24VUC/230VAC 2U
WRS2 24VUC 3A
WRS2 230VAC 3A
MCZ R 120VAC
MCZ O 120VUC
MCZ O 230VAC
PU 2 CR 275 VAC
MCZ PT100/3 CLP 0...100C
POS-4P M12 PG13,5 300 mm
POS-4P M12 M20 150mm
POS-4P M12 M20 300mm
Schutzkappe Dose
BUS-T-CONNECTOR STANDARD
BUS-T-CONNECTOR M.GASAB
BUS-T-CONNECTOR EEXIA
BUS-TERMINATORMODUL EEX
FBCon M12 4P FM EMC
WAVEBOX S 22.5
WAVEBOX S 22.5 QV
TOP UNIT S 22.5
WAVEBOX L 22.5
WAVEBOX L 22.5 QV
TOP UNIT L 22.5
WAVEBOX L 12.5
WAVEBOX L 12.5 QV
TOP UNIT L 12.5
WAVEBOX L 17.5
WAVEBOX L 17.5 QV
TOP UNIT L 17.5
SL 5.08/3 OR R
SL 5.08/3 OR L
SL 5.08/2 OR R
SL 5.08/2 OR L
CAP WAVEBOX L22,5/17,5
CAP 2 WAVEBOX 12,5
RS F10 I/O8 LMZF
RS F40 I/O32 LMZF
RS F10 INIT8 LD LMZF
RS F40 INIT32 LD LMZF
WOZ2 15-60VUC
RS F40 INIT32 LMZF
RS F10 8RS OUT LMZF
RS F40 32RS OUT LMZF
WTS4 PT100/3 V 0-10V
WTS4 PT100/3 V 0-10V 0...100C
WTS4 PT100/3 V 0-10V variabel
WTZ4 PT100/3 V 0-10V
WTZ4 PT100/3 V 0-10V 0...100C
WTZ4 PT100/3 V 0-10V variabel
WTS4 PT100/3 C 0/4-20mA
WTS4 PT100/3 C 0-20mA 0...100C
WTS4 PT100/3 C 4-20mA 0...100C
WTS4 PT100/3 C 0/4-20mA variabel
WTZ4 PT100/3 C 0/4-20mA
WTZ4 PT100/3 C 0-20mA 0...100C
WTZ4 PT100/3 C 4-20mA 0...100C
WTZ4 PT100/3 C 0/4-20mA variabel
- 电话:021-66100983 66100663
- 传真:021-61638399-9148
- email:boyi1010@126.com
魏德米勒 PU 1 TSG 50KA / 1,5KV 避雷器
